[pdal-commits] [PDAL/PDAL] 036412: Merge branch 'master' of github.com:PDAL/PDAL
GitHub noreply at github.com
Fri Nov 11 12:10:22 PST 2016
  Branch: refs/heads/hobu-windows-updates
  Home:   https://github.com/PDAL/PDAL
  Commit: 036412ea3a5f5b89721948cc2f29a01a366302a2
      https://github.com/PDAL/PDAL/commit/036412ea3a5f5b89721948cc2f29a01a366302a2
  Author: Howard Butler <howard at hobu.co>
  Date:   2016-11-09 (Wed, 09 Nov 2016)
  Changed paths:
    M include/pdal/util/IStream.hpp
    M io/las/VariableLengthRecord.cpp
  Log Message:
  Commit: 53236dca087ed998abbc8e51e4fdee595e4a9e58
      https://github.com/PDAL/PDAL/commit/53236dca087ed998abbc8e51e4fdee595e4a9e58
  Changed paths:
    M doc/apps/translate.rst
    M filters/pmf/PMFFilter.cpp
    M filters/pmf/PMFFilter.hpp
    M filters/stats/StatsFilter.cpp
    M filters/stats/StatsFilter.hpp
    A include/pdal/PipelineExecutor.hpp
    M kernels/pipeline/PipelineKernel.cpp
    M kernels/translate/TranslateKernel.cpp
    M kernels/translate/TranslateKernel.hpp
    M python/README.rst
    M python/VERSION.txt
    R python/pdal/Pipeline.cpp
    R python/pdal/Pipeline.hpp
    A python/pdal/PyPipeline.cpp
    A python/pdal/PyPipeline.hpp
    M python/pdal/__init__.py
    M python/pdal/libpdalpython.pyx
    A python/pdal/pipeline.py
    R python/pdal/pipeline_xml.py
    M python/setup.py
    M python/test/__init__.py
    R python/test/test_libpdal.py
    M python/test/test_pipeline.py
    M src/CMakeLists.txt
    M src/EigenUtils.cpp
    A src/PipelineExecutor.cpp
    M src/plang/Environment.cpp
    M src/util/FileUtils.cpp
    M test/unit/CMakeLists.txt
    A test/unit/apps/TranslateTest.cpp
    M test/unit/filters/StatsFilterTest.cpp
  Log Message:
  Commit: f72a51cd514734980e79c0c2f0f524a65348c382
      https://github.com/PDAL/PDAL/commit/f72a51cd514734980e79c0c2f0f524a65348c382
  Date:   2016-11-10 (Thu, 10 Nov 2016)
  Changed paths:
    M include/pdal/FlexWriter.hpp
    M include/pdal/Writer.hpp
    M io/bpf/BpfWriter.cpp
    M io/bpf/BpfWriter.hpp
    M io/derivative/DerivativeWriter.cpp
    M io/derivative/DerivativeWriter.hpp
    M io/gdal/GDALWriter.cpp
    M io/gdal/GDALWriter.hpp
    M io/las/LasWriter.cpp
    M io/ply/PlyWriter.cpp
    M io/ply/PlyWriter.hpp
    M io/sbet/SbetWriter.cpp
    M io/sbet/SbetWriter.hpp
    M io/text/TextWriter.cpp
    M plugins/matlab/io/MatlabWriter.cpp
    M plugins/matlab/io/MatlabWriter.hpp
    M plugins/mrsid/io/MrsidReader.cpp
    M plugins/mrsid/io/MrsidReader.hpp
    M plugins/p2g/io/P2gWriter.cpp
    M plugins/pcl/io/PcdWriter.cpp
    M plugins/pcl/io/PcdWriter.hpp
    M src/Writer.cpp
  Log Message:
  Commit: 5170d8fb37ee98c092025af36fcfb53cab406802
      https://github.com/PDAL/PDAL/commit/5170d8fb37ee98c092025af36fcfb53cab406802
  Changed paths:
    M test/unit/apps/TranslateTest.cpp
  Log Message:
  try pulling in string_literals namespace for MSVC
  Commit: 34410198f996c4d96862cb3133e81645024c0c70
      https://github.com/PDAL/PDAL/commit/34410198f996c4d96862cb3133e81645024c0c70
  Changed paths:
  Log Message:
  remove string literal because MSVC
  Commit: 6f609d7302989ee824fea30c1362468bb288ea8b
      https://github.com/PDAL/PDAL/commit/6f609d7302989ee824fea30c1362468bb288ea8b
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    A doc/stages/filters.radialdensity.rst
    M filters/CMakeLists.txt
    A filters/radialdensity/CMakeLists.txt
    A filters/radialdensity/RadialDensityFilter.cpp
    A filters/radialdensity/RadialDensityFilter.hpp
    M src/StageFactory.cpp
  Log Message:
  Add a Radial Density filter (#1373)
This filter creates a new dimension called RadialDensity that records the
density of points within a sphere of specified radius and centered at the
current point.
  Commit: e5bdb273e157b9f4dabd6e513b03b44370d2d8c3
      https://github.com/PDAL/PDAL/commit/e5bdb273e157b9f4dabd6e513b03b44370d2d8c3
  Changed paths:
    A doc/stages/filters.kdistance.rst
    A filters/kdistance/CMakeLists.txt
    A filters/kdistance/KDistanceFilter.cpp
    A filters/kdistance/KDistanceFilter.hpp
  Log Message:
  Add a K-Distance filter (#1374)
This filter creates a new dimension called KDistance that records the Euclidean
distance from the current point to its k-th nearest neighbor.
  Commit: 035ebef17e43c4297f534ab40c941ed912b369d3
      https://github.com/PDAL/PDAL/commit/035ebef17e43c4297f534ab40c941ed912b369d3
  Changed paths:
    M include/pdal/KDIndex.hpp
    M test/unit/KDIndexTest.cpp
  Log Message:
  Add KDIndex overloads for specifying query point (#1377)
* PointId from the indexed PointView
* PointRef
  Commit: d9c270003372317cbd4a39e1930224467db5cf86
      https://github.com/PDAL/PDAL/commit/d9c270003372317cbd4a39e1930224467db5cf86
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2016-11-11 (Fri, 11 Nov 2016)
  Changed paths:
    M test/unit/io/gdal/GDALWriterTest.cpp
  Log Message:
  Use proper function to determine dimension existence.
Close #1379
  Commit: 2f57c0cf1703af51498f9dae71c9a70128c4c93a
      https://github.com/PDAL/PDAL/commit/2f57c0cf1703af51498f9dae71c9a70128c4c93a
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: ddc6345242060c804bf8d3741950cd0a7d49ef72
      https://github.com/PDAL/PDAL/commit/ddc6345242060c804bf8d3741950cd0a7d49ef72
  Changed paths:
    M cmake/gdal.cmake
    M cmake/macros.cmake
  Log Message:
  Explicitly accept library type in PDAL_ADD_FREE_LIBRARY macro.
  Commit: 68e7cf26cafe4c88cbd0b835fe025242afa0a890
      https://github.com/PDAL/PDAL/commit/68e7cf26cafe4c88cbd0b835fe025242afa0a890
  Changed paths:
    M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M test/unit/io/optech/OptechReaderTest.cpp
  Log Message:
  comparison warnings
  Commit: 75266de8a107b73ddb85cc7714b2792b712d4197
      https://github.com/PDAL/PDAL/commit/75266de8a107b73ddb85cc7714b2792b712d4197
  Changed paths:
    M cmake/examples/hobu-windows.bat
  Log Message:
  I build project files now
  Commit: 0c4f9e0224f86ea03033a15d7c9ef158944bac8a
      https://github.com/PDAL/PDAL/commit/0c4f9e0224f86ea03033a15d7c9ef158944bac8a
  Changed paths:
    M src/plang/Invocation.cpp
  Log Message:
  silence PyTuple_GetItem argument warning
  Commit: 1b7703d1f1e87ae5d94e64894d0b1a196c36cd3d
      https://github.com/PDAL/PDAL/commit/1b7703d1f1e87ae5d94e64894d0b1a196c36cd3d
  Changed paths:
    M cmake/gdal.cmake
  Log Message:
  Merge remote-tracking branch 'refs/remotes/origin/master' into hobu-windows-updates
Compare: https://github.com/PDAL/PDAL/compare/c1eeb16f2e23...1b7703d1f1e8
More information about the pdal-commits mailing list
