[pdal-commits] [PDAL/PDAL] 073711: Expect one of multiple possible PROJ.4 outputs
GitHub noreply at github.com
Thu Feb 25 08:24:10 PST 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 073711478aab027222cf54fa86d661c307462f03
      https://github.com/PDAL/PDAL/commit/073711478aab027222cf54fa86d661c307462f03
  Author: Mateusz Łoskot <mateusz at loskot.net>
  Date:   2016-02-25 (Thu, 25 Feb 2016)
  Changed paths:
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
PROJ.4 output may change between version and checking
all possibilities is easier than determining which one
corresponds with particular PROj.4 version.
Clean up float/double mismatch warning.
  Commit: e6a9a3a3c01d0e3c42a4322a2e40b7cddff64546
      https://github.com/PDAL/PDAL/commit/e6a9a3a3c01d0e3c42a4322a2e40b7cddff64546
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #1158 from mloskot/ml/fix-proj4-output-test
Compare: https://github.com/PDAL/PDAL/compare/433e507a6c10...e6a9a3a3c01d
More information about the pdal-commits mailing list
