[pdal-commits] [PDAL/PDAL] f533d5: support writing density data into an existing OGR ...
GitHub
noreply at github.com
Mon Nov 28 16:09:03 PST 2016
Branch: refs/heads/include-dirs
Home: https://github.com/PDAL/PDAL
Commit: f533d5e2e7d4e6a872fae1622317a993f95b0404
https://github.com/PDAL/PDAL/commit/f533d5e2e7d4e6a872fae1622317a993f95b0404
Author: Howard Butler <howard at hobu.co>
Date: 2016-11-19 (Sat, 19 Nov 2016)
Changed paths:
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/hexbin/kernel/DensityKernel.hpp
M plugins/hexbin/kernel/OGR.cpp
M plugins/hexbin/kernel/OGR.hpp
Log Message:
support writing density data into an existing OGR datasource/layer (#1396)
Commit: 73ad258fe6ced1347723386bb8c43149a7270d1c
https://github.com/PDAL/PDAL/commit/73ad258fe6ced1347723386bb8c43149a7270d1c
Changed paths:
M plugins/mrsid/CMakeLists.txt
Log Message:
include directory update for mrsid driver
Commit: 14e3f7f6f06603aa1b43462dd6f3ad564dc4497c
https://github.com/PDAL/PDAL/commit/14e3f7f6f06603aa1b43462dd6f3ad564dc4497c
Author: Kristian Evers <kristianevers at gmail.com>
Date: 2016-11-22 (Tue, 22 Nov 2016)
Changed paths:
M .gitignore
M apps/CMakeLists.txt
A apps/pdal-config-bat.in
M python/setup.py
Log Message:
Experimental python support on windows. Introduces pdal-config for windows and modifies the setup script for the python module. (#1397)
Commit: 41c9746788b0565588a3219cf19e791a81f2d685
https://github.com/PDAL/PDAL/commit/41c9746788b0565588a3219cf19e791a81f2d685
Changed paths:
M src/XMLSchema.cpp
Log Message:
remove boost::property_tree from XMLSchema #1350 (#1399)
* remove boost::property_tree from XMLSchema #1350
Commit: d9d7d0779771ad297f9875ad51dbf99b0ea762e0
https://github.com/PDAL/PDAL/commit/d9d7d0779771ad297f9875ad51dbf99b0ea762e0
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M include/pdal/PDALUtils.hpp
M kernels/CMakeLists.txt
A kernels/hausdorff/CMakeLists.txt
A kernels/hausdorff/HausdorffKernel.cpp
A kernels/hausdorff/HausdorffKernel.hpp
M src/KernelFactory.cpp
M src/PDALUtils.cpp
M test/unit/CMakeLists.txt
A test/unit/apps/HausdorffTest.cpp
Log Message:
Add kernel to compute Hausdorff distance between two point clouds
Commit: eda61675f1636f95af2d4b122357f9a1c430ba76
https://github.com/PDAL/PDAL/commit/eda61675f1636f95af2d4b122357f9a1c430ba76
Changed paths:
A doc/stages/filters.computerange.rst
M filters/CMakeLists.txt
A filters/computerange/CMakeLists.txt
A filters/computerange/ComputeRangeFilter.cpp
A filters/computerange/ComputeRangeFilter.hpp
M src/StageFactory.cpp
A test/unit/filters/ComputeRangeFilterTest.cpp
Log Message:
Add filter to compute ranges from L1 Geiger-mode data
Commit: 45f903fc033bca245a9ce45b4ca743100f2ba679
https://github.com/PDAL/PDAL/commit/45f903fc033bca245a9ce45b4ca743100f2ba679
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M src/PDALUtils.cpp
Log Message:
Merge pull request #1381 from PDAL/hausdorff-kernel
Commit: b5edd2621236a69e65a9362334f108f2a1d8fc5c
https://github.com/PDAL/PDAL/commit/b5edd2621236a69e65a9362334f108f2a1d8fc5c
Changed paths:
Log Message:
Merge pull request #1390 from PDAL/new-compute-range
Commit: cb887c2b51e1d47f6e5238ac47f20137f8757f66
https://github.com/PDAL/PDAL/commit/cb887c2b51e1d47f6e5238ac47f20137f8757f66
Changed paths:
M filters/mongus/MongusFilter.cpp
M filters/mongus/MongusFilter.hpp
M filters/smrf/SMRFilter.cpp
M filters/smrf/SMRFilter.hpp
M include/pdal/EigenUtils.hpp
M src/EigenUtils.cpp
Log Message:
Add EigenUtils functions
* Write an Eigen Matrix as a GDAL raster (and use GDALUtils to do it)
* Compute extended local minimum (Chen, 2012) as alternative to minimum
elevation, which is sensitive to low outliers
Commit: 687287d2813b90b47c50480bd3b2e7998e6c3118
https://github.com/PDAL/PDAL/commit/687287d2813b90b47c50480bd3b2e7998e6c3118
Author: lbartoletti <lbartoletti at users.noreply.github.com>
Changed paths:
M src/PluginManager.cpp
Log Message:
Update PluginManager.cpp (#1400)
Use real name for FreeBSD. Add DragonFly too.
Commit: 99a24312d6037f5eda17d4d6f91fc4aaaa203b82
https://github.com/PDAL/PDAL/commit/99a24312d6037f5eda17d4d6f91fc4aaaa203b82
Date: 2016-11-23 (Wed, 23 Nov 2016)
Changed paths:
Log Message:
Merge pull request #1393 from PDAL/extended-local-minimum
Commit: ce2f2da7ed094fc61be1fe6550f8cb6152eada73
https://github.com/PDAL/PDAL/commit/ce2f2da7ed094fc61be1fe6550f8cb6152eada73
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M CMakeLists.txt
M cmake/laszip.cmake
M cmake/macros.cmake
A cmake/rply.cmake
M cmake/win32_compiler_options.cmake
A filters/ApproximateCoplanarFilter.cpp
A filters/ApproximateCoplanarFilter.hpp
A filters/AttributeFilter.cpp
A filters/AttributeFilter.hpp
R filters/CMakeLists.txt
A filters/ChipperFilter.cpp
A filters/ChipperFilter.hpp
A filters/ColorInterpRamps.hpp
A filters/ColorinterpFilter.cpp
A filters/ColorinterpFilter.hpp
A filters/ColorizationFilter.cpp
A filters/ColorizationFilter.hpp
A filters/CropFilter.cpp
A filters/CropFilter.hpp
A filters/DecimationFilter.cpp
A filters/DecimationFilter.hpp
A filters/DividerFilter.cpp
A filters/DividerFilter.hpp
A filters/EigenvaluesFilter.cpp
A filters/EigenvaluesFilter.hpp
A filters/EstimateRankFilter.cpp
A filters/EstimateRankFilter.hpp
A filters/FerryFilter.cpp
A filters/FerryFilter.hpp
A filters/HAGFilter.cpp
A filters/HAGFilter.hpp
A filters/IQRFilter.cpp
A filters/IQRFilter.hpp
A filters/KDistanceFilter.cpp
A filters/KDistanceFilter.hpp
A filters/LOFFilter.cpp
A filters/LOFFilter.hpp
A filters/MADFilter.cpp
A filters/MADFilter.hpp
A filters/MergeFilter.cpp
A filters/MergeFilter.hpp
A filters/MongusFilter.cpp
A filters/MongusFilter.hpp
A filters/MortonOrderFilter.cpp
A filters/MortonOrderFilter.hpp
A filters/NormalFilter.cpp
A filters/NormalFilter.hpp
A filters/OutlierFilter.cpp
A filters/OutlierFilter.hpp
A filters/PMFFilter.cpp
A filters/PMFFilter.hpp
A filters/RadialDensityFilter.cpp
A filters/RadialDensityFilter.hpp
A filters/RandomizeFilter.cpp
A filters/RandomizeFilter.hpp
A filters/RangeFilter.cpp
A filters/RangeFilter.hpp
A filters/ReprojectionFilter.cpp
A filters/ReprojectionFilter.hpp
A filters/SMRFilter.cpp
A filters/SMRFilter.hpp
A filters/SampleFilter.cpp
A filters/SampleFilter.hpp
A filters/SortFilter.cpp
A filters/SortFilter.hpp
A filters/SplitterFilter.cpp
A filters/SplitterFilter.hpp
A filters/StatsFilter.cpp
A filters/StatsFilter.hpp
A filters/StreamCallbackFilter.cpp
A filters/StreamCallbackFilter.hpp
A filters/TransformationFilter.cpp
A filters/TransformationFilter.hpp
R filters/approximatecoplanar/ApproximateCoplanarFilter.cpp
R filters/approximatecoplanar/ApproximateCoplanarFilter.hpp
R filters/approximatecoplanar/CMakeLists.txt
R filters/attribute/AttributeFilter.cpp
R filters/attribute/AttributeFilter.hpp
R filters/attribute/CMakeLists.txt
R filters/chipper/CMakeLists.txt
R filters/chipper/ChipperFilter.cpp
R filters/chipper/ChipperFilter.hpp
R filters/colorinterp/CMakeLists.txt
R filters/colorinterp/ColorinterpFilter.cpp
R filters/colorinterp/ColorinterpFilter.hpp
R filters/colorinterp/color-ramps.hpp
R filters/colorization/CMakeLists.txt
R filters/colorization/ColorizationFilter.cpp
R filters/colorization/ColorizationFilter.hpp
R filters/crop/CMakeLists.txt
R filters/crop/CropFilter.cpp
R filters/crop/CropFilter.hpp
R filters/decimation/CMakeLists.txt
R filters/decimation/DecimationFilter.cpp
R filters/decimation/DecimationFilter.hpp
R filters/divider/CMakeLists.txt
R filters/divider/DividerFilter.cpp
R filters/divider/DividerFilter.hpp
R filters/eigenvalues/CMakeLists.txt
R filters/eigenvalues/EigenvaluesFilter.cpp
R filters/eigenvalues/EigenvaluesFilter.hpp
R filters/estimaterank/CMakeLists.txt
R filters/estimaterank/EstimateRankFilter.cpp
R filters/estimaterank/EstimateRankFilter.hpp
R filters/ferry/CMakeLists.txt
R filters/ferry/FerryFilter.cpp
R filters/ferry/FerryFilter.hpp
R filters/hag/CMakeLists.txt
R filters/hag/HAGFilter.cpp
R filters/hag/HAGFilter.hpp
R filters/iqr/CMakeLists.txt
R filters/iqr/IQRFilter.cpp
R filters/iqr/IQRFilter.hpp
R filters/kdistance/CMakeLists.txt
R filters/kdistance/KDistanceFilter.cpp
R filters/kdistance/KDistanceFilter.hpp
R filters/lof/CMakeLists.txt
R filters/lof/LOFFilter.cpp
R filters/lof/LOFFilter.hpp
R filters/mad/CMakeLists.txt
R filters/mad/MADFilter.cpp
R filters/mad/MADFilter.hpp
R filters/merge/CMakeLists.txt
R filters/merge/MergeFilter.cpp
R filters/merge/MergeFilter.hpp
R filters/mongus/CMakeLists.txt
R filters/mongus/MongusFilter.cpp
R filters/mongus/MongusFilter.hpp
R filters/mortonorder/CMakeLists.txt
R filters/mortonorder/MortonOrderFilter.cpp
R filters/mortonorder/MortonOrderFilter.hpp
R filters/normal/CMakeLists.txt
R filters/normal/NormalFilter.cpp
R filters/normal/NormalFilter.hpp
R filters/outlier/CMakeLists.txt
R filters/outlier/OutlierFilter.cpp
R filters/outlier/OutlierFilter.hpp
R filters/pmf/CMakeLists.txt
R filters/pmf/PMFFilter.cpp
R filters/pmf/PMFFilter.hpp
R filters/radialdensity/CMakeLists.txt
R filters/radialdensity/RadialDensityFilter.cpp
R filters/radialdensity/RadialDensityFilter.hpp
R filters/randomize/CMakeLists.txt
R filters/randomize/RandomizeFilter.cpp
R filters/randomize/RandomizeFilter.hpp
R filters/range/CMakeLists.txt
R filters/range/RangeFilter.cpp
R filters/range/RangeFilter.hpp
R filters/reprojection/CMakeLists.txt
R filters/reprojection/ReprojectionFilter.cpp
R filters/reprojection/ReprojectionFilter.hpp
R filters/sample/CMakeLists.txt
R filters/sample/SampleFilter.cpp
R filters/sample/SampleFilter.hpp
R filters/smrf/CMakeLists.txt
R filters/smrf/SMRFilter.cpp
R filters/smrf/SMRFilter.hpp
R filters/sort/CMakeLists.txt
R filters/sort/SortFilter.cpp
R filters/sort/SortFilter.hpp
R filters/splitter/CMakeLists.txt
R filters/splitter/SplitterFilter.cpp
R filters/splitter/SplitterFilter.hpp
R filters/stats/CMakeLists.txt
R filters/stats/StatsFilter.cpp
R filters/stats/StatsFilter.hpp
R filters/streamcallback/CMakeLists.txt
R filters/streamcallback/StreamCallbackFilter.cpp
R filters/streamcallback/StreamCallbackFilter.hpp
R filters/transformation/CMakeLists.txt
R filters/transformation/TransformationFilter.cpp
R filters/transformation/TransformationFilter.hpp
A io/BpfCompressor.cpp
A io/BpfCompressor.hpp
A io/BpfHeader.cpp
A io/BpfHeader.hpp
A io/BpfReader.cpp
A io/BpfReader.hpp
A io/BpfWriter.cpp
A io/BpfWriter.hpp
A io/BufferReader.hpp
R io/CMakeLists.txt
A io/DerivativeWriter.cpp
A io/DerivativeWriter.hpp
A io/FauxReader.cpp
A io/FauxReader.hpp
A io/GDALGrid.cpp
A io/GDALGrid.hpp
A io/GDALReader.cpp
A io/GDALReader.hpp
A io/GDALWriter.cpp
A io/GDALWriter.hpp
A io/GeotiffSupport.cpp
A io/GeotiffSupport.hpp
A io/HeaderVal.hpp
A io/Ilvis2MetadataReader.cpp
A io/Ilvis2MetadataReader.hpp
A io/Ilvis2Reader.cpp
A io/Ilvis2Reader.hpp
A io/LasError.hpp
A io/LasHeader.cpp
A io/LasHeader.hpp
A io/LasReader.cpp
A io/LasReader.hpp
A io/LasSummaryData.cpp
A io/LasSummaryData.hpp
A io/LasUtils.cpp
A io/LasUtils.hpp
A io/LasVLR.cpp
A io/LasVLR.hpp
A io/LasWriter.cpp
A io/LasWriter.hpp
A io/LasZipPoint.cpp
A io/LasZipPoint.hpp
A io/NullWriter.cpp
A io/NullWriter.hpp
A io/OptechCommon.hpp
A io/OptechReader.cpp
A io/OptechReader.hpp
A io/OptechRotationMatrix.hpp
A io/PlyReader.cpp
A io/PlyReader.hpp
A io/PlyWriter.cpp
A io/PlyWriter.hpp
A io/PtsReader.cpp
A io/PtsReader.hpp
A io/QfitReader.cpp
A io/QfitReader.hpp
A io/SbetCommon.cpp
A io/SbetCommon.hpp
A io/SbetReader.cpp
A io/SbetReader.hpp
A io/SbetWriter.cpp
A io/SbetWriter.hpp
A io/TIndexReader.cpp
A io/TIndexReader.hpp
A io/TerrasolidReader.cpp
A io/TerrasolidReader.hpp
A io/TextReader.cpp
A io/TextReader.hpp
A io/TextWriter.cpp
A io/TextWriter.hpp
R io/bpf/BpfCompressor.cpp
R io/bpf/BpfCompressor.hpp
R io/bpf/BpfHeader.cpp
R io/bpf/BpfHeader.hpp
R io/bpf/BpfReader.cpp
R io/bpf/BpfReader.hpp
R io/bpf/BpfWriter.cpp
R io/bpf/BpfWriter.hpp
R io/bpf/CMakeLists.txt
R io/buffer/BufferReader.hpp
R io/buffer/CMakeLists.txt
R io/derivative/CMakeLists.txt
R io/derivative/DerivativeWriter.cpp
R io/derivative/DerivativeWriter.hpp
R io/faux/CMakeLists.txt
R io/faux/FauxReader.cpp
R io/faux/FauxReader.hpp
R io/gdal/CMakeLists.txt
R io/gdal/GDALGrid.cpp
R io/gdal/GDALGrid.hpp
R io/gdal/GDALReader.cpp
R io/gdal/GDALReader.hpp
R io/gdal/GDALWriter.cpp
R io/gdal/GDALWriter.hpp
R io/ilvis2/CMakeLists.txt
R io/ilvis2/Ilvis2MetadataReader.cpp
R io/ilvis2/Ilvis2MetadataReader.hpp
R io/ilvis2/Ilvis2Reader.cpp
R io/ilvis2/Ilvis2Reader.hpp
R io/las/CMakeLists.txt
R io/las/GeotiffSupport.cpp
R io/las/GeotiffSupport.hpp
R io/las/HeaderVal.hpp
R io/las/LasError.hpp
R io/las/LasHeader.cpp
R io/las/LasHeader.hpp
R io/las/LasReader.cpp
R io/las/LasReader.hpp
R io/las/LasUtils.cpp
R io/las/LasUtils.hpp
R io/las/LasWriter.cpp
R io/las/LasWriter.hpp
R io/las/SummaryData.cpp
R io/las/SummaryData.hpp
R io/las/VariableLengthRecord.cpp
R io/las/VariableLengthRecord.hpp
R io/las/ZipPoint.cpp
R io/las/ZipPoint.hpp
R io/null/CMakeLists.txt
R io/null/NullWriter.cpp
R io/null/NullWriter.hpp
R io/optech/CMakeLists.txt
R io/optech/OptechCommon.hpp
R io/optech/OptechReader.cpp
R io/optech/OptechReader.hpp
R io/optech/OptechRotationMatrix.hpp
R io/ply/CMakeLists.txt
R io/ply/PlyReader.cpp
R io/ply/PlyReader.hpp
R io/ply/PlyWriter.cpp
R io/ply/PlyWriter.hpp
R io/pts/CMakeLists.txt
R io/pts/PtsReader.cpp
R io/pts/PtsReader.hpp
R io/qfit/CMakeLists.txt
R io/qfit/QfitReader.cpp
R io/qfit/QfitReader.hpp
R io/sbet/CMakeLists.txt
R io/sbet/SbetCommon.cpp
R io/sbet/SbetCommon.hpp
R io/sbet/SbetReader.cpp
R io/sbet/SbetReader.hpp
R io/sbet/SbetWriter.cpp
R io/sbet/SbetWriter.hpp
R io/terrasolid/CMakeLists.txt
R io/terrasolid/TerrasolidReader.cpp
R io/terrasolid/TerrasolidReader.hpp
R io/text/CMakeLists.txt
R io/text/TextReader.cpp
R io/text/TextReader.hpp
R io/text/TextWriter.cpp
R io/text/TextWriter.hpp
R io/tindex/CMakeLists.txt
R io/tindex/TIndexReader.cpp
R io/tindex/TIndexReader.hpp
R kernels/CMakeLists.txt
A kernels/DeltaKernel.cpp
A kernels/DeltaKernel.hpp
A kernels/DiffKernel.cpp
A kernels/DiffKernel.hpp
A kernels/InfoKernel.cpp
A kernels/InfoKernel.hpp
A kernels/MergeKernel.cpp
A kernels/MergeKernel.hpp
A kernels/PipelineKernel.cpp
A kernels/PipelineKernel.hpp
A kernels/RandomKernel.cpp
A kernels/RandomKernel.hpp
A kernels/SortKernel.cpp
A kernels/SortKernel.hpp
A kernels/SplitKernel.cpp
A kernels/SplitKernel.hpp
A kernels/TIndexKernel.cpp
A kernels/TIndexKernel.hpp
A kernels/TranslateKernel.cpp
A kernels/TranslateKernel.hpp
R kernels/delta/CMakeLists.txt
R kernels/delta/DeltaKernel.cpp
R kernels/delta/DeltaKernel.hpp
R kernels/diff/CMakeLists.txt
R kernels/diff/DiffKernel.cpp
R kernels/diff/DiffKernel.hpp
R kernels/info/CMakeLists.txt
R kernels/info/InfoKernel.cpp
R kernels/info/InfoKernel.hpp
R kernels/merge/CMakeLists.txt
R kernels/merge/MergeKernel.cpp
R kernels/merge/MergeKernel.hpp
R kernels/pipeline/CMakeLists.txt
R kernels/pipeline/PipelineKernel.cpp
R kernels/pipeline/PipelineKernel.hpp
R kernels/random/CMakeLists.txt
R kernels/random/RandomKernel.cpp
R kernels/random/RandomKernel.hpp
R kernels/sort/CMakeLists.txt
R kernels/sort/SortKernel.cpp
R kernels/sort/SortKernel.hpp
R kernels/split/CMakeLists.txt
R kernels/split/SplitKernel.cpp
R kernels/split/SplitKernel.hpp
R kernels/tindex/CMakeLists.txt
R kernels/tindex/TIndexKernel.cpp
R kernels/tindex/TIndexKernel.hpp
R kernels/translate/CMakeLists.txt
R kernels/translate/TranslateKernel.cpp
R kernels/translate/TranslateKernel.hpp
M plugins/cpd/CMakeLists.txt
M plugins/cpd/kernel/Cpd.cpp
M plugins/cpd/test/CpdKernelTest.cpp
M plugins/icebridge/CMakeLists.txt
M plugins/icebridge/io/IcebridgeReader.hpp
M plugins/nitf/CMakeLists.txt
M plugins/nitf/io/NitfReader.hpp
M plugins/nitf/io/NitfWriter.hpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/nitf/test/NitfWriterTest.cpp
M plugins/oci/CMakeLists.txt
M plugins/oci/test/OCITest.cpp
M plugins/pcl/CMakeLists.txt
M plugins/pcl/filters/DartSampleFilter.cpp
M plugins/pcl/filters/GreedyProjectionFilter.cpp
M plugins/pcl/filters/GridProjectionFilter.cpp
M plugins/pcl/filters/GroundFilter.cpp
M plugins/pcl/filters/HeightFilter.cpp
M plugins/pcl/filters/MovingLeastSquaresFilter.cpp
M plugins/pcl/filters/PCLBlock.cpp
M plugins/pcl/filters/PoissonFilter.cpp
M plugins/pcl/filters/RadiusOutlierFilter.cpp
M plugins/pcl/filters/StatisticalOutlierFilter.cpp
M plugins/pcl/filters/VoxelGridFilter.cpp
M plugins/pcl/io/PCLVisualizer.cpp
M plugins/pcl/io/PcdReader.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/python/CMakeLists.txt
M plugins/python/test/PLangTest.cpp
M plugins/python/test/PredicateFilterTest.cpp
M plugins/python/test/ProgrammableFilterTest.cpp
M plugins/sqlite/test/SQLiteTest.cpp
M src/CMakeLists.txt
R src/Filter.cpp
M src/Kernel.cpp
M test/unit/CompressionTest.cpp
M test/unit/LogTest.cpp
M test/unit/OptionsTest.cpp
M test/unit/PointTableTest.cpp
M test/unit/SpatialReferenceTest.cpp
M test/unit/StreamingTest.cpp
M test/unit/apps/RandomTest.cpp
M test/unit/apps/pc2pcTest.cpp
M test/unit/filters/AdditionalMergeTest.cpp
M test/unit/filters/ChipperTest.cpp
M test/unit/filters/ColorizationFilterTest.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/filters/DecimationFilterTest.cpp
M test/unit/filters/DividerFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/filters/RandomizeFilterTest.cpp
M test/unit/filters/RangeFilterTest.cpp
M test/unit/filters/ReprojectionFilterTest.cpp
M test/unit/filters/SortFilterTest.cpp
M test/unit/filters/SplitterTest.cpp
M test/unit/filters/StatsFilterTest.cpp
M test/unit/filters/TransformationFilterTest.cpp
A test/unit/io/BPFTest.cpp
A test/unit/io/BufferTest.cpp
A test/unit/io/FauxReaderTest.cpp
A test/unit/io/GDALReaderTest.cpp
A test/unit/io/GDALWriterTest.cpp
A test/unit/io/Ilvis2MetadataReaderTest.cpp
A test/unit/io/Ilvis2ReaderTest.cpp
A test/unit/io/Ilvis2ReaderWithMDReaderTest.cpp
A test/unit/io/LasReaderTest.cpp
A test/unit/io/LasWriterTest.cpp
A test/unit/io/OptechReaderTest.cpp
A test/unit/io/PlyReaderTest.cpp
A test/unit/io/PlyWriterTest.cpp
A test/unit/io/PtsReaderTest.cpp
A test/unit/io/QFITReaderTest.cpp
A test/unit/io/SbetReaderTest.cpp
A test/unit/io/SbetWriterTest.cpp
A test/unit/io/TerrasolidReaderTest.cpp
A test/unit/io/TextReaderTest.cpp
A test/unit/io/TextWriterTest.cpp
R test/unit/io/bpf/BPFTest.cpp
R test/unit/io/buffer/BufferTest.cpp
R test/unit/io/faux/FauxReaderTest.cpp
R test/unit/io/gdal/GDALReaderTest.cpp
R test/unit/io/gdal/GDALWriterTest.cpp
R test/unit/io/ilvis2/Ilvis2MetadataReaderTest.cpp
R test/unit/io/ilvis2/Ilvis2ReaderTest.cpp
R test/unit/io/ilvis2/Ilvis2ReaderWithMDReaderTest.cpp
R test/unit/io/las/LasReaderTest.cpp
R test/unit/io/las/LasWriterTest.cpp
R test/unit/io/oci/oracle_array.cpp
R test/unit/io/optech/OptechReaderTest.cpp
R test/unit/io/ply/PlyReaderTest.cpp
R test/unit/io/ply/PlyWriterTest.cpp
R test/unit/io/pts/PtsReaderTest.cpp
R test/unit/io/qfit/QFITReaderTest.cpp
R test/unit/io/sbet/SbetReaderTest.cpp
R test/unit/io/sbet/SbetWriterTest.cpp
R test/unit/io/terrasolid/TerrasolidReaderTest.cpp
R test/unit/io/text/TextReaderTest.cpp
R test/unit/io/text/TextWriterTest.cpp
M tools/nitfwrap/CMakeLists.txt
M tools/nitfwrap/NitfWrap.cpp
M tools/nitfwrap/NitfWrap.hpp
Log Message:
Move filters/io/kernels from subdirectories and refactor build.
Commit: cc30c272a421d8719813514c23e0e7b9b2859356
https://github.com/PDAL/PDAL/commit/cc30c272a421d8719813514c23e0e7b9b2859356
Changed paths:
M .gitignore
M filters/MongusFilter.cpp
M filters/MongusFilter.hpp
M filters/SMRFilter.cpp
M filters/SMRFilter.hpp
M python/setup.py
M src/PDALUtils.cpp
M src/XMLSchema.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into include-dirs
Commit: cf07c0e8e1b2d26fbe9128206e99efd1867b37bc
https://github.com/PDAL/PDAL/commit/cf07c0e8e1b2d26fbe9128206e99efd1867b37bc
Changed paths:
A filters/ComputeRangeFilter.cpp
A filters/ComputeRangeFilter.hpp
R filters/computerange/CMakeLists.txt
R filters/computerange/ComputeRangeFilter.cpp
R filters/computerange/ComputeRangeFilter.hpp
A kernels/HausdorffKernel.cpp
A kernels/HausdorffKernel.hpp
R kernels/hausdorff/CMakeLists.txt
R kernels/hausdorff/HausdorffKernel.cpp
R kernels/hausdorff/HausdorffKernel.hpp
M test/unit/filters/ComputeRangeFilterTest.cpp
Log Message:
Make added kernels/filters work in new layout.
Commit: b7f1c42f9f7e148481faa1578faee5779b518b5d
https://github.com/PDAL/PDAL/commit/b7f1c42f9f7e148481faa1578faee5779b518b5d
Changed paths:
M doc/apps/density.rst
A doc/apps/hausdorff.rst
A doc/apps/sort.rst
M kernels/delta/DeltaKernel.cpp
M kernels/diff/DiffKernel.cpp
M kernels/hausdorff/HausdorffKernel.cpp
M kernels/info/InfoKernel.cpp
M kernels/merge/MergeKernel.cpp
M kernels/pipeline/PipelineKernel.cpp
M kernels/random/RandomKernel.cpp
M kernels/sort/SortKernel.cpp
M kernels/split/SplitKernel.cpp
M kernels/tindex/TIndexKernel.cpp
M kernels/translate/TranslateKernel.cpp
M plugins/pcl/kernel/GroundKernel.cpp
M plugins/pcl/kernel/ViewKernel.cpp
Log Message:
Documentation updates
* Add Hausdorff and Sort kernel documentation
* Update all kernel links to point to the real URLs
* Add note that density kernel only comes with Hexer
Commit: 44075bce4a7d6c36ac0e38636568d66d114cb785
https://github.com/PDAL/PDAL/commit/44075bce4a7d6c36ac0e38636568d66d114cb785
Changed paths:
A doc/apps/sort.rst
Log Message:
Merge pull request #1403 from PDAL/kernel-links-add-hausdorff
Commit: 46e56edeabe875d3be50f126dccb4a0714581ebe
https://github.com/PDAL/PDAL/commit/46e56edeabe875d3be50f126dccb4a0714581ebe
Changed paths:
M CMakeLists.txt
M cmake/directories.cmake
M plugins/python/filters/CMakeLists.txt
R src/CMakeLists.txt
Log Message:
Install new directory structure.
Rename some cmake variables.
Remove some dead code.
Commit: d89c03e85da5c1bc6631fdc946c6223fba537dc5
https://github.com/PDAL/PDAL/commit/d89c03e85da5c1bc6631fdc946c6223fba537dc5
Date: 2016-11-28 (Mon, 28 Nov 2016)
Changed paths:
M test/unit/EigenTest.cpp
Log Message:
Replace and fix diffX/diffY lambdas
Replace with numerical gradient result much like you would expect from MATLAB.
Add some tests to make sure it's all working as expected.
Commit: ca9e38d8079044800d4ed4e4e48269becad53676
https://github.com/PDAL/PDAL/commit/ca9e38d8079044800d4ed4e4e48269becad53676
Changed paths:
Log Message:
Merge pull request #1408 from PDAL/diffX_diffY_refactor_and_tests
Commit: 6c74d2d8f2325a5a34bb726038eda62f16e30701
https://github.com/PDAL/PDAL/commit/6c74d2d8f2325a5a34bb726038eda62f16e30701
Changed paths:
M CMakeLists.txt
M dimbuilder/CMakeLists.txt
M examples/writing-filter/CMakeLists.txt
M examples/writing-kernel/CMakeLists.txt
M examples/writing-reader/CMakeLists.txt
M examples/writing-writer/CMakeLists.txt
M examples/writing/CMakeLists.txt
M include/pdal/KDIndex.hpp
M include/pdal/util/FileUtils.hpp
M io/PlyReader.hpp
M io/PlyWriter.hpp
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/GreyhoundReader.hpp
M plugins/hexbin/CMakeLists.txt
M plugins/matlab/CMakeLists.txt
M plugins/p2g/CMakeLists.txt
M plugins/pgpointcloud/CMakeLists.txt
M plugins/rxp/CMakeLists.txt
M plugins/sqlite/CMakeLists.txt
M src/PDALUtils.cpp
M src/plang/CMakeLists.txt
M src/util/CMakeLists.txt
M tools/lasdump/CMakeLists.txt
M vendor/arbiter/CMakeLists.txt
M vendor/pdalboost/CMakeLists.txt
Log Message:
Replace include_directories with target_include_directories
Commit: 090f3118e84d793363246fcc761a23da09a63d0b
https://github.com/PDAL/PDAL/commit/090f3118e84d793363246fcc761a23da09a63d0b
Changed paths:
A doc/apps/sort.rst
M kernels/DeltaKernel.cpp
M kernels/DiffKernel.cpp
M kernels/HausdorffKernel.cpp
M kernels/InfoKernel.cpp
M kernels/MergeKernel.cpp
M kernels/PipelineKernel.cpp
M kernels/RandomKernel.cpp
M kernels/SortKernel.cpp
M kernels/SplitKernel.cpp
M kernels/TIndexKernel.cpp
M kernels/TranslateKernel.cpp
Log Message:
Commit: 53582dd826891cf4bf556d42a947341015198f71
https://github.com/PDAL/PDAL/commit/53582dd826891cf4bf556d42a947341015198f71
Changed paths:
M plugins/pgpointcloud/io/PgCommon.hpp
Log Message:
Returning NULL as string results in bad string.
Commit: 7b1ea0547fc8e569163324b65eea3b05fa395a12
https://github.com/PDAL/PDAL/commit/7b1ea0547fc8e569163324b65eea3b05fa395a12
Changed paths:
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/2623dd705305...7b1ea0547fc8
More information about the pdal-commits
