[pdal-commits] [PDAL/PDAL] 72fd8f: don't try to add a deploy key if it is empty (PRs ...
    GitHub
    noreply at github.com
    Mon Jun 20 10:02:40 PDT 2016
  Branch: refs/heads/newoptions
  Home:   https://github.com/PDAL/PDAL
  Commit: 72fd8ff33dc4caf28afbeb30166f63e095ad99db
      https://github.com/PDAL/PDAL/commit/72fd8ff33dc4caf28afbeb30166f63e095ad99db
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-06-13 (Mon, 13 Jun 2016)
  Changed paths:
    M scripts/ci/add_deploy_key.sh
  Log Message:
  don't try to add a deploy key if it is empty (PRs from non-PDAL devs won't have one
  Commit: d490cb6fe73f80d8ef8b2dd49c0a03f57dd3c99d
      https://github.com/PDAL/PDAL/commit/d490cb6fe73f80d8ef8b2dd49c0a03f57dd3c99d
  Date:   2016-06-17 (Fri, 17 Jun 2016)
  Changed paths:
  Log Message:
  Merge pull request #1256 from PDAL/no-deploy-key-for-prs
  Commit: 935d3658303b4837a904c31a03433b94681bd137
      https://github.com/PDAL/PDAL/commit/935d3658303b4837a904c31a03433b94681bd137
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-06-20 (Mon, 20 Jun 2016)
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/Options.hpp
    M include/pdal/PDALUtils.hpp
    M include/pdal/Stage.hpp
    M plugins/hexbin/test/HexbinFilterTest.cpp
    M plugins/icebridge/test/IcebridgeReaderTest.cpp
    M plugins/oci/io/OciWriter.cpp
    M plugins/pcl/test/PCLBlockFilterTest.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M src/Options.cpp
    M src/PDALUtils.cpp
    M src/PipelineReaderXML.cpp
    M src/Stage.cpp
    R test/data/misc/opts2json.txt
    M test/unit/CMakeLists.txt
    M test/unit/OptionsTest.cpp
    R test/unit/PDALUtilsTest.cpp
    M test/unit/PipelineManagerTest.cpp
    M test/unit/PolygonTest.cpp
    M test/unit/filters/AdditionalMergeTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/ColorizationFilterTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    M test/unit/io/las/LasReaderTest.cpp
    M test/unit/io/qfit/QFITReaderTest.cpp
    M test/unit/io/sbet/SbetReaderTest.cpp
    M test/unit/io/sbet/SbetWriterTest.cpp
  Log Message:
  Remove lots of Options cruft.
  Commit: e5438b749072a5e41d28628cf5cddb6fd9311ca5
      https://github.com/PDAL/PDAL/commit/e5438b749072a5e41d28628cf5cddb6fd9311ca5
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into newoptions
Compare: https://github.com/PDAL/PDAL/compare/85720bf4a2ae...e5438b749072
More information about the pdal-commits
