[pdal-commits] [PDAL/PDAL] 8f9c89: Resolve some dangling references to deprecated ext...
GitHub
noreply at github.com
Mon Apr 17 07:05:30 PDT 2017
Branch: refs/heads/issue/1566-filter-docs
Home: https://github.com/PDAL/PDAL
Commit: 8f9c895b47ae8525ddaa779f4054510b8b171e5b
https://github.com/PDAL/PDAL/commit/8f9c895b47ae8525ddaa779f4054510b8b171e5b
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-04-17 (Mon, 17 Apr 2017)
Changed paths:
M doc/apps/translate.rst
M doc/pipeline.rst
M doc/stages/filters.outlier.rst
M doc/stages/filters.pmf.rst
M doc/workshop/exercises/analysis/denoising/denoise.json
M doc/workshop/exercises/analysis/denoising/denoising.rst
M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
M doc/workshop/exercises/analysis/ground/ground.rst
M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
Log Message:
Resolve some dangling references to deprecated extract and classify options
extract and classify have been used in several filters, namely outlier and PMF.
With the release of PDAL v1.5, we removed these options, opting to always
classify points, and to force users to ignore or extract them as they see fit
in their pipelines.
The outlier filter's extract option can be replicated by adding a range filter
stage as shown following the outlier filter:
"type":"filters.range",
"limits":"Classification![7:7]"
The PMF filter's extract option can be replicated by adding the following range
filter:
"limits":"Classification[2:2]"
The intention here was to remove any ambiguity as to how individual filters
implement "extract", and to instead be explicit in the pipeline specification
as to how points are extracted.
More information about the pdal-commits
