[pdal-commits] [PDAL/PDAL] 1579aa: Fix PcdWriter compression option
GitHub
noreply at github.com
Mon Sep 12 11:00:44 PDT 2016
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 1579aa524e1321007d8c6a0c28b76039af419f46
https://github.com/PDAL/PDAL/commit/1579aa524e1321007d8c6a0c28b76039af419f46
Author: Logan Byers <loganbyers at ku.edu>
Date: 2016-09-12 (Mon, 12 Sep 2016)
Changed paths:
M plugins/pcl/io/PcdWriter.cpp
M plugins/pcl/io/PcdWriter.hpp
Log Message:
Rearrange workflow for determining compression level
for option writers.pcd.compression. Previous version
set write method before the program arguments were
set! This resulted in always ascii compression.
This also fixes a potential free() error that can occur
when this writer is ran within a pipeline.
Commit: 65f86e02b074a6f97a124c15b2eb6380bcf18d84
https://github.com/PDAL/PDAL/commit/65f86e02b074a6f97a124c15b2eb6380bcf18d84
Author: Howard Butler <howard at hobu.co>
Changed paths:
Log Message:
Merge pull request #1309 from loganbyers/pcdwriter_upgrades
Fix PcdWriter compression option for 1.3
Compare: https://github.com/PDAL/PDAL/compare/4b1bfe4ba5c4...65f86e02b074
More information about the pdal-commits
