[pdal-commits] [PDAL/PDAL] 66f6de: remove outdated cmake examples
GitHub
noreply at github.com
Thu Apr 13 12:40:55 PDT 2017
Branch: refs/heads/windows-packaging
Home: https://github.com/PDAL/PDAL
Commit: 66f6de22b9a94c4d6c6af4473c5ec52031ed93f2
https://github.com/PDAL/PDAL/commit/66f6de22b9a94c4d6c6af4473c5ec52031ed93f2
Author: Howard Butler <howard at hobu.co>
Date: 2017-03-31 (Fri, 31 Mar 2017)
Changed paths:
R cmake/examples/mpg-config.bat
R cmake/examples/pramsey-config.sh
Log Message:
Commit: 317803ae559a6d2498177771861d8e068b8d344d
https://github.com/PDAL/PDAL/commit/317803ae559a6d2498177771861d8e068b8d344d
Changed paths:
M .travis.yml
M CMakeLists.txt
M python/VERSION.txt
M python/pdal/__init__.py
Log Message:
increment versions in preparation for 1.5.0 release
Commit: 9a42694b5e31b6457b2a957abc92d88c2c398ebb
https://github.com/PDAL/PDAL/commit/9a42694b5e31b6457b2a957abc92d88c2c398ebb
Changed paths:
M filters/SortFilter.hpp
Log Message:
remove redundant 'override' declaration in filters.sort
Commit: bd03920c181e8a83d49b290632e96a162bfc1444
https://github.com/PDAL/PDAL/commit/bd03920c181e8a83d49b290632e96a162bfc1444
Changed paths:
M filters/OutlierFilter.cpp
M filters/OutlierFilter.hpp
M filters/PMFFilter.cpp
M filters/PMFFilter.hpp
M filters/SMRFilter.cpp
M filters/SMRFilter.hpp
M pdal/Segmentation.cpp
M pdal/Segmentation.hpp
M test/unit/OldPCLBlockTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into release-ready
Commit: 730821143ce82796c798c020b07e02a926109b78
https://github.com/PDAL/PDAL/commit/730821143ce82796c798c020b07e02a926109b78
Date: 2017-04-03 (Mon, 03 Apr 2017)
Changed paths:
M io/LasWriter.cpp
Log Message:
initialize a loop variable to prevent returning uninitialzed data
Commit: f5cb1e65421234662734bab11e11a374b6cc64fd
https://github.com/PDAL/PDAL/commit/f5cb1e65421234662734bab11e11a374b6cc64fd
Changed paths:
M plugins/mbio/CMakeLists.txt
Log Message:
mbsystem cmake is case-sensitive
Commit: 67630280f7b2289a6804decace010a88445ad823
https://github.com/PDAL/PDAL/commit/67630280f7b2289a6804decace010a88445ad823
Changed paths:
M scripts/docker/Dockerfile
Log Message:
build mbio and CPD by default in Docker build
Commit: f4cc476f6aca2c3b47157cea4f4413107c2f5f94
https://github.com/PDAL/PDAL/commit/f4cc476f6aca2c3b47157cea4f4413107c2f5f94
Changed paths:
M scripts/docker/dependencies/Dockerfile
Log Message:
add mbio and hauru to dependencies
Commit: a1368f08fa183db61852283c56c1fe301d9b4daa
https://github.com/PDAL/PDAL/commit/a1368f08fa183db61852283c56c1fe301d9b4daa
Changed paths:
M cmake/laszip.cmake
Log Message:
Commit: 0d03c5af0cc09edc526b505407713adb4bcd9bc5
https://github.com/PDAL/PDAL/commit/0d03c5af0cc09edc526b505407713adb4bcd9bc5
Changed paths:
M doc/tutorial/las.rst
M io/LasWriter.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Commit: 1c20b2552e50ad5f14383b031934cb15c16ebf7d
https://github.com/PDAL/PDAL/commit/1c20b2552e50ad5f14383b031934cb15c16ebf7d
Date: 2017-04-05 (Wed, 05 Apr 2017)
Changed paths:
M doc/development/docs.rst
Log Message:
docs about building docs
Commit: 7209899fa1091a6c0e17c0ed6c005f833a708ac3
https://github.com/PDAL/PDAL/commit/7209899fa1091a6c0e17c0ed6c005f833a708ac3
Changed paths:
R scripts/vagrant/loadpgpointcloud.xml
R scripts/vagrant/readpgpointcloud.xml
Log Message:
remove dead stuff
Commit: 1dad94c68a0c342324fdae5ef56417064787e103
https://github.com/PDAL/PDAL/commit/1dad94c68a0c342324fdae5ef56417064787e103
Changed paths:
R scripts/docker/Dockerfile.xenial
Log Message:
remove dead dockerfile
Commit: 4e1e5f92406d703465355a3120315c555700dbda
https://github.com/PDAL/PDAL/commit/4e1e5f92406d703465355a3120315c555700dbda
Changed paths:
M doc/about.rst
M doc/apps/density.rst
M doc/community.rst
M doc/development/compilation/unix.rst
M doc/download.rst
M doc/index.rst
Log Message:
doc updates in preparation for 1.5.0
Commit: f09cf4e2ce4a384d4aefe51e31240d7d4093f249
https://github.com/PDAL/PDAL/commit/f09cf4e2ce4a384d4aefe51e31240d7d4093f249
Changed paths:
M doc/development/docker.rst
Log Message:
pdal docker docs
Commit: 8a22494cf4dd17f9cbac85829edc7c60342b7b48
https://github.com/PDAL/PDAL/commit/8a22494cf4dd17f9cbac85829edc7c60342b7b48
Date: 2017-04-06 (Thu, 06 Apr 2017)
Changed paths:
M doc/references.rst
A doc/stages/filters.elm.rst
A filters/ELMFilter.cpp
A filters/ELMFilter.hpp
M pdal/StageFactory.cpp
Log Message:
Add Extended Local Maximum (ELM) filter
Based off the work of Chen, et al. In the original work, the authors used ELM
to generate grid minimums that were resistent to low outliers in ground
segmentation and DTM generation. We implement here as a standalone filter that
simply marks the low points as noise. Downstream filtering stages can ignore,
extract, or handle these noise points as they see fit.
Commit: 8e22916871d2d0c7ed81f4b35ecba65371a36250
https://github.com/PDAL/PDAL/commit/8e22916871d2d0c7ed81f4b35ecba65371a36250
Changed paths:
M io/LasReader.cpp
M test/unit/io/LasReaderTest.cpp
Log Message:
Squashed commit of the following:
commit f7a56630d3c37ec6cf080cad0a7b1759cfa79bdc
Author: Connor Manning <connormanning at users.noreply.github.com>
Date: Thu Apr 6 08:55:01 2017 -0500
Preserve well-known, but non-standard to LAS, dimension IDs when written as extra_dims. (#1555)
commit eb1e3ff9fc3fd65a55b5075d5fc388e9cd111eff
Merge: effed6214 c9216dfdd
Author: chambbj <brad.chambers at gmail.com>
Date: Thu Apr 6 08:15:13 2017 -0400
Merge pull request #1554 from PDAL/add-elm-filter
commit c9216dfdd07f6c316130318628a1ba9df1695fdd
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: Wed Apr 5 16:22:42 2017 -0400
Commit: 0471a27411ccf00ce1e72e942a3159eb81f88ce5
https://github.com/PDAL/PDAL/commit/0471a27411ccf00ce1e72e942a3159eb81f88ce5
Changed paths:
M io/PlyWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into windows-packaging
Commit: a28c7e5aad7f45f4e2d765527089ba55119dd202
https://github.com/PDAL/PDAL/commit/a28c7e5aad7f45f4e2d765527089ba55119dd202
Date: 2017-04-12 (Wed, 12 Apr 2017)
Changed paths:
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Commit: 24736d867f6f04df36029a784fb61da9a2a90f30
https://github.com/PDAL/PDAL/commit/24736d867f6f04df36029a784fb61da9a2a90f30
Changed paths:
Log Message:
Commit: bf9a3252ab8e7e8c8d58a45fbc40d098fec14f40
https://github.com/PDAL/PDAL/commit/bf9a3252ab8e7e8c8d58a45fbc40d098fec14f40
Date: 2017-04-13 (Thu, 13 Apr 2017)
Changed paths:
M cmake/examples/hobu-windows.bat
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/bounds.hpp
M plugins/greyhound/io/point.hpp
M plugins/sqlite/io/SQLiteCommon.hpp
M vendor/arbiter/CMakeLists.txt
Log Message:
windows wip
Compare: https://github.com/PDAL/PDAL/compare/66f6de22b9a9^...bf9a3252ab8e
More information about the pdal-commits
