[pdal-commits] [PDAL/PDAL] c9216d: Add Extended Local Maximum (ELM) filter
GitHub
noreply at github.com
Thu Apr 6 13:32:00 PDT 2017
Branch: refs/heads/release-ready
Home: https://github.com/PDAL/PDAL
Commit: c9216dfdd07f6c316130318628a1ba9df1695fdd
https://github.com/PDAL/PDAL/commit/c9216dfdd07f6c316130318628a1ba9df1695fdd
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-04-05 (Wed, 05 Apr 2017)
Changed paths:
M doc/references.rst
A doc/stages/filters.elm.rst
A filters/ELMFilter.cpp
A filters/ELMFilter.hpp
M pdal/StageFactory.cpp
Log Message:
Based off the work of Chen, et al. In the original work, the authors used ELM
to generate grid minimums that were resistent to low outliers in ground
segmentation and DTM generation. We implement here as a standalone filter that
simply marks the low points as noise. Downstream filtering stages can ignore,
extract, or handle these noise points as they see fit.
Commit: eb1e3ff9fc3fd65a55b5075d5fc388e9cd111eff
https://github.com/PDAL/PDAL/commit/eb1e3ff9fc3fd65a55b5075d5fc388e9cd111eff
Author: chambbj <brad.chambers at gmail.com>
Date: 2017-04-06 (Thu, 06 Apr 2017)
Changed paths:
Log Message:
Merge pull request #1554 from PDAL/add-elm-filter
Commit: f7a56630d3c37ec6cf080cad0a7b1759cfa79bdc
https://github.com/PDAL/PDAL/commit/f7a56630d3c37ec6cf080cad0a7b1759cfa79bdc
Author: Connor Manning <connormanning at users.noreply.github.com>
Changed paths:
M io/LasReader.cpp
M test/unit/io/LasReaderTest.cpp
Log Message:
Preserve well-known, but non-standard to LAS, dimension IDs when written as extra_dims. (#1555)
Commit: 505acf9808da16b24843e1774807e1ec338edc25
https://github.com/PDAL/PDAL/commit/505acf9808da16b24843e1774807e1ec338edc25
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M io/PlyWriter.cpp
Log Message:
Get type from layout -- don't use default type.
Close #1556
Commit: 90acdc335d3b18e60004cacc8b91033941448d76
https://github.com/PDAL/PDAL/commit/90acdc335d3b18e60004cacc8b91033941448d76
Author: Howard Butler <howard at hobu.co>
Changed paths:
M io/PlyWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into release-ready
Compare: https://github.com/PDAL/PDAL/compare/8e22916871d2...90acdc335d3b
More information about the pdal-commits
