[pdal-commits] [PDAL/PDAL] 5469dd: Uncomment header files.
GitHub
noreply at github.com
Tue May 10 10:38:25 PDT 2016
Branch: refs/heads/nolaszip
Home: https://github.com/PDAL/PDAL
Commit: 5469ddbb21306b890ecc191e88c21aec5e9e5aeb
https://github.com/PDAL/PDAL/commit/5469ddbb21306b890ecc191e88c21aec5e9e5aeb
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-05-09 (Mon, 09 May 2016)
Changed paths:
M src/CMakeLists.txt
Log Message:
Remove Dimension.hpp dependency.
Commit: 50991590ee7a4597d3070359b3ab61e92bcd638a
https://github.com/PDAL/PDAL/commit/50991590ee7a4597d3070359b3ab61e92bcd638a
Author: Howard Butler <howard at hobu.co>
Changed paths:
M filters/stats/StatsFilter.cpp
M filters/stats/StatsFilter.hpp
Log Message:
add skewness, kurtosis, stddev, and variance to filters.stats output
Commit: dffb04c82cdefbcbb56307803590feedeabfa28d
https://github.com/PDAL/PDAL/commit/dffb04c82cdefbcbb56307803590feedeabfa28d
Changed paths:
Log Message:
Fix #1240, misleading error with no points
Commit: 0a0e5d333ac679c5cc8858c306a3e93eca955e48
https://github.com/PDAL/PDAL/commit/0a0e5d333ac679c5cc8858c306a3e93eca955e48
Changed paths:
Log Message:
make #1240 more clear
Commit: 1cea310de57df8fb2c6b816df7ebce7bc9985799
https://github.com/PDAL/PDAL/commit/1cea310de57df8fb2c6b816df7ebce7bc9985799
Changed paths:
Log Message:
Merge pull request #1241 from PDAL/no-points-ogr-error
Commit: cf28eb90ecfa0e2e80b118e23dce48e98c2313bf
https://github.com/PDAL/PDAL/commit/cf28eb90ecfa0e2e80b118e23dce48e98c2313bf
Changed paths:
Log Message:
Merge pull request #1242 from PDAL/more-stats
Commit: d71a522691cfe08e0acd42296a104a83c3603ee9
https://github.com/PDAL/PDAL/commit/d71a522691cfe08e0acd42296a104a83c3603ee9
Date: 2016-05-10 (Tue, 10 May 2016)
Changed paths:
M scripts/docker/dependencies/Dockerfile
Log Message:
compile PCL with c++11 and use new lazperf git location
Commit: 9b1ab443f35140e8b25c7c00116f6d308e89c149
https://github.com/PDAL/PDAL/commit/9b1ab443f35140e8b25c7c00116f6d308e89c149
Changed paths:
M scripts/appveyor/config.cmd
Log Message:
wag at lazperf on windows
Commit: bbb4e33ff3520b869b852646f317cf1e9efed0c8
https://github.com/PDAL/PDAL/commit/bbb4e33ff3520b869b852646f317cf1e9efed0c8
Changed paths:
Log Message:
turn on verbose makefile
Commit: e6334dee381e0bc5cbce4ae107ad17a49265d013
https://github.com/PDAL/PDAL/commit/e6334dee381e0bc5cbce4ae107ad17a49265d013
Changed paths:
Log Message:
make/install lazperf and point at it
Commit: 40941ce2bd61edebe8f99567f39169a4cb1c8e6a
https://github.com/PDAL/PDAL/commit/40941ce2bd61edebe8f99567f39169a4cb1c8e6a
Changed paths:
Log Message:
another swing at lazperf build
Commit: 60eda66ec43c4ad3b06a82f69dccf7c19bdcd470
https://github.com/PDAL/PDAL/commit/60eda66ec43c4ad3b06a82f69dccf7c19bdcd470
Changed paths:
Log Message:
Merge branch 'windows-lazperf' into nolaszip
Compare: https://github.com/PDAL/PDAL/compare/5b872cb1a002...60eda66ec43c
More information about the pdal-commits
