[pdal-commits] [PDAL/PDAL] 15db3d: Fix splitter so that cells below the origin have t...
GitHub
noreply at github.com
Fri Oct 21 11:49:39 PDT 2016
Branch: refs/heads/1.3-maintenance
Home: https://github.com/PDAL/PDAL
Commit: 15db3d0f211857e355df9635a83e10b0a470906d
https://github.com/PDAL/PDAL/commit/15db3d0f211857e355df9635a83e10b0a470906d
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-10-21 (Fri, 21 Oct 2016)
Changed paths:
M filters/splitter/SplitterFilter.cpp
M filters/splitter/SplitterFilter.hpp
M test/unit/filters/SplitterTest.cpp
Log Message:
Fix splitter so that cells below the origin have the correct index.
Add tests for the above.
ALSO - Store viewMap across point view processing so that cells are merged
from multiple point views.
Close #1336
More information about the pdal-commits
