[pdal-commits] [PDAL/PDAL] d0ec58: Initial roll-up of draft JSON spec (wrt #1071)
GitHub
noreply at github.com
Mon Feb 29 11:37:03 PST 2016
Branch: refs/heads/json-pipeline
Home: https://github.com/PDAL/PDAL
Commit: d0ec581e730cb5d14b76d34fbe06f8c4c133b4e1
https://github.com/PDAL/PDAL/commit/d0ec581e730cb5d14b76d34fbe06f8c4c133b4e1
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-02-26 (Fri, 26 Feb 2016)
Changed paths:
A doc/json_pipeline_specification.rst
Log Message:
Commit: e2bdd912c095a001bf330da9540dd15b953a29d3
https://github.com/PDAL/PDAL/commit/e2bdd912c095a001bf330da9540dd15b953a29d3
Changed paths:
Log Message:
Merge branch 'draft-json-pipeline-spec' into json-pipeline
Commit: 0f94cb7ac2e9f5d7e22ceccc4d55b0013a82cfa3
https://github.com/PDAL/PDAL/commit/0f94cb7ac2e9f5d7e22ceccc4d55b0013a82cfa3
Date: 2016-02-29 (Mon, 29 Feb 2016)
Changed paths:
M doc/stages/filters.colorization.rst
M doc/stages/filters.hexbin.rst
M doc/tutorial/clipping-with-shapefile.rst
M doc/tutorial/pcl_block_tutorial.rst
M doc/tutorial/reading.rst
M doc/tutorial/writing-reader.rst
M doc/tutorial/writing-writer.rst
A examples/writing-reader/pipeline-myreader.json
R examples/writing-reader/pipeline-myreader.xml
A examples/writing-writer/pipeline-mywriter.json
R examples/writing-writer/pipeline-mywriter.xml
M kernels/info/InfoKernel.cpp
M src/PipelineManager.cpp
A test/data/bpf/bpf.json.in
A test/data/bpf/bpf2nitf.json.in
A test/data/filters/chip.json.in
A test/data/filters/colorize.json.in
A test/data/filters/crop_wkt.json.in
A test/data/filters/crop_wkt_2d.json.in
A test/data/filters/crop_wkt_2d_classification.json.in
A test/data/filters/hexbin-info.json.in
A test/data/filters/hexbin.json.in
A test/data/filters/range_classification.json.in
A test/data/filters/range_z.json.in
A test/data/filters/range_z_classification.json.in
A test/data/filters/reproject.json.in
A test/data/filters/splitter.json.in
A test/data/filters/stats.json.in
A test/data/hole/crop.json.in
A test/data/io/p2g-writer.json.in
A test/data/io/text-writer-csv.json.in
A test/data/io/text-writer-geojson.json.in
A test/data/io/text-writer-space-delimited.json.in
A test/data/nitf/conversion.json.in
A test/data/nitf/las2nitf.json.in
A test/data/nitf/write_laz.json.in
A test/data/nitf/write_options.json.in
A test/data/pipeline/drop_color.json.in
A test/data/pipeline/pipeline_interpolate.json.in
A test/data/pipeline/pipeline_metadata_writer.json.in
A test/data/pipeline/pipeline_mississippi.json.in
A test/data/pipeline/pipeline_mississippi_reverse.json.in
A test/data/pipeline/pipeline_multioptions.json.in
A test/data/pipeline/pipeline_read.json.in
A test/data/pipeline/pipeline_read_notype.json.in
A test/data/pipeline/pipeline_write.json.in
A test/data/pipeline/pipeline_write2.json.in
A test/data/plang/predicate-keep-ground-and-unclass.json.in
A test/data/plang/predicate-keep-last-return.json.in
A test/data/plang/predicate-keep-specified-returns.json.in
M test/unit/apps/pcpipelineTest.cpp
Log Message:
Doc and test updates, infer pipeline type (JSON or XML)
* Update docs to use JSON vice XML
* Replicate existing XML unit tests in JSON format
* Instruct InfoKernel and PipelineManager to infer XML or JSON based on extension
Commit: d3f6e9418d6065f3a0a22a990991519a35d7b69e
https://github.com/PDAL/PDAL/commit/d3f6e9418d6065f3a0a22a990991519a35d7b69e
Changed paths:
M README.md
M cmake/python.cmake
M filters/colorization/ColorizationFilter.hpp
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/test/CpdKernelTest.cpp
M plugins/oci/test/OCITest.cpp
M scripts/appveyor/config.cmd
M src/PipelineWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/json-pipeline' into json-pipeline
Compare: https://github.com/PDAL/PDAL/compare/1f07c8d90fa0...d3f6e9418d60
More information about the pdal-commits
