[pdal-commits] [PDAL/PDAL] 45c1e5: remove debugging lint
GitHub
noreply at github.com
Wed Mar 30 13:48:14 PDT 2016
Branch: refs/tags/docker-master
Home: https://github.com/PDAL/PDAL
Commit: 45c1e53b0baae71522c1522e9650f14649824709
https://github.com/PDAL/PDAL/commit/45c1e53b0baae71522c1522e9650f14649824709
Author: Howard Butler <howard at hobu.co>
Date: 2016-03-14 (Mon, 14 Mar 2016)
Changed paths:
M plugins/hexbin/kernel/DensityKernel.cpp
Log Message:
Commit: 33a053476808637cbde06103f57010b5e003015c
https://github.com/PDAL/PDAL/commit/33a053476808637cbde06103f57010b5e003015c
Date: 2016-03-15 (Tue, 15 Mar 2016)
Changed paths:
M doc/apps.rst
Log Message:
typo
Commit: 6a0613afcb9bee764bc136943d77738b94327d0f
https://github.com/PDAL/PDAL/commit/6a0613afcb9bee764bc136943d77738b94327d0f
Author: Bas Couwenberg <sebastic at xs4all.nl>
Date: 2016-03-19 (Sat, 19 Mar 2016)
Changed paths:
M include/pdal/Dimension.hpp
M io/las/LasWriter.cpp
M plugins/pgpointcloud/io/PgReader.cpp
Log Message:
Fix various spelling errors.
* statment -> statement
* aquired -> acquired
* Tranformation -> Transformation
Commit: f7422066335a35ea03ab1432dfa5f44bb53295de
https://github.com/PDAL/PDAL/commit/f7422066335a35ea03ab1432dfa5f44bb53295de
Changed paths:
M cmake/unix_compiler_options.cmake
Log Message:
Use FLAGS set in the environment.
Commit: 353c10c7710cfa62406f61b109b83b54189c5310
https://github.com/PDAL/PDAL/commit/353c10c7710cfa62406f61b109b83b54189c5310
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-03-18 (Fri, 18 Mar 2016)
Changed paths:
Log Message:
Merge pull request #1181 from sebastic/spelling-errors
Commit: 3be814330f76a80ee6934f1765c3d38a4451160f
https://github.com/PDAL/PDAL/commit/3be814330f76a80ee6934f1765c3d38a4451160f
Changed paths:
Log Message:
Merge pull request #1182 from sebastic/hardening
Commit: 3ab89eb4251184a6dd0768ed6ec6da54b60b1064
https://github.com/PDAL/PDAL/commit/3ab89eb4251184a6dd0768ed6ec6da54b60b1064
Changed paths:
M plugins/sqlite/io/SQLiteCommon.hpp
Log Message:
Load mod_spatialite.so on Linux too.
The loadable SQLite3 module is named mod_spatialite since 4.2.0.
Commit: 317c379ee1237af94cb772efae43649eb2b730a8
https://github.com/PDAL/PDAL/commit/317c379ee1237af94cb772efae43649eb2b730a8
Changed paths:
M cmake/modules/FindJSONCPP.cmake
Log Message:
Add support for libjsoncpp-dev Debian package to FindJSONCPP.cmake.
Commit: 64bbc28034fbcb2c768c8e23e6900d15e9c24917
https://github.com/PDAL/PDAL/commit/64bbc28034fbcb2c768c8e23e6900d15e9c24917
Changed paths:
A cmake/spatialite.cmake
M plugins/sqlite/CMakeLists.txt
Log Message:
Use mod_spatialite for SpatiaLite >= 4.2.0.
Commit: 752d73d714ac5bb750505397bb43831679d750c6
https://github.com/PDAL/PDAL/commit/752d73d714ac5bb750505397bb43831679d750c6
Changed paths:
M python/setup.py
Log Message:
Reduce requirements for clean target.
Don't require pdal-config, and don't cythonize the extensions.
Commit: c28e058e5f8baf15d2de98635367f6fc49051475
https://github.com/PDAL/PDAL/commit/c28e058e5f8baf15d2de98635367f6fc49051475
Date: 2016-03-20 (Sun, 20 Mar 2016)
Changed paths:
M python/test/test_libpdal.py
Log Message:
Skip Python extension tests when test data is missing.
The test data is missing from the PyPi tarballs.
Commit: 2a54a066d6404814b5886ed5c64cead69222c512
https://github.com/PDAL/PDAL/commit/2a54a066d6404814b5886ed5c64cead69222c512
Changed paths:
M include/pdal/util/portable_endian.hpp
Log Message:
Add support for kFreeBSD architectures.
Treat like Linux, has GNU libc.
Commit: 26ff8511424bfde3894ebeb8d0f6aeca2f3065b0
https://github.com/PDAL/PDAL/commit/26ff8511424bfde3894ebeb8d0f6aeca2f3065b0
Changed paths:
Log Message:
Merge pull request #1184 from sebastic/jsoncpp
Commit: f3bd90512db78ebbec055c726f6e739edeff224e
https://github.com/PDAL/PDAL/commit/f3bd90512db78ebbec055c726f6e739edeff224e
Changed paths:
Log Message:
Merge pull request #1183 from sebastic/mod-spatialite
Commit: 5aa0e60087bd20aebdb6b518f51a047bc00103eb
https://github.com/PDAL/PDAL/commit/5aa0e60087bd20aebdb6b518f51a047bc00103eb
Changed paths:
M python/setup.py
Log Message:
Merge pull request #1185 from sebastic/clean-setup
Reduce requirements for setup.py clean target.
Commit: 89f89416ed8a06eb875f343e4e537bb0fc8f59f1
https://github.com/PDAL/PDAL/commit/89f89416ed8a06eb875f343e4e537bb0fc8f59f1
Changed paths:
Log Message:
Merge pull request #1186 from sebastic/skip-tests-missing-data
Commit: cc8760b633e1e36f0d01d02b651dbc6ffcbf662a
https://github.com/PDAL/PDAL/commit/cc8760b633e1e36f0d01d02b651dbc6ffcbf662a
Changed paths:
Log Message:
Merge pull request #1187 from sebastic/kfreebsd
Commit: ff97dbe1c699fad0c0bc2f08a976f3612d6b2b0d
https://github.com/PDAL/PDAL/commit/ff97dbe1c699fad0c0bc2f08a976f3612d6b2b0d
Date: 2016-03-21 (Mon, 21 Mar 2016)
Changed paths:
M src/PluginManager.cpp
Log Message:
Add support for kFreeBSD to PluginManager & SQLiteCommon.
Commit: 988eeca6f356558738803fa0b4ff89b34bf6c5ab
https://github.com/PDAL/PDAL/commit/988eeca6f356558738803fa0b4ff89b34bf6c5ab
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M doc/stages/filters.dartsample.rst
M doc/tutorial/dart-throwing.rst
Log Message:
fix dartsample references
Commit: f11ebd405d5f7bc20dcc017fa8a303b653cbfbad
https://github.com/PDAL/PDAL/commit/f11ebd405d5f7bc20dcc017fa8a303b653cbfbad
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1190 from PDAL/doc-cleanup
Commit: f8e28b6465eb05ad7773d823b32501ebff308a97
https://github.com/PDAL/PDAL/commit/f8e28b6465eb05ad7773d823b32501ebff308a97
Date: 2016-03-22 (Tue, 22 Mar 2016)
Changed paths:
Log Message:
Merge pull request #1189 from sebastic/kfreebsd2
Commit: 2e6339e9845a1134f8ccf3aec264ae437c218bd2
https://github.com/PDAL/PDAL/commit/2e6339e9845a1134f8ccf3aec264ae437c218bd2
Changed paths:
M cmake/python.cmake
M pdal_defines.h.in
Log Message:
Explicitly set PDAL_PYTHON_LIBRARY in python.cmake
Close #1174
Commit: 03370fc53fdf71b72cf6440b23ecf2a0e96b162f
https://github.com/PDAL/PDAL/commit/03370fc53fdf71b72cf6440b23ecf2a0e96b162f
Author: Connor Manning <connor at hobu.co>
Changed paths:
M io/las/LasHeader.cpp
Log Message:
Simplify a constructor.
Commit: 2b93c72f5b3846f6eb2a9dee0f767e1d41b3b36f
https://github.com/PDAL/PDAL/commit/2b93c72f5b3846f6eb2a9dee0f767e1d41b3b36f
Changed paths:
M include/pdal/GlobalEnvironment.hpp
M src/GlobalEnvironment.cpp
Log Message:
do the GDAL/GEOS error handler binding stuff right away when GlobalEnvironment wakes up. Don't do the heavy GDAL startup stuff until asked.
Commit: 4560839ee1b0571f2a0ccf599f3cde43aeb052ed
https://github.com/PDAL/PDAL/commit/4560839ee1b0571f2a0ccf599f3cde43aeb052ed
Changed paths:
M filters/attribute/AttributeFilter.cpp
M filters/colorization/ColorizationFilter.cpp
M filters/reprojection/ReprojectionFilter.cpp
M io/gdal/GDALReader.cpp
M io/tindex/TIndexReader.cpp
M kernels/tindex/TIndexKernel.cpp
M plugins/oci/io/OciReader.cpp
M plugins/oci/io/OciWriter.cpp
Log Message:
further split GDAL error handler binding from GDAl wake up
Commit: 45128709942cde9ab215b15e5824cbf03a5a0519
https://github.com/PDAL/PDAL/commit/45128709942cde9ab215b15e5824cbf03a5a0519
Changed paths:
Log Message:
Merge pull request #1192 from PDAL/gdal-error-split
Split GDAL error handler binding from GDAL wake up
Commit: 2b0f852568436e4db356ebef5e6d3178de4e5cbf
https://github.com/PDAL/PDAL/commit/2b0f852568436e4db356ebef5e6d3178de4e5cbf
Changed paths:
M CMakeLists.txt
Log Message:
increment version to 1.2.0 in preparation for release
Commit: 3291a0279e6467b7ff17c4a1ff84cad95facfe00
https://github.com/PDAL/PDAL/commit/3291a0279e6467b7ff17c4a1ff84cad95facfe00
Date: 2016-03-23 (Wed, 23 Mar 2016)
Changed paths:
M include/pdal/GDALUtils.hpp
M src/GDALUtils.cpp
Log Message:
Simplify GDAL error handling.
Commit: 7e5b52f422f184fd6d4be5846cdc0e837404acd0
https://github.com/PDAL/PDAL/commit/7e5b52f422f184fd6d4be5846cdc0e837404acd0
Changed paths:
M CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: c39c26b3dfeb6f9b9ac8885798345260af6c865d
https://github.com/PDAL/PDAL/commit/c39c26b3dfeb6f9b9ac8885798345260af6c865d
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M plugins/cpd/CMakeLists.txt
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/kernel/Cpd.hpp
M plugins/cpd/test/CpdKernelTest.cpp
Log Message:
Rewrite cpd plugin for v0.3
Commit: 6ee50f9a304bc2af4b19dcc89b5e0feabf607816
https://github.com/PDAL/PDAL/commit/6ee50f9a304bc2af4b19dcc89b5e0feabf607816
Changed paths:
M scripts/ci/script.sh
M scripts/docker/dependencies/Dockerfile
R scripts/docker/dependencies/fgt-pr-13.patch
Log Message:
Update clone-build-install for fgt and cpd
This is for the docker dependency image. This also removes armadillo
from the docker dependencies since we don't need it anymore, w00t!
Commit: 5d080edbd0726ebde227d523e7241efdee62bd9e
https://github.com/PDAL/PDAL/commit/5d080edbd0726ebde227d523e7241efdee62bd9e
Changed paths:
M doc/pipeline.rst
Log Message:
quit talking about dolls
Commit: 8c9a67005c8c873c7b994b326f01279cafe8f32d
https://github.com/PDAL/PDAL/commit/8c9a67005c8c873c7b994b326f01279cafe8f32d
Changed paths:
M doc/api/cpp/bounds.rst
M doc/api/cpp/dimension.rst
M doc/api/cpp/fileutils.rst
M doc/api/cpp/utils.rst
M doc/download.rst
M doc/stages/writers.derivative.rst
M doc/tutorial/writing-kernel.rst
M doc/tutorial/writing-writer.rst
Log Message:
doc updates
Commit: d363a503c9269e0656cc17803da4fde7bab128d8
https://github.com/PDAL/PDAL/commit/d363a503c9269e0656cc17803da4fde7bab128d8
Changed paths:
M src/GDALUtils.cpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 49bf2b3b5f664154b07260d08ceb3cd9e658a941
https://github.com/PDAL/PDAL/commit/49bf2b3b5f664154b07260d08ceb3cd9e658a941
Changed paths:
Log Message:
Merge pull request #1193 from gadomski/cpd
Update cpd to v0.3
Commit: 7d679abe330e2d3c779e2f50aedaa3267c5c8f5e
https://github.com/PDAL/PDAL/commit/7d679abe330e2d3c779e2f50aedaa3267c5c8f5e
Changed paths:
M include/pdal/StageFactory.hpp
M src/StageFactory.cpp
Log Message:
Add a function to allow specific stage destruction.
Commit: bbeb1bad3404fcf0d319cc2f4047f1d64b542f9b
https://github.com/PDAL/PDAL/commit/bbeb1bad3404fcf0d319cc2f4047f1d64b542f9b
Changed paths:
Log Message:
Move doxy to header.
Commit: 14224cb6bf3c48871fde6df39e01ed368c88e8bf
https://github.com/PDAL/PDAL/commit/14224cb6bf3c48871fde6df39e01ed368c88e8bf
Changed paths:
M doc/api/cpp/index.rst
A doc/api/cpp/stagefactory.rst
Log Message:
add StageFactory to website API docs
Commit: 993f80dedb249542dbb783704fca6bdae4c38056
https://github.com/PDAL/PDAL/commit/993f80dedb249542dbb783704fca6bdae4c38056
Changed paths:
Log Message:
Shared libs in cpd and fgt docker dependencies
cpd and fgt don't build shared libs by default, so we need to explicitly
state that we should. Also, disable tests for these two upstreams.
[skip ci]
Commit: 99fa758b9cbd51e2ac04b2974f6c401c96f935bb
https://github.com/PDAL/PDAL/commit/99fa758b9cbd51e2ac04b2974f6c401c96f935bb
Changed paths:
Log Message:
s/cpd/csd/ for Optech reader
I fat-fingered the file extension for Optech files back when I made the
plugin, and only now discovered the error. Optech files are `.csd`, not
`.cpd`.
Commit: 49e830b621660d52c64f961184aa1f1960192173
https://github.com/PDAL/PDAL/commit/49e830b621660d52c64f961184aa1f1960192173
Changed paths:
Log Message:
Remove cpd/fgt build dirs from pdal/dependencies
I forgot to clean up after myself.
[skip ci]
Commit: 23294d89524536ca8795180ba0428f0fb552785b
https://github.com/PDAL/PDAL/commit/23294d89524536ca8795180ba0428f0fb552785b
Date: 2016-03-24 (Thu, 24 Mar 2016)
Changed paths:
Log Message:
Make sure old error handlers are destroyed before new ones are created.
Commit: 59926566b9d8be510ccf7998c6907cc56c27aeed
https://github.com/PDAL/PDAL/commit/59926566b9d8be510ccf7998c6907cc56c27aeed
Changed paths:
Log Message:
Commit: 5ee2288a849f18de286c6391e2cc6aff706bfbdb
https://github.com/PDAL/PDAL/commit/5ee2288a849f18de286c6391e2cc6aff706bfbdb
Changed paths:
M doc/pipeline.rst
M doc/stages/filters.attribute.rst
M doc/stages/filters.chipper.rst
M doc/stages/filters.crop.rst
M doc/stages/filters.divider.rst
M doc/stages/filters.ferry.rst
M doc/stages/filters.greedyprojection.rst
M doc/stages/filters.gridprojection.rst
M doc/stages/filters.ground.rst
M doc/stages/filters.height.rst
M doc/stages/filters.merge.rst
M doc/stages/filters.mortonorder.rst
M doc/stages/filters.movingleastsquares.rst
M doc/stages/filters.poisson.rst
M doc/stages/filters.predicate.rst
M doc/stages/filters.programmable.rst
M doc/stages/filters.radiusoutlier.rst
M doc/stages/filters.randomize.rst
M doc/stages/filters.range.rst
M doc/stages/filters.reprojection.rst
M doc/stages/filters.splitter.rst
M doc/stages/filters.statisticaloutlier.rst
M doc/stages/filters.stats.rst
M doc/stages/filters.transformation.rst
M doc/stages/filters.voxelgrid.rst
M doc/stages/readers.bpf.rst
M doc/stages/readers.faux.rst
M doc/stages/readers.gdal.rst
M doc/stages/readers.geowave.rst
M doc/stages/readers.greyhound.rst
M doc/stages/readers.ilvis2.rst
M doc/stages/readers.las.rst
M doc/stages/readers.mrsid.rst
M doc/stages/readers.nitf.rst
M doc/stages/readers.oci.rst
M doc/stages/readers.optech.rst
M doc/stages/readers.pcd.rst
M doc/stages/readers.pgpointcloud.rst
M doc/stages/readers.ply.rst
M doc/stages/readers.qfit.rst
M doc/stages/readers.rxp.rst
M doc/stages/readers.sqlite.rst
M doc/stages/readers.text.rst
M doc/stages/readers.tindex.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.geowave.rst
M doc/stages/writers.las.rst
M doc/stages/writers.matlab.rst
M doc/stages/writers.nitf.rst
M doc/stages/writers.null.rst
M doc/stages/writers.oci.rst
M doc/stages/writers.p2g.rst
M doc/stages/writers.pcd.rst
M doc/stages/writers.pgpointcloud.rst
M doc/stages/writers.ply.rst
M doc/stages/writers.rialto.rst
M doc/stages/writers.sqlite.rst
M doc/stages/writers.text.rst
M examples/writing-kernel/MyKernel.cpp
Log Message:
XML->JSON for all stage documentation
Commit: 96a6cef11df42abb036bd53ea58179180cf16ac1
https://github.com/PDAL/PDAL/commit/96a6cef11df42abb036bd53ea58179180cf16ac1
Changed paths:
Log Message:
Fix typo.
Commit: b4627117dd61e623c491e1ad418d63b602ecc9cd
https://github.com/PDAL/PDAL/commit/b4627117dd61e623c491e1ad418d63b602ecc9cd
Changed paths:
M doc/pipeline.rst
Log Message:
Commit: 1111137bb17abb250082112e3eb72e1ce6778dc3
https://github.com/PDAL/PDAL/commit/1111137bb17abb250082112e3eb72e1ce6778dc3
Changed paths:
Log Message:
typo
Commit: 080e614bd975aa3784a463a8a0b50885bc65c726
https://github.com/PDAL/PDAL/commit/080e614bd975aa3784a463a8a0b50885bc65c726
Author: Raphael Kubo da Costa <rakuco at FreeBSD.org>
Date: 2016-03-25 (Fri, 25 Mar 2016)
Changed paths:
M src/util/CMakeLists.txt
Log Message:
Link against ${CMAKE_DL_LIBS} instead of libdl.
-dl only exists on Linux, so linking fails on other OSes like FreeBSD.
Use the portable CMAKE_DL_LIBS variable instead.
Commit: ee1ba13d6323370c06d26e726eb534b6b9624035
https://github.com/PDAL/PDAL/commit/ee1ba13d6323370c06d26e726eb534b6b9624035
Changed paths:
Log Message:
Merge pull request #1195 from rakuco/cmake-dl
Commit: 5443d3aacadd4a11301ef31e0be424b038d88007
https://github.com/PDAL/PDAL/commit/5443d3aacadd4a11301ef31e0be424b038d88007
Changed paths:
M src/Polygon.cpp
Log Message:
use GEOS' envelope for computing Polygon::bounds
Commit: 51e04198eb4cc450bf8fb48ef2d3eb420f92fdc9
https://github.com/PDAL/PDAL/commit/51e04198eb4cc450bf8fb48ef2d3eb420f92fdc9
Changed paths:
M plugins/hexbin/filters/HexBin.cpp
Log Message:
codger up a UTM-based density computation if the SRS is geographic
Commit: fc9cb3cae6035a3a3b203b5bc6b159aa8d5f49f6
https://github.com/PDAL/PDAL/commit/fc9cb3cae6035a3a3b203b5bc6b159aa8d5f49f6
Changed paths:
Log Message:
Commit: 38b0aa91665f34f79d090251a3f76210c28af91a
https://github.com/PDAL/PDAL/commit/38b0aa91665f34f79d090251a3f76210c28af91a
Changed paths:
M src/Polygon.cpp
Log Message:
better handle Multi* geometry in Polygon::bounds() computation
Commit: 7b9e6794c76c08858fd2966b0a12bcbac309c11a
https://github.com/PDAL/PDAL/commit/7b9e6794c76c08858fd2966b0a12bcbac309c11a
Changed paths:
M doc/pipeline.rst
Log Message:
no more dolls (dammit). note aboute JSON being preferred over XML
Commit: 4a8a59d0ad661f91b7d1b6a376a34c7af77e1984
https://github.com/PDAL/PDAL/commit/4a8a59d0ad661f91b7d1b6a376a34c7af77e1984
Changed paths:
Log Message:
both WKT and GeoTIFF VLRs is now a debug message instead of Error
Commit: c8a1f887d7316f76853bd67ffe5a9bb556e54b57
https://github.com/PDAL/PDAL/commit/c8a1f887d7316f76853bd67ffe5a9bb556e54b57
Changed paths:
M vendor/nanoflann-1.1.8/nanoflann.hpp
Log Message:
nanoflann: Include <cstdlib> for ::malloc().
malloc() is defined in stdlib.h, which was being included indirectly by
other on Linux. On systems such as FreeBSD, the code was just failing to
build because of the missing symbol.
Commit: cb620cc840bb52a3a080a8c0c135337c53558990
https://github.com/PDAL/PDAL/commit/cb620cc840bb52a3a080a8c0c135337c53558990
Changed paths:
Log Message:
Merge pull request #1196 from rakuco/nanoflann-malloc
Commit: bb745b0ac139106a1289df9de7c462ad7cb8e5d0
https://github.com/PDAL/PDAL/commit/bb745b0ac139106a1289df9de7c462ad7cb8e5d0
Changed paths:
Log Message:
Add lock for StageFactory::destroyStage.
Commit: ca96bbe62933c129025448149b2f5ab6818d61a9
https://github.com/PDAL/PDAL/commit/ca96bbe62933c129025448149b2f5ab6818d61a9
Changed paths:
M include/pdal/Polygon.hpp
M include/pdal/Stage.hpp
M include/pdal/util/Utils.hpp
M io/las/GeotiffSupport.cpp
M plugins/hexbin/kernel/DensityKernel.hpp
M src/GDALUtils.cpp
M src/Polygon.cpp
M src/Stage.cpp
M src/util/Utils.cpp
Log Message:
Merge changes to GDAL error handling.
Commit: 576536c809e21c88f0a9475d7e5229cbffe950dd
https://github.com/PDAL/PDAL/commit/576536c809e21c88f0a9475d7e5229cbffe950dd
Changed paths:
Log Message:
Update readers.geowave.rst
missing comma
Commit: cbc73324c977304ca40de3e0bc9c5beb63047daf
https://github.com/PDAL/PDAL/commit/cbc73324c977304ca40de3e0bc9c5beb63047daf
Date: 2016-03-26 (Sat, 26 Mar 2016)
Changed paths:
M RELEASENOTES.txt
Log Message:
Update release notes.
Commit: 78481eee4740df0657342d8288bd7e0422edfce0
https://github.com/PDAL/PDAL/commit/78481eee4740df0657342d8288bd7e0422edfce0
Changed paths:
Log Message:
Commit: 3c7e9979ea67a56e8d29f7404e1e8153dc93c6bb
https://github.com/PDAL/PDAL/commit/3c7e9979ea67a56e8d29f7404e1e8153dc93c6bb
Date: 2016-03-28 (Mon, 28 Mar 2016)
Changed paths:
Log Message:
portable_endian: Remove wrong byte-order macro definitions for the BSDs.
Only OpenBSD has {b,l}etoh{16,32,64} in addition to {b,l}e{16,32,64}toh,
so the macro definitions were breaking the build on all those OSes.
Commit: 5a0b123bfd7a843b18318ec2e95ce725c5f1f386
https://github.com/PDAL/PDAL/commit/5a0b123bfd7a843b18318ec2e95ce725c5f1f386
Changed paths:
Log Message:
utils: Include sys/wait.h for the WIFEXITED and WEXITSTATUS macros.
These two macros are defined in sys/wait.h, which was being included
indirectly by other headers. This did not work on systems such as
FreeBSD, so explicitly include all headers that we actually need.
Commit: 7613440c736338fce251a329c5d5de9a3fd93a38
https://github.com/PDAL/PDAL/commit/7613440c736338fce251a329c5d5de9a3fd93a38
Changed paths:
M RELEASENOTES.txt
Log Message:
Fix typos.
Commit: acf54cf9b9b549a612dfc73d0fe2df9c57258ed1
https://github.com/PDAL/PDAL/commit/acf54cf9b9b549a612dfc73d0fe2df9c57258ed1
Changed paths:
M kernels/info/InfoKernel.cpp
Log Message:
Fix #1201 -- info on pipeline segfault
Commit: 52c9b6195b1cfe56b8f916c496efe85f8eb5a6dd
https://github.com/PDAL/PDAL/commit/52c9b6195b1cfe56b8f916c496efe85f8eb5a6dd
Changed paths:
M RELEASENOTES.txt
Log Message:
Commit: e4e3f3f3e7e6bff7d30c76335ee76d6f7af1a4a2
https://github.com/PDAL/PDAL/commit/e4e3f3f3e7e6bff7d30c76335ee76d6f7af1a4a2
Changed paths:
Log Message:
Merge pull request #1199 from rakuco/portable_endian-bsd-names
Commit: ae1d75a609a1d766a7651b8ade467b3f823a1ad2
https://github.com/PDAL/PDAL/commit/ae1d75a609a1d766a7651b8ade467b3f823a1ad2
Changed paths:
Log Message:
Merge pull request #1200 from rakuco/wait-macros-header
Commit: 4eabffd77041705fa5431ebed60a5358c3eda256
https://github.com/PDAL/PDAL/commit/4eabffd77041705fa5431ebed60a5358c3eda256
Changed paths:
R include/pdal/GlobalEnvironment.hpp
R src/GlobalEnvironment.cpp
Log Message:
Remove GlobalEnvironment.
Simplify GEOS error handling.
Commit: 48b1b999bdec51ace3783e7bc4e6a2aee4af9a5d
https://github.com/PDAL/PDAL/commit/48b1b999bdec51ace3783e7bc4e6a2aee4af9a5d
Changed paths:
M include/pdal/GEOSUtils.hpp
M io/tindex/TIndexReader.hpp
M plugins/nitf/io/NitfWriter.cpp
M src/CMakeLists.txt
M src/GDALUtils.cpp
M src/GEOSUtils.cpp
M src/Kernel.cpp
M src/Polygon.cpp
M src/Stage.cpp
Log Message:
Rest of previous commit.
Commit: 19e064793b25ce3f2b3107b542a4570a3b40539a
https://github.com/PDAL/PDAL/commit/19e064793b25ce3f2b3107b542a4570a3b40539a
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into geoserror
Commit: 6f45579dbaaa186b4d14f95bae2d4574eb4e8218
https://github.com/PDAL/PDAL/commit/6f45579dbaaa186b4d14f95bae2d4574eb4e8218
Changed paths:
M src/GDALUtils.cpp
Log Message:
Add header.
Commit: 887b47bdebb5a75e823e641108984c3f5525161e
https://github.com/PDAL/PDAL/commit/887b47bdebb5a75e823e641108984c3f5525161e
Changed paths:
M src/GEOSUtils.cpp
Log Message:
Add header.
Commit: 72ef4dbbfb769f5f9ed2e5ef8a9fbe0608c2fc28
https://github.com/PDAL/PDAL/commit/72ef4dbbfb769f5f9ed2e5ef8a9fbe0608c2fc28
Changed paths:
Log Message:
Add PDAL_DLL to register/unregisterDrivers().
Commit: d1365b727701763bb3496ea9f7c8e98bca044142
https://github.com/PDAL/PDAL/commit/d1365b727701763bb3496ea9f7c8e98bca044142
Changed paths:
M cmake/examples/hobu-config.sh
Log Message:
turn on CPD in my example config
Commit: d5e79e7f3d76333905bf798bf272cc925ed30007
https://github.com/PDAL/PDAL/commit/d5e79e7f3d76333905bf798bf272cc925ed30007
Changed paths:
M src/GDALUtils.cpp
M src/GEOSUtils.cpp
M src/Kernel.cpp
M src/Polygon.cpp
M src/Stage.cpp
Log Message:
Merge branch 'geoserror'
Commit: b3d63d95587de110a5be121e1a6113b37e7b434a
https://github.com/PDAL/PDAL/commit/b3d63d95587de110a5be121e1a6113b37e7b434a
Date: 2016-03-29 (Tue, 29 Mar 2016)
Changed paths:
Log Message:
Add library dependency as well as symbol export for libpdal_util library
with respect to libpdalcpp library.
Close #1202
Commit: 16130eb77e7c974d98cdb60d9b6522d155023873
https://github.com/PDAL/PDAL/commit/16130eb77e7c974d98cdb60d9b6522d155023873
Date: 2016-03-30 (Wed, 30 Mar 2016)
Changed paths:
M src/GDALUtils.cpp
Log Message:
Change GDAL error handling to global.
Compare: https://github.com/PDAL/PDAL/compare/59f1cf4b6545...16130eb77e7c
More information about the pdal-commits
