[pdal-commits] [PDAL/PDAL] ccfc6a: Pass gdaloptions to raster.
GitHub
noreply at github.com
Tue Apr 4 12:43:02 PDT 2017
Branch: refs/tags/dependencies
Home: https://github.com/PDAL/PDAL
Commit: ccfc6ac8b099a505ad7b2a953c3b00ff9d0b4411
https://github.com/PDAL/PDAL/commit/ccfc6ac8b099a505ad7b2a953c3b00ff9d0b4411
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-03-13 (Mon, 13 Mar 2017)
Changed paths:
M io/GDALWriter.cpp
Log Message:
Close #1523
Commit: 94c97fce81653e5e4f4213479422a1084ca225e1
https://github.com/PDAL/PDAL/commit/94c97fce81653e5e4f4213479422a1084ca225e1
Changed paths:
M scripts/docker/Dockerfile
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: a18cd5b193bb22470914a29ca9efc140c5772029
https://github.com/PDAL/PDAL/commit/a18cd5b193bb22470914a29ca9efc140c5772029
Author: Howard Butler <howard at hobu.co>
Date: 2017-03-14 (Tue, 14 Mar 2017)
Changed paths:
A doc/development/docker.rst
M doc/development/index.rst
Log Message:
add notes about Docker setup
Commit: 306d9ae70536eb6cd784ffd3194d39859a5ac4c6
https://github.com/PDAL/PDAL/commit/306d9ae70536eb6cd784ffd3194d39859a5ac4c6
Changed paths:
A doc/images/docker-maintenance-branch.png
A doc/images/docker-master-branch.png
Log Message:
add images about docker building
Commit: e3a9390dc5f80f740dd83f9d48165109d93ce63c
https://github.com/PDAL/PDAL/commit/e3a9390dc5f80f740dd83f9d48165109d93ce63c
Author: Pete Gadomski <pete.gadomski at gmail.com>
Changed paths:
M plugins/hexbin/CMakeLists.txt
Log Message:
HEXER_INCLUDE_DIR must be included publicly (#1519)
The density kernel links against the hexer filter library, and if hexer
is installed to a non-system location the build fails.
Commit: 92bf4ff915b9885c5d328eaa0bf8e2e55ccd16a1
https://github.com/PDAL/PDAL/commit/92bf4ff915b9885c5d328eaa0bf8e2e55ccd16a1
Author: Mateusz Łoskot <mateusz at loskot.net>
Changed paths:
M doc/development/compilation/dependencies.rst
Log Message:
Move GeoTIFF and PROJ.4 to required dependencies. (#1522)
Both libraries are actually required, or successful
build is not feasible without GDAL with PROJ.4 enabled.
[ci skip]
Commit: c474509974483c438683f99e4e22072318465a9d
https://github.com/PDAL/PDAL/commit/c474509974483c438683f99e4e22072318465a9d
Changed paths:
M test/unit/PluginManagerTest.cpp
Log Message:
Fix for GCC 4.7.2 returning lambda.
Commit: 7ee24898b3bf4290a40d81564899d1d61b1c5790
https://github.com/PDAL/PDAL/commit/7ee24898b3bf4290a40d81564899d1d61b1c5790
Changed paths:
M io/GDALWriter.cpp
Log Message:
Commit: a32602986449eb9c5ba34ec619b27b5893bb3ec2
https://github.com/PDAL/PDAL/commit/a32602986449eb9c5ba34ec619b27b5893bb3ec2
Changed paths:
M kernels/TranslateKernel.cpp
M pdal/PipelineManager.cpp
M pdal/PipelineManager.hpp
M pdal/Stage.hpp
M test/unit/apps/TranslateTest.cpp
Log Message:
Accept full pipelines with --json argument to pdal pipeline.
Close #1521
Commit: 99eb8163c2c6f5dc9877bdd46e68629d8b5db19f
https://github.com/PDAL/PDAL/commit/99eb8163c2c6f5dc9877bdd46e68629d8b5db19f
Author: Connor Manning <connor at hobu.co>
Changed paths:
M vendor/arbiter/arbiter.hpp
Log Message:
Add arbiter include.
Commit: 0c81e54b43e6c4621962908a4a4a11e36c917ce1
https://github.com/PDAL/PDAL/commit/0c81e54b43e6c4621962908a4a4a11e36c917ce1
Changed paths:
M doc/development/metadata.rst
M doc/stages/writers.las.rst
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Optionally add PDAL metadata and pipeline VLRs to writers.las output in support of processing history activities (#1525)
* PDAL metadata WIP
* more pdal metadata VLR WIP -- a test too
* light docs on pdal_metadata option
Commit: 6db4c2075f1dca5bafc558678f09ea1c720d3c82
https://github.com/PDAL/PDAL/commit/6db4c2075f1dca5bafc558678f09ea1c720d3c82
Author: Alex Jokela <alex at camulus.com>
Changed paths:
M io/GDALGrid.hpp
Log Message:
Add GDALGrid include.
Commit: 6448d9357ddf58a123323f38a13c4ab13b61df24
https://github.com/PDAL/PDAL/commit/6448d9357ddf58a123323f38a13c4ab13b61df24
Changed paths:
M io/GDALGrid.hpp
Log Message:
Merge pull request #1526 from ajokela/master
Commit: 84e14de69c52cb33538f674bebe910ada7d7285d
https://github.com/PDAL/PDAL/commit/84e14de69c52cb33538f674bebe910ada7d7285d
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-03-15 (Wed, 15 Mar 2017)
Changed paths:
R doc/stages/writers.derivative.rst
R io/DerivativeWriter.cpp
R io/DerivativeWriter.hpp
M pdal/StageFactory.cpp
Log Message:
Remove writers.derivative per #1527
The actual derivative calculations will be kept in EigenUtils for now - only the writer is removed.
Commit: 1bbc63394988093a5005c3475286d899ffb757b8
https://github.com/PDAL/PDAL/commit/1bbc63394988093a5005c3475286d899ffb757b8
Changed paths:
M doc/apps/pipeline.rst
Log Message:
discussion about substitution should be more prominent
Commit: 2354399c87b73b59fb20e310ae4c45dd9ce526d5
https://github.com/PDAL/PDAL/commit/2354399c87b73b59fb20e310ae4c45dd9ce526d5
Changed paths:
M HOWTORELEASE.txt
Log Message:
how to release notes
Commit: 0eb5fd71c45a8e0108b1cf0a8af10e11acb45c45
https://github.com/PDAL/PDAL/commit/0eb5fd71c45a8e0108b1cf0a8af10e11acb45c45
Changed paths:
M doc/community.rst
Log Message:
note about gitter
Commit: 119419a69fd5a3dcc8693b01c315053effbcbe03
https://github.com/PDAL/PDAL/commit/119419a69fd5a3dcc8693b01c315053effbcbe03
Changed paths:
M io/GDALGrid.hpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Stage.hpp
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 8419172dbeab4e4bf9163db7c1b6f12400843efc
https://github.com/PDAL/PDAL/commit/8419172dbeab4e4bf9163db7c1b6f12400843efc
Changed paths:
M doc/apps/ground.rst
M doc/tutorial/pcl_ground.rst
M doc/workshop/exercises/analysis/boundary/boundary.rst
M kernels/GroundKernel.cpp
M kernels/RandomKernel.cpp
M kernels/SortKernel.cpp
M pdal/Kernel.cpp
M pdal/Kernel.hpp
M plugins/pcl/io/PcdReader.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
Log Message:
Remove visualize option from kernels.
Close #1529
Commit: be875700afb443a69cc3b5dd297be417979f9cea
https://github.com/PDAL/PDAL/commit/be875700afb443a69cc3b5dd297be417979f9cea
Changed paths:
M HOWTORELEASE.txt
M doc/community.rst
Log Message:
Commit: 45c851a8ff92e8c3537fa54332ba1a7b1b9d5cfd
https://github.com/PDAL/PDAL/commit/45c851a8ff92e8c3537fa54332ba1a7b1b9d5cfd
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1528 from PDAL/remove-derivative-writer
Close #1527
Commit: 201174b405f9940cb201641f2fce8704e3389466
https://github.com/PDAL/PDAL/commit/201174b405f9940cb201641f2fce8704e3389466
Changed paths:
M doc/apps/density.rst
M doc/apps/index.rst
Log Message:
Move standard kernel option doc.
Commit: b2bf6aed78934ce357e523712cb86080f9656387
https://github.com/PDAL/PDAL/commit/b2bf6aed78934ce357e523712cb86080f9656387
Changed paths:
M HOWTORELEASE.txt
M doc/community.rst
M io/GDALGrid.hpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Kernel.cpp
M pdal/Kernel.hpp
Log Message:
Commit: fb15a3a120e6a335e629a64ec246b9cb4815c789
https://github.com/PDAL/PDAL/commit/fb15a3a120e6a335e629a64ec246b9cb4815c789
Changed paths:
M CMakeLists.txt
Log Message:
Expose LASzip's configured include path via interface-include-directories.
Commit: 32459c8a3d449ff55622c00db1f3ba3b9b682ada
https://github.com/PDAL/PDAL/commit/32459c8a3d449ff55622c00db1f3ba3b9b682ada
Changed paths:
M doc/apps/delta.rst
M doc/apps/diff.rst
M doc/apps/info.rst
M doc/apps/merge.rst
M doc/apps/pcl.rst
M doc/apps/random.rst
M doc/apps/sort.rst
M doc/apps/split.rst
M doc/apps/tindex.rst
M doc/apps/translate.rst
M kernels/InfoKernel.cpp
M kernels/TIndexKernel.cpp
Log Message:
Update options/doc pass for kernels.
Commit: 21d9a5869b4650bf0511dce33efe5a247b2234b2
https://github.com/PDAL/PDAL/commit/21d9a5869b4650bf0511dce33efe5a247b2234b2
Changed paths:
M CMakeLists.txt
Log Message:
Commit: 4e7e52d368925d8f6d9244b58f1112bdf6b8c103
https://github.com/PDAL/PDAL/commit/4e7e52d368925d8f6d9244b58f1112bdf6b8c103
Date: 2017-03-16 (Thu, 16 Mar 2017)
Changed paths:
Log Message:
Remove PCvisualizer references.
Commit: 6154697ca83574a66834a4ec22a0fffbf447accb
https://github.com/PDAL/PDAL/commit/6154697ca83574a66834a4ec22a0fffbf447accb
Changed paths:
M doc/download.rst
M doc/quickstart.rst
M doc/workshop/exercises/analysis/clipping/clipping.json
M doc/workshop/slides/source/pdal_intro.rst
Log Message:
doc updates
Commit: ef2d75d0b3fc6a073012829be4188340115308f4
https://github.com/PDAL/PDAL/commit/ef2d75d0b3fc6a073012829be4188340115308f4
Changed paths:
M doc/images/reproject-merge-pipeline.png
M doc/pipeline.rst
Log Message:
pipeline doc updates
Commit: d1c50ff10e4c5b7e0f4106016e8f7ba0e5d60c90
https://github.com/PDAL/PDAL/commit/d1c50ff10e4c5b7e0f4106016e8f7ba0e5d60c90
Changed paths:
R doc/development/compilation/python.rst
A doc/images/python-pdal-pipeline.png
M doc/index.rst
A doc/python.rst
Log Message:
python docs
Commit: 49d88890ea288aa9fad1eada86fb6cde0fc68cf0
https://github.com/PDAL/PDAL/commit/49d88890ea288aa9fad1eada86fb6cde0fc68cf0
Date: 2017-03-17 (Fri, 17 Mar 2017)
Changed paths:
M doc/stages/filters.smrf.rst
M filters/SMRFilter.cpp
M filters/SMRFilter.hpp
M pdal/EigenUtils.cpp
M pdal/EigenUtils.hpp
Log Message:
Refactor SMRF code
* only write intermediate rasters for debugging when optional output directory is provided
* make program args more consistent with the paper
* revert from TPS interpolation back to average of 8 nearest neighbors
* use iterative morphological operations and diamond structuring element for speedup
* remove the classify/extract args, always classify, and extract with range filter if desired
Commit: b094fd5ad222617f5c5023c34aba1306b80311a5
https://github.com/PDAL/PDAL/commit/b094fd5ad222617f5c5023c34aba1306b80311a5
Changed paths:
M doc/python.rst
M doc/stages/filters.range.rst
R doc/stages/ranges.rst
Log Message:
doc updates: pull content about Ranges into filters.range document
Commit: ca6c17001cc0328253f48c0483b58aa0e283b856
https://github.com/PDAL/PDAL/commit/ca6c17001cc0328253f48c0483b58aa0e283b856
Changed paths:
Log Message:
Merge pull request #1531 from PDAL/smrf-refactor
Refactor SMRF code
Close #1314
Commit: a34ef5eac2c9075bdad5f2642126fd7d3d955f05
https://github.com/PDAL/PDAL/commit/a34ef5eac2c9075bdad5f2642126fd7d3d955f05
Changed paths:
A doc/about.rst
M doc/development/docker.rst
M doc/index.rst
M doc/python.rst
M doc/stages/filters.reprojection.rst
M doc/stages/readers.gdal.rst
M doc/stages/writers.gdal.rst
M doc/tutorial/pcl_spec.rst
M doc/workshop/agenda.rst
M doc/workshop/index.rst
R doc/workshop/pdal-introduction.rst
Log Message:
doc updates (make an About page)
Commit: faee100b7dfc964f9244ef66c54bc537d0209cd6
https://github.com/PDAL/PDAL/commit/faee100b7dfc964f9244ef66c54bc537d0209cd6
Changed paths:
M doc/download.rst
M doc/index.rst
M scripts/docker/docbuild/Dockerfile
Log Message:
doc updates (latex output org
Commit: 2a860a2d88847ac961746cde52a0afd009becf4a
https://github.com/PDAL/PDAL/commit/2a860a2d88847ac961746cde52a0afd009becf4a
Changed paths:
M cmake/examples/hobu-config.sh
Log Message:
my config doesn't need to hardcode laszip anymore
Commit: 10fec9cc53de5e4ff07033e0530b0cc2d4ae625f
https://github.com/PDAL/PDAL/commit/10fec9cc53de5e4ff07033e0530b0cc2d4ae625f
Changed paths:
M kernels/PipelineKernel.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Set progress FD in PipelineManager.
Close #1534
Commit: 40e422e83ff83234385d91d521394dfc2c305770
https://github.com/PDAL/PDAL/commit/40e422e83ff83234385d91d521394dfc2c305770
Changed paths:
A doc/about.rst
M doc/download.rst
M doc/index.rst
M doc/pipeline.rst
A doc/python.rst
Log Message:
Commit: cbf3982f84510d6846a6a49e53460570129354c2
https://github.com/PDAL/PDAL/commit/cbf3982f84510d6846a6a49e53460570129354c2
Date: 2017-03-20 (Mon, 20 Mar 2017)
Changed paths:
Log Message:
Attempt to succeed poorly rather than fail ugly when we can't load filters.hexbin for pdal info --boundary and pdal tindex #1532 (#1533)
Commit: 05097a9d7776990a445dbf8fc5c470d14a7dedea
https://github.com/PDAL/PDAL/commit/05097a9d7776990a445dbf8fc5c470d14a7dedea
Changed paths:
M plugins/mbio/test/MBSystemTest.cpp
A test/data/mbio/mbf_em300raw.mb56
Log Message:
Fix mbio test.
Commit: c1c2e4ed5ccf25d512d4cf85d49de1ede0b57037
https://github.com/PDAL/PDAL/commit/c1c2e4ed5ccf25d512d4cf85d49de1ede0b57037
Changed paths:
Log Message:
Commit: 090862ba06e1b7391fe93230c9e323426f035126
https://github.com/PDAL/PDAL/commit/090862ba06e1b7391fe93230c9e323426f035126
Changed paths:
M doc/about.rst
M doc/api/index.rst
M doc/faq.rst
A doc/images/las-reproject-pgpointcloud.png
M doc/index.rst
M doc/workshop/exercises/info/metadata.rst
Log Message:
doc updates (about page, fix links)
Commit: 5f59374ac5a49aef4083a2de1a97dcd9381f281c
https://github.com/PDAL/PDAL/commit/5f59374ac5a49aef4083a2de1a97dcd9381f281c
Changed paths:
M doc/about.rst
M doc/development/integration.rst
M doc/stages/readers.las.rst
M doc/stages/readers.nitf.rst
M doc/stages/readers.ply.rst
M doc/stages/readers.pts.rst
Log Message:
doc updates (whitespace, small updates)
Commit: c0530ca140645717b236843bf889e487f7e2800a
https://github.com/PDAL/PDAL/commit/c0530ca140645717b236843bf889e487f7e2800a
Changed paths:
M doc/about.rst
M doc/pipeline.rst
M doc/tutorial/index.rst
A doc/tutorial/las.rst
M doc/workshop/includes/substitutions.rst
Log Message:
doc updates (start on LAS tutorial)
Commit: 6fff0adcd8ea9b44a1302edb14c5a14abc036a0c
https://github.com/PDAL/PDAL/commit/6fff0adcd8ea9b44a1302edb14c5a14abc036a0c
Changed paths:
M doc/about.rst
A doc/development/overview.rst
A doc/development/pipeline.png
R doc/tutorial/overview.rst
R doc/tutorial/pipeline.png
Log Message:
Doc updates.
Commit: 6254f666e94c8e569e3871d88eef23b43a949019
https://github.com/PDAL/PDAL/commit/6254f666e94c8e569e3871d88eef23b43a949019
Date: 2017-03-22 (Wed, 22 Mar 2017)
Changed paths:
M doc/tutorial/las.rst
Log Message:
doc updates (LAS tutorial, (c) date)
Commit: 8444ed6e96fa3fe88f0a19b2ac32b6b1c993e480
https://github.com/PDAL/PDAL/commit/8444ed6e96fa3fe88f0a19b2ac32b6b1c993e480
Changed paths:
M vendor/arbiter/arbiter.cpp
Log Message:
Update arbiter bundle for more certificate configuration hooks.
Commit: f7fbbdc9e7de5fba4919310e8b133a0b4e394863
https://github.com/PDAL/PDAL/commit/f7fbbdc9e7de5fba4919310e8b133a0b4e394863
Date: 2017-03-24 (Fri, 24 Mar 2017)
Changed paths:
M filters/PMFFilter.cpp
M filters/PMFFilter.hpp
M test/unit/EigenTest.cpp
Log Message:
Accelerate morphological operations
filters.pmf and filters.smrf both spend a majority of their time in the
morphological operations (erosion and dilation). As it turns out, we don't gain
much by using Eigen to implement these either. By storing our matrices as
vectors in column-major order, and refactoring the erosion and dilation
functions slightly, we have achieved speedups of greater than 2x for both
filters.
We also had a bug in SMRF, as the erosion and dilation steps were reversed in
the net cutting procedure.
Finally, we have added some additional tests for both erosion and dilation.
Commit: 5ced8979c54fdb268ae46d04e7fcc67c33aa95c6
https://github.com/PDAL/PDAL/commit/5ced8979c54fdb268ae46d04e7fcc67c33aa95c6
Changed paths:
Log Message:
Missing include for back_inserter
Commit: 8937663c2748832c79202fb62712838ac44971b4
https://github.com/PDAL/PDAL/commit/8937663c2748832c79202fb62712838ac44971b4
Changed paths:
Log Message:
Export the new erosion and dilation functions
Commit: 0623cfdf38d4bdc18814488ab84bd4d52d0013c0
https://github.com/PDAL/PDAL/commit/0623cfdf38d4bdc18814488ab84bd4d52d0013c0
Changed paths:
M pdal/Stage.cpp
Log Message:
Don't infinite-loop on zero-point StreamPointTable execution.
Commit: 6b3df6620d9ba98a8bcb8e71a8b3fea59b987066
https://github.com/PDAL/PDAL/commit/6b3df6620d9ba98a8bcb8e71a8b3fea59b987066
Author: Éric Lemoine <eric.lemoine at gmail.com>
Date: 2017-03-25 (Sat, 25 Mar 2017)
Changed paths:
M plugins/pgpointcloud/io/PgWriter.cpp
Log Message:
Fix PgWriter DROP TABLE statement (#1540)
When a schema is specified the following statement is currently issued:
DROP TABLE IF EXISTS "public.table_name"
which is not correct. With this patch the following statement is created:
DROP TABLE IF EXISTS "public"."table_name"
Commit: fc0e332abbcc5b47cc38b9f199f8ffe6dc3fa341
https://github.com/PDAL/PDAL/commit/fc0e332abbcc5b47cc38b9f199f8ffe6dc3fa341
Changed paths:
M io/LasWriter.cpp
M io/LasWriter.hpp
M test/unit/CMakeLists.txt
Log Message:
Allow user-settable VLRs in writers.las (#1542)
* Allow user-settable VLRs in writers.las
* add PDAL_JSONCPP_INCLUDE_DIR for PRIVATE includes for many tests
Commit: 5e3c222cbd468788f90d796705eb63b389943db2
https://github.com/PDAL/PDAL/commit/5e3c222cbd468788f90d796705eb63b389943db2
Date: 2017-03-27 (Mon, 27 Mar 2017)
Changed paths:
Log Message:
Merge pull request #1541 from PDAL/faster-morphology
Commit: 2969f8931fd4ceb626978310ccbb859ea959194d
https://github.com/PDAL/PDAL/commit/2969f8931fd4ceb626978310ccbb859ea959194d
Author: Weston Renoud <wrenoud at gmail.com>
Changed paths:
M doc/stages/filters.sort.rst
M filters/SortFilter.cpp
M filters/SortFilter.hpp
M pdal/PointViewIter.hpp
M test/unit/filters/SortFilterTest.cpp
Log Message:
Add sort order option, with new descending sort #1121 (#1530)
* Add sort order Option, with new descending (largest to smallest) sort #1121
Default behavior remains unchanged.
This includes unittests and documentation updates.
* reformat sort filter to follow style guide
* undue change to sort filter test interations
I'm unsure if there is a reason for the number of iterations.
* better handling of unknown options for sort
per suggestion from @abellgithub
* wrong out text for SortOrder enum
* switch sort filter to std::stable_sort
needed a default constructor for pdal::PointViewIter
* update sort filter description in documentation
* bug exposed when trying to use std::stable_sort with the SortFilter
Commit: 194e285a74a871b5a013882c9521825189275372
https://github.com/PDAL/PDAL/commit/194e285a74a871b5a013882c9521825189275372
Changed paths:
M doc/development/compilation/index.rst
Log Message:
doc updates (las tutorial)
Commit: 5ead5cb042e0c598f22c107a811c70bff22c61d3
https://github.com/PDAL/PDAL/commit/5ead5cb042e0c598f22c107a811c70bff22c61d3
Date: 2017-03-29 (Wed, 29 Mar 2017)
Changed paths:
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Stage.cpp
Log Message:
Commit: bb7ffbbbf92a6bb98748b5a3bafd407841f85cd4
https://github.com/PDAL/PDAL/commit/bb7ffbbbf92a6bb98748b5a3bafd407841f85cd4
Changed paths:
M plugins/pgpointcloud/test/PgpointcloudWriterTest.cpp
Log Message:
Add a pgpointcloud test for the overwrite option (#1543)
This follows up on #1540.
Commit: 923ed6e75fec225a668eb18334e834a8e17b329b
https://github.com/PDAL/PDAL/commit/923ed6e75fec225a668eb18334e834a8e17b329b
Changed paths:
M doc/stages/writers.oci.rst
M plugins/oci/io/OciWriter.cpp
M plugins/oci/io/OciWriter.hpp
Log Message:
Allow setting 'tolerance' for oracle geometry tolerance in writers.oci #810 (#1544)
Commit: 98fb1b27b6433732fe716948f9dd867d2208ca1c
https://github.com/PDAL/PDAL/commit/98fb1b27b6433732fe716948f9dd867d2208ca1c
Changed paths:
M LICENSE.txt
Log Message:
update (c) to 2017
Commit: f13967d6bd294be1760f301fab14bd1e6694fe74
https://github.com/PDAL/PDAL/commit/f13967d6bd294be1760f301fab14bd1e6694fe74
Changed paths:
M plugins/nitf/CMakeLists.txt
Log Message:
NITF build config for JSON include dirs
Commit: 2ab518a020d51c1ac45ee9f2c51889c3831520de
https://github.com/PDAL/PDAL/commit/2ab518a020d51c1ac45ee9f2c51889c3831520de
Date: 2017-03-30 (Thu, 30 Mar 2017)
Changed paths:
Log Message:
Update metadata doc.
Commit: fea91d41c41cb3c7428ecf04f0cdbaaeb43dee96
https://github.com/PDAL/PDAL/commit/fea91d41c41cb3c7428ecf04f0cdbaaeb43dee96
Changed paths:
M LICENSE.txt
Log Message:
Commit: e8fb59bfe253f57bb990c8f1ae8fddd84281110c
https://github.com/PDAL/PDAL/commit/e8fb59bfe253f57bb990c8f1ae8fddd84281110c
Changed paths:
M filters/OutlierFilter.cpp
M filters/OutlierFilter.hpp
M pdal/Segmentation.cpp
M pdal/Segmentation.hpp
Log Message:
Updating outlier, PMF, and SMRF filters
It is desirable to exclude noise points from further processing, as well as
anything but last returns (i.e., return number equals number of returns).
Although this can be accomplished with various other filters, we currently
require that those points be dropped from the PointView if we wanted to exclude
them from the bare earth filters. Provide a mechanism for segmenting last
returns and ignoring an optional, user-defined DimRange. Apply this to both
SMRF and PMF. This allows us to set them aside for the filtering step, without
losing them altogether.
This also marks the first point at which we remove the "extract" and "classify"
options from the PMF and outlier filters. Ground/noise points will always be
classified, but not extracted. Users wishing to extract ground or noise returns
should use the range filter as a downstream processing step.
The outlier filter now allows the user to specify the class they would like to
use for noise points. The default value for noise points has been changed from
18 to 7.
Finally, the outlier filter now uses online updates when computing mean,
variance, and standard deviation.
Commit: faba4c42c52dfe4f7340ade145a6455cf5a3ad0b
https://github.com/PDAL/PDAL/commit/faba4c42c52dfe4f7340ade145a6455cf5a3ad0b
Changed paths:
Log Message:
Don't fail if ignore option is unspecified, just use the input PointView
Commit: e4834bef90c066215ade073d6393eeaaa276bdee
https://github.com/PDAL/PDAL/commit/e4834bef90c066215ade073d6393eeaaa276bdee
Changed paths:
M test/unit/OldPCLBlockTest.cpp
Log Message:
Append individual views to a single output view, rather than inserting into the
viewSet. Fixup tests.
Commit: 32b8475cdfac7afc4ccc869210e26e3359253983
https://github.com/PDAL/PDAL/commit/32b8475cdfac7afc4ccc869210e26e3359253983
Changed paths:
Log Message:
Don't fail when return information is missing. Just use all returns, but warn the user.
Commit: f7f149d2b1a154d10e737bde8ebdf9d8419d1e09
https://github.com/PDAL/PDAL/commit/f7f149d2b1a154d10e737bde8ebdf9d8419d1e09
Changed paths:
Log Message:
doc typo
Commit: 8b8d95429ca74edd36a17fd3994eb8f7d465d4ee
https://github.com/PDAL/PDAL/commit/8b8d95429ca74edd36a17fd3994eb8f7d465d4ee
Changed paths:
M io/LasReader.cpp
M io/LasWriter.cpp
A test/data/las/spec_3.las
Log Message:
Forward VLR LASF_Spec/0 and LASF_Spec/3
Close #1547
Commit: ac61a607ff8625530b4faefc51489dd13baaf472
https://github.com/PDAL/PDAL/commit/ac61a607ff8625530b4faefc51489dd13baaf472
Changed paths:
M doc/stages/filters.predicate.rst
M doc/stages/filters.programmable.rst
M pdal/plang/Invocation.cpp
M pdal/plang/Invocation.hpp
M plugins/python/CMakeLists.txt
M plugins/python/filters/CMakeLists.txt
M plugins/python/filters/PredicateFilter.cpp
M plugins/python/filters/PredicateFilter.hpp
M plugins/python/filters/ProgrammableFilter.cpp
M plugins/python/filters/ProgrammableFilter.hpp
M plugins/python/test/ProgrammableFilterTest.cpp
Log Message:
Implement 'pdalargs' option for filters.predicate and filters.programmable to allow users to pass in a dictionary of arguments to the module #931 (#1546)
* Implement 'pdalargs' option for filters.predicate and filters.programmable to allow users to pass in a dictionary of arguments to the module #931
* fix up tests
Commit: af5068a3faf3cf140059902ed66c41cf413423ba
https://github.com/PDAL/PDAL/commit/af5068a3faf3cf140059902ed66c41cf413423ba
Date: 2017-03-31 (Fri, 31 Mar 2017)
Changed paths:
Log Message:
Merge pull request #1545 from PDAL/pmf-smrf-outlier-changes
Commit: 66f6de22b9a94c4d6c6af4473c5ec52031ed93f2
https://github.com/PDAL/PDAL/commit/66f6de22b9a94c4d6c6af4473c5ec52031ed93f2
Changed paths:
R cmake/examples/mpg-config.bat
R cmake/examples/pramsey-config.sh
Log Message:
remove outdated cmake examples
Commit: 317803ae559a6d2498177771861d8e068b8d344d
https://github.com/PDAL/PDAL/commit/317803ae559a6d2498177771861d8e068b8d344d
Changed paths:
M .travis.yml
M CMakeLists.txt
M python/VERSION.txt
M python/pdal/__init__.py
Log Message:
increment versions in preparation for 1.5.0 release
Commit: 9a42694b5e31b6457b2a957abc92d88c2c398ebb
https://github.com/PDAL/PDAL/commit/9a42694b5e31b6457b2a957abc92d88c2c398ebb
Changed paths:
Log Message:
remove redundant 'override' declaration in filters.sort
Commit: bd03920c181e8a83d49b290632e96a162bfc1444
https://github.com/PDAL/PDAL/commit/bd03920c181e8a83d49b290632e96a162bfc1444
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into release-ready
Commit: 730821143ce82796c798c020b07e02a926109b78
https://github.com/PDAL/PDAL/commit/730821143ce82796c798c020b07e02a926109b78
Date: 2017-04-03 (Mon, 03 Apr 2017)
Changed paths:
M io/LasWriter.cpp
Log Message:
initialize a loop variable to prevent returning uninitialzed data
Commit: f5cb1e65421234662734bab11e11a374b6cc64fd
https://github.com/PDAL/PDAL/commit/f5cb1e65421234662734bab11e11a374b6cc64fd
Changed paths:
M plugins/mbio/CMakeLists.txt
Log Message:
mbsystem cmake is case-sensitive
Commit: 67630280f7b2289a6804decace010a88445ad823
https://github.com/PDAL/PDAL/commit/67630280f7b2289a6804decace010a88445ad823
Changed paths:
Log Message:
build mbio and CPD by default in Docker build
Commit: f4cc476f6aca2c3b47157cea4f4413107c2f5f94
https://github.com/PDAL/PDAL/commit/f4cc476f6aca2c3b47157cea4f4413107c2f5f94
Changed paths:
M scripts/docker/dependencies/Dockerfile
Log Message:
add mbio and hauru to dependencies
Commit: 3e98d50ddc37add6a927036df98dead63031d341
https://github.com/PDAL/PDAL/commit/3e98d50ddc37add6a927036df98dead63031d341
Author: Bas Couwenberg <sebastic at xs4all.nl>
Changed paths:
M cmake/laszip.cmake
Log Message:
Fix build failure without LASzip. (#1549)
Commit: fd72f8812a429fcf2d4fec4ba8a13cc847bf3aa6
https://github.com/PDAL/PDAL/commit/fd72f8812a429fcf2d4fec4ba8a13cc847bf3aa6
Changed paths:
Log Message:
Fix LASZIP_LASZIP_DEFINES typo (#1550)
Replace LASZIP_LASZIP_DEFINES with LASZIP_DEFINES
Commit: a1368f08fa183db61852283c56c1fe301d9b4daa
https://github.com/PDAL/PDAL/commit/a1368f08fa183db61852283c56c1fe301d9b4daa
Changed paths:
Log Message:
Commit: effed6214684bc9ad252bba2b9ca62a8712148a8
https://github.com/PDAL/PDAL/commit/effed6214684bc9ad252bba2b9ca62a8712148a8
Changed paths:
M io/LasWriter.cpp
Log Message:
Edits to LAS tutorial.
Don't allow oversize VLRs when writing LAS 1.0 - 1.3
Close #1551
Commit: 0d03c5af0cc09edc526b505407713adb4bcd9bc5
https://github.com/PDAL/PDAL/commit/0d03c5af0cc09edc526b505407713adb4bcd9bc5
Changed paths:
M io/LasWriter.cpp
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/46a3caced20e...0d03c5af0cc0
More information about the pdal-commits
