[pdal-commits] [PDAL/PDAL] 1396e9: Update location of dimension info.
GitHub
noreply at github.com
Mon Oct 31 08:24:32 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 1396e9fd29909bed5aa1451b428c913ff46b3707
https://github.com/PDAL/PDAL/commit/1396e9fd29909bed5aa1451b428c913ff46b3707
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2016-10-31 (Mon, 31 Oct 2016)
Changed paths:
M doc/tutorial/overview.rst
Log Message:
Commit: e94df2e8fb6e5932946343e81e3ee9a800bfff5e
https://github.com/PDAL/PDAL/commit/e94df2e8fb6e5932946343e81e3ee9a800bfff5e
Changed paths:
M apps/pdal.cpp
M cmake/macros.cmake
M dimbuilder/CMakeLists.txt
M doc/conf.py
A doc/dimensions.rst
M doc/index.rst
A doc/references.rst
M doc/stages/filters.dartsample.rst
M doc/stages/filters.ground.rst
M doc/stages/filters.outlier.rst
M doc/stages/filters.pmf.rst
M doc/stages/filters.sample.rst
M doc/stages/filters.statisticaloutlier.rst
M doc/stages/readers.rst
M doc/tutorial/writing-filter.rst
M doc/tutorial/writing-kernel.rst
M doc/tutorial/writing-reader.rst
M doc/tutorial/writing-writer.rst
M examples/writing-reader/MyReader.cpp
M include/pdal/GDALUtils.hpp
M include/pdal/Kernel.hpp
M include/pdal/PDALUtils.hpp
M include/pdal/Polygon.hpp
M include/pdal/util/Utils.hpp
M kernels/info/InfoKernel.cpp
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/bbox.cpp
M plugins/greyhound/io/bbox.hpp
M plugins/greyhound/io/dir.hpp
M plugins/icebridge/io/IcebridgeReader.cpp
M plugins/icebridge/io/IcebridgeReader.hpp
M plugins/nitf/io/NitfFileWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/p2g/io/P2gWriter.cpp
M plugins/p2g/io/P2gWriter.hpp
M plugins/sqlite/io/SQLiteWriter.cpp
M src/CMakeLists.txt
M src/Kernel.cpp
M src/PDALUtils.cpp
M src/PipelineReaderJSON.cpp
M src/PipelineReaderXML.cpp
M src/PointView.cpp
M src/Polygon.cpp
M src/SpatialReference.cpp
M src/util/CMakeLists.txt
M src/util/Utils.cpp
A test/data/autzen/thin-1.las
A test/data/autzen/thin-2.las
M test/data/filters/hexbin-info.xml.in
A test/data/pipeline/glob.json.in
M test/data/text/utm17_2.txt
M test/unit/CMakeLists.txt
M test/unit/PipelineManagerTest.cpp
A test/unit/io/text/TextWriterTest.cpp
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
M vendor/jsoncpp/dist/CMakeLists.txt
M vendor/pdalboost/CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/737e6218813a...e94df2e8fb6e
More information about the pdal-commits
