[pdal-commits] [PDAL/PDAL] d9d7d0: Add kernel to compute Hausdorff distance between t...
GitHub
noreply at github.com
Wed Nov 23 10:24:03 PST 2016
Branch: refs/heads/issues/1315-json-drivers
Home: https://github.com/PDAL/PDAL
Commit: d9d7d0779771ad297f9875ad51dbf99b0ea762e0
https://github.com/PDAL/PDAL/commit/d9d7d0779771ad297f9875ad51dbf99b0ea762e0
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2016-11-22 (Tue, 22 Nov 2016)
Changed paths:
M include/pdal/PDALUtils.hpp
M kernels/CMakeLists.txt
A kernels/hausdorff/CMakeLists.txt
A kernels/hausdorff/HausdorffKernel.cpp
A kernels/hausdorff/HausdorffKernel.hpp
M src/KernelFactory.cpp
M src/PDALUtils.cpp
M test/unit/CMakeLists.txt
A test/unit/apps/HausdorffTest.cpp
Log Message:
Add kernel to compute Hausdorff distance between two point clouds
Commit: eda61675f1636f95af2d4b122357f9a1c430ba76
https://github.com/PDAL/PDAL/commit/eda61675f1636f95af2d4b122357f9a1c430ba76
Changed paths:
A doc/stages/filters.computerange.rst
M filters/CMakeLists.txt
A filters/computerange/CMakeLists.txt
A filters/computerange/ComputeRangeFilter.cpp
A filters/computerange/ComputeRangeFilter.hpp
M src/StageFactory.cpp
A test/unit/filters/ComputeRangeFilterTest.cpp
Log Message:
Add filter to compute ranges from L1 Geiger-mode data
Commit: 45f903fc033bca245a9ce45b4ca743100f2ba679
https://github.com/PDAL/PDAL/commit/45f903fc033bca245a9ce45b4ca743100f2ba679
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M src/PDALUtils.cpp
Log Message:
Merge pull request #1381 from PDAL/hausdorff-kernel
Commit: b5edd2621236a69e65a9362334f108f2a1d8fc5c
https://github.com/PDAL/PDAL/commit/b5edd2621236a69e65a9362334f108f2a1d8fc5c
Changed paths:
Log Message:
Merge pull request #1390 from PDAL/new-compute-range
Commit: cb887c2b51e1d47f6e5238ac47f20137f8757f66
https://github.com/PDAL/PDAL/commit/cb887c2b51e1d47f6e5238ac47f20137f8757f66
Changed paths:
M filters/mongus/MongusFilter.cpp
M filters/mongus/MongusFilter.hpp
M filters/smrf/SMRFilter.cpp
M filters/smrf/SMRFilter.hpp
M include/pdal/EigenUtils.hpp
M src/EigenUtils.cpp
Log Message:
Add EigenUtils functions
* Write an Eigen Matrix as a GDAL raster (and use GDALUtils to do it)
* Compute extended local minimum (Chen, 2012) as alternative to minimum
elevation, which is sensitive to low outliers
Commit: 687287d2813b90b47c50480bd3b2e7998e6c3118
https://github.com/PDAL/PDAL/commit/687287d2813b90b47c50480bd3b2e7998e6c3118
Author: lbartoletti <lbartoletti at users.noreply.github.com>
Changed paths:
M src/PluginManager.cpp
Log Message:
Update PluginManager.cpp (#1400)
Use real name for FreeBSD. Add DragonFly too.
Commit: 99a24312d6037f5eda17d4d6f91fc4aaaa203b82
https://github.com/PDAL/PDAL/commit/99a24312d6037f5eda17d4d6f91fc4aaaa203b82
Date: 2016-11-23 (Wed, 23 Nov 2016)
Changed paths:
Log Message:
Merge pull request #1393 from PDAL/extended-local-minimum
Commit: b7f1c42f9f7e148481faa1578faee5779b518b5d
https://github.com/PDAL/PDAL/commit/b7f1c42f9f7e148481faa1578faee5779b518b5d
Changed paths:
M doc/apps/density.rst
A doc/apps/hausdorff.rst
A doc/apps/sort.rst
M kernels/delta/DeltaKernel.cpp
M kernels/diff/DiffKernel.cpp
M kernels/hausdorff/HausdorffKernel.cpp
M kernels/info/InfoKernel.cpp
M kernels/merge/MergeKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/random/RandomKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/split/SplitKernel.cpp
M kernels/tindex/TIndexKernel.cpp
M kernels/translate/TranslateKernel.cpp
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/ViewKernel.cpp
Log Message:
Documentation updates
* Add Hausdorff and Sort kernel documentation
* Update all kernel links to point to the real URLs
* Add note that density kernel only comes with Hexer
Commit: 44075bce4a7d6c36ac0e38636568d66d114cb785
https://github.com/PDAL/PDAL/commit/44075bce4a7d6c36ac0e38636568d66d114cb785
Changed paths:
A doc/apps/sort.rst
Log Message:
Merge pull request #1403 from PDAL/kernel-links-add-hausdorff
Commit: 804a71e7defe09e75e3711dc2dc7b315956fee81
https://github.com/PDAL/PDAL/commit/804a71e7defe09e75e3711dc2dc7b315956fee81
Author: Howard Butler <howard at hobu.co>
Changed paths:
M apps/pdal.cpp
Log Message:
use stage name(s) as keys
Commit: 5fc96f8dd1d57edfe0cc7148f12287c3da436200
https://github.com/PDAL/PDAL/commit/5fc96f8dd1d57edfe0cc7148f12287c3da436200
Changed paths:
A doc/apps/sort.rst
M src/PDALUtils.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into issues/1315-json-drivers
Compare: https://github.com/PDAL/PDAL/compare/cd6dd0acd4ca...5fc96f8dd1d5
More information about the pdal-commits
