[pdal-commits] [PDAL/PDAL] 87697e: add Java into docker deps (#1405)
GitHub noreply at github.com
Tue Nov 29 15:08:43 PST 2016
  Branch: refs/heads/include-dirs
  Home:   https://github.com/PDAL/PDAL
  Commit: 87697e4d6b148cdf4d95e825b19ce7144cc75df1
      https://github.com/PDAL/PDAL/commit/87697e4d6b148cdf4d95e825b19ce7144cc75df1
  Author: Grisha <gr.pomadchin at gmail.com>
  Date:   2016-11-28 (Mon, 28 Nov 2016)
  Changed paths:
    M scripts/docker/dependencies/Dockerfile
    M scripts/docker/dependencies/Dockerfile.xenial
  Log Message:
  Commit: f3602b17cedeca7efa521c010f80ddf4059f388b
      https://github.com/PDAL/PDAL/commit/f3602b17cedeca7efa521c010f80ddf4059f388b
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M apps/pdal.cpp
    M include/pdal/util/ProgramArgs.hpp
    M plugins/mrsid/io/MrsidReader.cpp
  Log Message:
  Support --showjson switch for 'pdal' app (#1401)
* don't add filename arg to ProgramArgs for readers.mrsid
* support --showjson switch for 'pdal' app to print current options and driver info as JSON #1315
* use stage name(s) as keys
* showjson option should be hidden #1315
  Commit: ff59e7d98077f0a793a288e8fc2d3bf404bff40f
      https://github.com/PDAL/PDAL/commit/ff59e7d98077f0a793a288e8fc2d3bf404bff40f
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2016-11-29 (Tue, 29 Nov 2016)
  Changed paths:
    M plugins/pcl/CMakeLists.txt
  Log Message:
  Fix #1410
  Commit: fd36f60f89a6c5ef620bba22ae269069bd7d791a
      https://github.com/PDAL/PDAL/commit/fd36f60f89a6c5ef620bba22ae269069bd7d791a
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
  Log Message:
  Merge pull request #1411 from PDAL/issue/1410-pcd-writer
CMake missing PCD writer sources
  Commit: c56358260e03d2a5d70519373f636f34eb180a55
      https://github.com/PDAL/PDAL/commit/c56358260e03d2a5d70519373f636f34eb180a55
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into include-dirs
Compare: https://github.com/PDAL/PDAL/compare/33ac35eca7c1...c56358260e03
More information about the pdal-commits mailing list
