[pdal-commits] [PDAL/PDAL] 456083: further split GDAL error handler binding from GDAl...
GitHub
noreply at github.com
Wed Mar 23 18:31:10 PDT 2016
Branch: refs/heads/issues/1188
Home: https://github.com/PDAL/PDAL
Commit: 4560839ee1b0571f2a0ccf599f3cde43aeb052ed
https://github.com/PDAL/PDAL/commit/4560839ee1b0571f2a0ccf599f3cde43aeb052ed
Author: Howard Butler <howard at hobu.co>
Date: 2016-03-22 (Tue, 22 Mar 2016)
Changed paths:
M filters/attribute/AttributeFilter.cpp
M filters/colorization/ColorizationFilter.cpp
M filters/reprojection/ReprojectionFilter.cpp
M include/pdal/GlobalEnvironment.hpp
M io/gdal/GDALReader.cpp
M io/tindex/TIndexReader.cpp
M kernels/tindex/TIndexKernel.cpp
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/oci/io/OciReader.cpp
M plugins/oci/io/OciWriter.cpp
M src/GlobalEnvironment.cpp
Log Message:
further split GDAL error handler binding from GDAl wake up
Commit: 45128709942cde9ab215b15e5824cbf03a5a0519
https://github.com/PDAL/PDAL/commit/45128709942cde9ab215b15e5824cbf03a5a0519
Changed paths:
Log Message:
Merge pull request #1192 from PDAL/gdal-error-split
Split GDAL error handler binding from GDAL wake up
Commit: 2b0f852568436e4db356ebef5e6d3178de4e5cbf
https://github.com/PDAL/PDAL/commit/2b0f852568436e4db356ebef5e6d3178de4e5cbf
Changed paths:
M CMakeLists.txt
Log Message:
increment version to 1.2.0 in preparation for release
Commit: 3291a0279e6467b7ff17c4a1ff84cad95facfe00
https://github.com/PDAL/PDAL/commit/3291a0279e6467b7ff17c4a1ff84cad95facfe00
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-03-23 (Wed, 23 Mar 2016)
Changed paths:
M include/pdal/GDALUtils.hpp
M src/GDALUtils.cpp
Log Message:
Simplify GDAL error handling.
Commit: 7e5b52f422f184fd6d4be5846cdc0e837404acd0
https://github.com/PDAL/PDAL/commit/7e5b52f422f184fd6d4be5846cdc0e837404acd0
Changed paths:
M CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: c39c26b3dfeb6f9b9ac8885798345260af6c865d
https://github.com/PDAL/PDAL/commit/c39c26b3dfeb6f9b9ac8885798345260af6c865d
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M plugins/cpd/CMakeLists.txt
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/kernel/Cpd.hpp
M plugins/cpd/test/CpdKernelTest.cpp
Log Message:
Rewrite cpd plugin for v0.3
Commit: 6ee50f9a304bc2af4b19dcc89b5e0feabf607816
https://github.com/PDAL/PDAL/commit/6ee50f9a304bc2af4b19dcc89b5e0feabf607816
Changed paths:
M scripts/ci/script.sh
M scripts/docker/dependencies/Dockerfile
R scripts/docker/dependencies/fgt-pr-13.patch
Log Message:
Update clone-build-install for fgt and cpd
This is for the docker dependency image. This also removes armadillo
from the docker dependencies since we don't need it anymore, w00t!
Commit: 5d080edbd0726ebde227d523e7241efdee62bd9e
https://github.com/PDAL/PDAL/commit/5d080edbd0726ebde227d523e7241efdee62bd9e
Changed paths:
M doc/pipeline.rst
Log Message:
quit talking about dolls
Commit: 8c9a67005c8c873c7b994b326f01279cafe8f32d
https://github.com/PDAL/PDAL/commit/8c9a67005c8c873c7b994b326f01279cafe8f32d
Changed paths:
M doc/api/cpp/bounds.rst
M doc/api/cpp/dimension.rst
M doc/api/cpp/fileutils.rst
M doc/api/cpp/utils.rst
M doc/download.rst
M doc/stages/writers.derivative.rst
M doc/tutorial/writing-kernel.rst
M doc/tutorial/writing-writer.rst
Log Message:
doc updates
Commit: d363a503c9269e0656cc17803da4fde7bab128d8
https://github.com/PDAL/PDAL/commit/d363a503c9269e0656cc17803da4fde7bab128d8
Changed paths:
M src/GDALUtils.cpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 49bf2b3b5f664154b07260d08ceb3cd9e658a941
https://github.com/PDAL/PDAL/commit/49bf2b3b5f664154b07260d08ceb3cd9e658a941
Changed paths:
Log Message:
Merge pull request #1193 from gadomski/cpd
Update cpd to v0.3
Commit: 7d679abe330e2d3c779e2f50aedaa3267c5c8f5e
https://github.com/PDAL/PDAL/commit/7d679abe330e2d3c779e2f50aedaa3267c5c8f5e
Changed paths:
M include/pdal/StageFactory.hpp
M src/StageFactory.cpp
Log Message:
Add a function to allow specific stage destruction.
Commit: bbeb1bad3404fcf0d319cc2f4047f1d64b542f9b
https://github.com/PDAL/PDAL/commit/bbeb1bad3404fcf0d319cc2f4047f1d64b542f9b
Changed paths:
Log Message:
Move doxy to header.
Commit: 14224cb6bf3c48871fde6df39e01ed368c88e8bf
https://github.com/PDAL/PDAL/commit/14224cb6bf3c48871fde6df39e01ed368c88e8bf
Changed paths:
M doc/api/cpp/index.rst
A doc/api/cpp/stagefactory.rst
Log Message:
add StageFactory to website API docs
Commit: 993f80dedb249542dbb783704fca6bdae4c38056
https://github.com/PDAL/PDAL/commit/993f80dedb249542dbb783704fca6bdae4c38056
Changed paths:
Log Message:
Shared libs in cpd and fgt docker dependencies
cpd and fgt don't build shared libs by default, so we need to explicitly
state that we should. Also, disable tests for these two upstreams.
[skip ci]
Commit: 99fa758b9cbd51e2ac04b2974f6c401c96f935bb
https://github.com/PDAL/PDAL/commit/99fa758b9cbd51e2ac04b2974f6c401c96f935bb
Changed paths:
Log Message:
s/cpd/csd/ for Optech reader
I fat-fingered the file extension for Optech files back when I made the
plugin, and only now discovered the error. Optech files are `.csd`, not
`.cpd`.
Commit: b4ed4b0e007751e96c1e567db26370381bf32695
https://github.com/PDAL/PDAL/commit/b4ed4b0e007751e96c1e567db26370381bf32695
Author: Connor Manning <connor at hobu.co>
Changed paths:
M CMakeLists.txt
M doc/download.rst
M doc/pipeline.rst
M src/GDALUtils.cpp
Log Message:
Merge branch 'master' into issues/1188
Compare: https://github.com/PDAL/PDAL/compare/9e346e7c8fca...b4ed4b0e0077
More information about the pdal-commits
