[pdal-commits] [PDAL/PDAL] 9ef96d: Update XML to match some options parsing changes i...
GitHub
noreply at github.com
Thu Mar 3 10:05:15 PST 2016
Branch: refs/heads/json-pipeline
Home: https://github.com/PDAL/PDAL
Commit: 9ef96de9affe6dcccd78f11440dcd391b1edfad4
https://github.com/PDAL/PDAL/commit/9ef96de9affe6dcccd78f11440dcd391b1edfad4
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-03-01 (Tue, 01 Mar 2016)
Changed paths:
M test/data/nitf/las2nitf.xml.in
M test/data/nitf/write_options.xml.in
Log Message:
Update XML to match some options parsing changes in master
Commit: dbadec23cdbaf6550151059ebc8d26ca6883b43c
https://github.com/PDAL/PDAL/commit/dbadec23cdbaf6550151059ebc8d26ca6883b43c
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-03-03 (Thu, 03 Mar 2016)
Changed paths:
M CMakeLists.txt
M filters/colorization/ColorizationFilter.cpp
M include/pdal/Dimension.hpp
M include/pdal/PointLayout.hpp
M include/pdal/plang/Redirector.hpp
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/test/CpdKernelTest.cpp
M plugins/oci/test/OCITest.cpp
M plugins/python/test/PLangTest.cpp
M scripts/docker/dependencies/Dockerfile
M src/PointLayout.cpp
M src/plang/Redirector.cpp
M test/unit/filters/ColorizationFilterTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into nitf
Commit: fcd903c40f3c9aa65faa085c6511c7673096ea82
https://github.com/PDAL/PDAL/commit/fcd903c40f3c9aa65faa085c6511c7673096ea82
Changed paths:
M CMakeLists.txt
M filters/CMakeLists.txt
A filters/attribute/AttributeFilter.cpp
A filters/attribute/AttributeFilter.hpp
A filters/attribute/CMakeLists.txt
M plugins/CMakeLists.txt
R plugins/attribute/CMakeLists.txt
R plugins/attribute/filters/AttributeFilter.cpp
R plugins/attribute/filters/AttributeFilter.hpp
R plugins/attribute/test/AttributeFilterTest.cpp
M src/StageFactory.cpp
M test/unit/CMakeLists.txt
A test/unit/filters/AttributeFilterTest.cpp
Log Message:
With GDAL and GEOS being hard dependencies for PDAL, move the attribute filter out of the "plugins" category
Commit: b5cf132eff020251f64d43ceb89024897ecbeaa0
https://github.com/PDAL/PDAL/commit/b5cf132eff020251f64d43ceb89024897ecbeaa0
Changed paths:
M include/pdal/Options.hpp
M plugins/nitf/io/MetadataReader.cpp
M plugins/nitf/io/NitfWriter.cpp
M test/data/bpf/bpf2nitf.xml.in
M test/data/nitf/write_laz.xml.in
Log Message:
Fix population of AIMIDB and ACFTB fields in NITF writer.
Fix various options in pipeline files.
Improve error message on failed option conversions.
Commit: 6fb051ec3d7b2e334d1c629824c0d2a028f6e5c9
https://github.com/PDAL/PDAL/commit/6fb051ec3d7b2e334d1c629824c0d2a028f6e5c9
Changed paths:
M scripts/appveyor/config.cmd
M scripts/ci/script.sh
M scripts/docker/Dockerfile
M scripts/linux-install-scripts/pdal.sh
Log Message:
BUILD_PLUGIN_ATTRIBUTE is no longer relevant
Commit: f1d793b9dda5a3c530562203d9ca6fe4c0ae9a67
https://github.com/PDAL/PDAL/commit/f1d793b9dda5a3c530562203d9ca6fe4c0ae9a67
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M CMakeLists.txt
Log Message:
Merge pull request #1171 from PDAL/attributes-no-longer-a-plugin
Attribute filter is no longer a (shared) plugin
Commit: f8992d3b3710c3b1b0d6a4292bc175d80ffdde66
https://github.com/PDAL/PDAL/commit/f8992d3b3710c3b1b0d6a4292bc175d80ffdde66
Changed paths:
M CMakeLists.txt
Log Message:
Merge branch 'master' into json-pipeline
Commit: 7c06c87a4dd10855110f506112d88159d6dc61aa
https://github.com/PDAL/PDAL/commit/7c06c87a4dd10855110f506112d88159d6dc61aa
Changed paths:
M test/data/pipeline/bpf2nitf.json.in
M test/data/pipeline/las2nitf.json.in
M test/data/pipeline/metadata_writer.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Merge branch 'issue/1169-nitf-tests' into json-pipeline-nitf-fixed
Compare: https://github.com/PDAL/PDAL/compare/976e3025f946...7c06c87a4dd1
More information about the pdal-commits
