[pdal-commits] [PDAL/PDAL] 341ece: Add note to docs about pgpointcloud tests
GitHub
noreply at github.com
Thu Apr 20 07:12:25 PDT 2017
Branch: refs/heads/1.5-maintenance
Home: https://github.com/PDAL/PDAL
Commit: 341ece4cdd11f455b6152cc0e6be98e4984899b1
https://github.com/PDAL/PDAL/commit/341ece4cdd11f455b6152cc0e6be98e4984899b1
Author: Éric Lemoine <eric.lemoine at oslandia.com>
Date: 2017-04-20 (Thu, 20 Apr 2017)
Changed paths:
M doc/development/testing.rst
Log Message:
Commit: 72f8e270a1f16857e8ea29886b0204957e94068f
https://github.com/PDAL/PDAL/commit/72f8e270a1f16857e8ea29886b0204957e94068f
Author: Howard Butler <howard at hobu.co>
Changed paths:
M doc/apps/translate.rst
M doc/pipeline.rst
M doc/stages/filters.outlier.rst
M doc/stages/filters.pmf.rst
M doc/workshop/exercises/analysis/denoising/denoise.json
M doc/workshop/exercises/analysis/denoising/denoising.rst
M doc/workshop/exercises/analysis/ground/ground-run-ground-only.txt
M doc/workshop/exercises/analysis/ground/ground.rst
M doc/workshop/exercises/analysis/ground/translate-run-ground-only.txt
Log Message:
Merge branch '1.5-maintenance' of github.com:PDAL/PDAL into 1.5-maintenance
Compare: https://github.com/PDAL/PDAL/compare/4ed1a6c3b38c...72f8e270a1f1
More information about the pdal-commits
