[pdal-commits] [PDAL/PDAL] 457f5a: Log a stacktrace if at log-level debug on unix if ...
GitHub noreply at github.com
Wed Oct 19 13:00:03 PDT 2016
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 457f5ac59adb223f44f9e033922dd73cc5bb0f08
      https://github.com/PDAL/PDAL/commit/457f5ac59adb223f44f9e033922dd73cc5bb0f08
  Author: Connor Manning <connor at hobu.co>
  Date:   2016-10-12 (Wed, 12 Oct 2016)
  Changed paths:
    M apps/pdal.cpp
    M filters/stats/StatsFilter.cpp
  Log Message:
  Log a stacktrace if at log-level debug on unix if a segfault occurs.  Remove an extraneous debug log.
  Commit: 71b3696deaf5ac258cbed51c21632dbbec721c68
      https://github.com/PDAL/PDAL/commit/71b3696deaf5ac258cbed51c21632dbbec721c68
  Changed paths:
    M apps/pdal.cpp
    M src/util/Utils.cpp
  Log Message:
  In demangle, ensure result is valid to avoid hanging.  Use this util for stacktrace logging.
  Commit: ff61520aa6f475331b4bd512c7e05d926d874f73
      https://github.com/PDAL/PDAL/commit/ff61520aa6f475331b4bd512c7e05d926d874f73
  Date:   2016-10-19 (Wed, 19 Oct 2016)
  Changed paths:
    M doc/stages/writers.gdal.rst
    M filters/colorinterp/ColorinterpFilter.cpp
    M filters/splitter/SplitterFilter.cpp
    M io/derivative/DerivativeWriter.cpp
    M io/gdal/GDALWriter.cpp
    M io/gdal/GDALWriter.hpp
    M kernels/info/InfoKernel.cpp
    M plugins/hexbin/filters/HexBin.cpp
    M plugins/p2g/io/P2gWriter.cpp
    M scripts/docker/Dockerfile
    M src/Dimension.json
    M test/unit/io/gdal/GDALWriterTest.cpp
  Log Message:
  Merge branch 'master' into stacktrace
  Commit: f83ae81a2c549cf579ef94056e09e71d9a151c06
      https://github.com/PDAL/PDAL/commit/f83ae81a2c549cf579ef94056e09e71d9a151c06
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  Add include.
  Commit: 142f1de7bc792427e6268eb6a97a9b5af1624b54
      https://github.com/PDAL/PDAL/commit/142f1de7bc792427e6268eb6a97a9b5af1624b54
  Changed paths:
    M src/CMakeLists.txt
  Log Message:
  Link dl.
  Commit: 60ef8cfcfc0e255d80f17d5096c2bdc207743547
      https://github.com/PDAL/PDAL/commit/60ef8cfcfc0e255d80f17d5096c2bdc207743547
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M apps/pdal.cpp
  Log Message:
  Merge pull request #1329 from PDAL/stacktrace
Log a stacktrace if PDAL segfaults on Unix
Compare: https://github.com/PDAL/PDAL/compare/f3508112e023...60ef8cfcfc0e
More information about the pdal-commits mailing list
