[pdal-commits] [PDAL/PDAL] 166351: Add example for PowerShell.
GitHub
noreply at github.com
Thu Dec 28 18:15:27 PST 2017
Branch: refs/heads/inline-dimdetail-pointlayout
Home: https://github.com/PDAL/PDAL
Commit: 16635110fcc14a57638c78ee343277c5e7aa3e56
https://github.com/PDAL/PDAL/commit/16635110fcc14a57638c78ee343277c5e7aa3e56
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-11-20 (Mon, 20 Nov 2017)
Changed paths:
M doc/tutorial/reading.rst
Log Message:
Commit: 172a92810aaec895a133496e9d303ac3e8a36fce
https://github.com/PDAL/PDAL/commit/172a92810aaec895a133496e9d303ac3e8a36fce
Date: 2017-11-21 (Tue, 21 Nov 2017)
Changed paths:
M doc/apps/translate.rst
Log Message:
Fix a couple of typos.
Commit: ab2e0b18ee8413992075593355ebb8e8ef435e90
https://github.com/PDAL/PDAL/commit/ab2e0b18ee8413992075593355ebb8e8ef435e90
Changed paths:
M pdal/Kernel.hpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
A test/data/apps/bad_cmd_opt
A test/data/apps/bad_json_opt
A test/data/apps/good_cmd_opt
A test/data/apps/good_json_opt
M test/unit/apps/AppTest.cpp
M test/unit/apps/TranslateTest.cpp
Log Message:
Option file (#1728)
* Add support for stage option files.
* Remove test code.
* Add JSON option file.
* Add tests form option_file.
Add grid_option_file option.
* Make sure there's no "foo.las" sitting around.
Commit: 87986c5afdfdaf49b64a7bbc9696aa36124c5689
https://github.com/PDAL/PDAL/commit/87986c5afdfdaf49b64a7bbc9696aa36124c5689
Changed paths:
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Make sure we don't write LASzip VLRs more than once. (#1726)
Make LasHeader::findVlr const.
Commit: 348eb7b74da02fb43ab64062fd4d8a83679d247d
https://github.com/PDAL/PDAL/commit/348eb7b74da02fb43ab64062fd4d8a83679d247d
Changed paths:
M doc/conf.py
M doc/download.rst
M doc/rtd_theme/footer.html
M doc/workshop/osgeo4w.rst
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/Kernel.hpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: a3ece8ee7a1f1c43715eea4d0f9e707b88891c42
https://github.com/PDAL/PDAL/commit/a3ece8ee7a1f1c43715eea4d0f9e707b88891c42
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-11-22 (Wed, 22 Nov 2017)
Changed paths:
M doc/stages/writers.pcd.rst
Log Message:
Update PCD Writer documentation to reflect new options
Commit: 4f595c248ce9b1870b47f1666c456dd45e0474a2
https://github.com/PDAL/PDAL/commit/4f595c248ce9b1870b47f1666c456dd45e0474a2
Author: Howard Butler <howard at hobu.co>
Date: 2017-11-26 (Sun, 26 Nov 2017)
Changed paths:
M cmake/examples/hobu-windows.bat
M cmake/modules/FindZSTD.cmake
M scripts/appveyor/config.cmd
Log Message:
Get windows happy (#1734)
* be explict about LIBLZMA_LIBRARY for windows
* don't override LIBRARY_SUFFIX in FindZSTD
Commit: a61011d3ffd33e5cdb786f2816b629b4dd411102
https://github.com/PDAL/PDAL/commit/a61011d3ffd33e5cdb786f2816b629b4dd411102
Author: Kristian Evers <kristianevers at gmail.com>
Changed paths:
M python/setup.py
Log Message:
Fix python install (#1733)
* Don't import Cython directly before doing a fail-safe import of the same module
* Add install requirements to Python setup script
Commit: a36bc1e281f9d776ea85b0187e19a68ef3ffb00b
https://github.com/PDAL/PDAL/commit/a36bc1e281f9d776ea85b0187e19a68ef3ffb00b
Date: 2017-11-30 (Thu, 30 Nov 2017)
Changed paths:
M python/setup.py
Log Message:
Commit: 88b102eaeb8f774c37b1eb8071bc9ac1bdd4d55e
https://github.com/PDAL/PDAL/commit/88b102eaeb8f774c37b1eb8071bc9ac1bdd4d55e
Changed paths:
M filters/ColorizationFilter.cpp
M io/BpfReader.cpp
M io/LasReader.cpp
M io/OGRWriterV1.cpp
M io/PlyReader.cpp
Log Message:
Misc. formatting/doc fixes.
Commit: 813caf8b2c73cb29d1bacb056c20bb0e20865921
https://github.com/PDAL/PDAL/commit/813caf8b2c73cb29d1bacb056c20bb0e20865921
Changed paths:
M cmake/lzma.cmake
M cmake/zlib.cmake
M cmake/zstd.cmake
M io/BpfCompressor.cpp
M io/BpfCompressor.hpp
M io/BpfReader.cpp
M io/BpfWriter.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
R pdal/Compression.hpp
A pdal/compression/Compression.hpp
A pdal/compression/DeflateCompression.hpp
A pdal/compression/LazPerfCompression.hpp
A pdal/compression/LzmaCompression.hpp
A pdal/compression/ZstdCompression.hpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/oci/io/OciReader.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/pgpointcloud/io/PgCommon.hpp
M plugins/sqlite/io/SQLiteCommon.hpp
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M test/unit/CompressionTest.cpp
M test/unit/io/BPFTest.cpp
Log Message:
Compression (#1736)
* Add general deflate/LZMA support.
* Add lzma cmake file
* Add xz to dockerfile.
* Try xz-dev.
* Put xz in the right list.
* Modify travis build script for xz(lzma) compression.
* Update Dockerfile for xz(lzma)
* Use proper casting to avoid warnings on Linux.
* Make interface consistent for compressors.
* Update SQLite for new compression API.
* Update osgeo4w install to grab xz-devel.
* Add support for zstd compression.
* Add zstd to alpine build.
* Add zstd.
* Add zstd-dev pkg.
* Update docker/build files for zstd.
* Convert LazPerfDecompressor to new interface.
* Update Dockerfile(s) for lzma(xz) and zstd.
* Update compression for GreyhoundReader.
* Made compression modules optional.
* Allow compression types to be optional.
* Provide appropriate defaults for compression options.
Commit: 4a17c4e63f5655bfcbba960ff34b636f8ec0df4d
https://github.com/PDAL/PDAL/commit/4a17c4e63f5655bfcbba960ff34b636f8ec0df4d
Date: 2017-12-07 (Thu, 07 Dec 2017)
Changed paths:
M doc/stages/writers.gdal.rst
M doc/stages/writers.las.rst
Log Message:
Update writers.gdal doc.
Commit: 356f4bd86afbb7ec28b7f3238548379ccfce365a
https://github.com/PDAL/PDAL/commit/356f4bd86afbb7ec28b7f3238548379ccfce365a
Date: 2017-12-12 (Tue, 12 Dec 2017)
Changed paths:
M scripts/docker/1.6-maintenance/alpine/Dockerfile
Log Message:
use external jsoncpp library for alphine builds
Commit: 3fc0c29199aa7272b6c849f83864084ec37b6c7d
https://github.com/PDAL/PDAL/commit/3fc0c29199aa7272b6c849f83864084ec37b6c7d
Date: 2017-12-13 (Wed, 13 Dec 2017)
Changed paths:
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
AWS_SESSION_TOKEN and Google Cloud Storage support in Arbiter sub-library
Commit: c2aeccf8f11a24525cc105b682ba07186d1f8450
https://github.com/PDAL/PDAL/commit/c2aeccf8f11a24525cc105b682ba07186d1f8450
Changed paths:
Log Message:
Revert "AWS_SESSION_TOKEN and Google Cloud Storage support in Arbiter sub-library"
This reverts commit 3fc0c29199aa7272b6c849f83864084ec37b6c7d.
Commit: ea3d86651e3f7c05a44529638ca0604846fc581b
https://github.com/PDAL/PDAL/commit/ea3d86651e3f7c05a44529638ca0604846fc581b
Date: 2017-12-18 (Mon, 18 Dec 2017)
Changed paths:
Log Message:
Commit: 19087bcff40e36b68e180f101c125a6787f8db68
https://github.com/PDAL/PDAL/commit/19087bcff40e36b68e180f101c125a6787f8db68
Author: Loïc Messal <loic.messal at orange.fr>
Changed paths:
M doc/stages/filters.pmf.rst
Log Message:
Typo (#1745)
Commit: 4a5f39346b796e130d1c2d88f212422558b83f07
https://github.com/PDAL/PDAL/commit/4a5f39346b796e130d1c2d88f212422558b83f07
Author: John Wass <jwass3 at gmail.com>
Date: 2017-12-21 (Thu, 21 Dec 2017)
Changed paths:
M pdal/PipelineManager.hpp
Log Message:
expose the stages of a pipeline (#1748)
Commit: f8cc65882cb47d8a9755c80f4b18a40e6c9114e0
https://github.com/PDAL/PDAL/commit/f8cc65882cb47d8a9755c80f4b18a40e6c9114e0
Author: Vicky Vergara <vicky at georepublic.de>
Changed paths:
M appveyor.yml
Log Message:
appveyor: creating artifacts only on branch: 1.6-maintenance (#1752)
Commit: be9f791f8268b530121cef16a0af324caa3a59c4
https://github.com/PDAL/PDAL/commit/be9f791f8268b530121cef16a0af324caa3a59c4
Changed paths:
M filters/ColorinterpFilter.cpp
Log Message:
Remove warning: ignoring return value of VSILFILE* VSIFileFromMemBuffer(....) (#1751)
Commit: 33aca17443d74f1459d67635ae22719c5ba6368c
https://github.com/PDAL/PDAL/commit/33aca17443d74f1459d67635ae22719c5ba6368c
Date: 2017-12-22 (Fri, 22 Dec 2017)
Changed paths:
M appveyor.yml
Log Message:
Commit: 60fd8c73764cbe92eb40baa275bdb1690afaa256
https://github.com/PDAL/PDAL/commit/60fd8c73764cbe92eb40baa275bdb1690afaa256
Changed paths:
M doc/stages/filters.hexbin.rst
Log Message:
Fix documentation for filters.hexbin.
Close #1741
Commit: b4d3bc88a0f91cfac976dfd7a55958dd79635366
https://github.com/PDAL/PDAL/commit/b4d3bc88a0f91cfac976dfd7a55958dd79635366
Changed paths:
M vendor/kazhdan/MultiGridOctreeData.Evaluation.inl
M vendor/kazhdan/MultiGridOctreeData.h
Log Message:
Fix warn misleading indentation when compiling PoissonFilter.cpp (#1755)
Add braces to quiet compiler.
Commit: 988c130f715ca10ff867399ae805c0d04fecc01f
https://github.com/PDAL/PDAL/commit/988c130f715ca10ff867399ae805c0d04fecc01f
Changed paths:
M kernels/TIndexKernel.cpp
Log Message:
Don't assume output from tindex is a LAS file.
Commit: 151a84e9e840e68f59c07c519c0adfb5bfbc260d
https://github.com/PDAL/PDAL/commit/151a84e9e840e68f59c07c519c0adfb5bfbc260d
Date: 2017-12-26 (Tue, 26 Dec 2017)
Changed paths:
M io/LasHeader.cpp
M vendor/kazhdan/Geometry.cpp
Log Message:
Remove warn [-Wcast qual] (#1757)
* fix warning -Wcast-qual when compiling Geometry.cpp
* fix warning -Wcast-qual when compiling LasHeader.cpp
Commit: 3466b590f10d84ec65ef93daff15987ba89545fd
https://github.com/PDAL/PDAL/commit/3466b590f10d84ec65ef93daff15987ba89545fd
Changed paths:
M vendor/kazhdan/MultiGridOctreeData.IsoSurface.inl
M vendor/kazhdan/MultiGridOctreeData.System.inl
M vendor/kazhdan/Octree.inl
Log Message:
Remove warn [-Wmaybe-uninitialized] (#1756)
* fix warning may be used uninitialized when compiling RadialDensityFilter.cpp
* fix warning may be used uninitialized when compiling MultiGridOctreeData.IsoSurface.inl (isneeded varable)
* fix warning may be used uninitialized when compiling SMRFilter.cpp
* fix warning may be used uninitialized when compiling SampleFilter.cpp
Commit: d7db7b3eaefc78709a1ff269d705e28f77e41ae1
https://github.com/PDAL/PDAL/commit/d7db7b3eaefc78709a1ff269d705e28f77e41ae1
Changed paths:
M cmake/unix_compiler_options.cmake
M io/OGRWriter.cpp
M io/OGRWriter.hpp
M pdal/PyArray.hpp
M plugins/matlab/filters/Script.cpp
Log Message:
Warnings to errors on GCC
Quiet more GCC warnings.
Commit: a43046827439cebb456a3b44df6bd118aff7def0
https://github.com/PDAL/PDAL/commit/a43046827439cebb456a3b44df6bd118aff7def0
Date: 2017-12-27 (Wed, 27 Dec 2017)
Changed paths:
M tools/lasdump/Dumper.cpp
Log Message:
Eliminate warnings.
'&' should have been '&&'
Commit: 93064851a8549057f50cabc170f92c0d317c55e1
https://github.com/PDAL/PDAL/commit/93064851a8549057f50cabc170f92c0d317c55e1
Changed paths:
M io/LasHeader.cpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
M pdal/PyArray.hpp
Log Message:
Commit: f717a4ceabf2c23fcb03838945865cd54a4698c7
https://github.com/PDAL/PDAL/commit/f717a4ceabf2c23fcb03838945865cd54a4698c7
Date: 2017-12-28 (Thu, 28 Dec 2017)
Changed paths:
M dimbuilder/DimBuilder.cpp
Log Message:
jsoncpp changed the return signature of removeMember and we need to get the same behavior in two steps now (#1759)
Commit: 76e6e1bf27a73dcdf23594b844a2e745cfe4738c
https://github.com/PDAL/PDAL/commit/76e6e1bf27a73dcdf23594b844a2e745cfe4738c
Changed paths:
M filters/MortonOrderFilter.cpp
M filters/SMRFilter.cpp
M io/GDALReader.cpp
M io/GDALWriter.cpp
M io/OGRWriter.cpp
M io/OptechReader.cpp
M io/PlyReader.cpp
M pdal/EigenUtils.hpp
M pdal/PDALUtils.cpp
M plugins/sqlite/io/SQLiteWriter.hpp
Log Message:
Removed extra ";" (#1762)
* Remove warn warning: extra ";" [-Wpedantic] when compiling pdal directory
* Remove warn warning: extra ";" [-Wpedantic] when compiling filters directory
* Remove warn warning: extra ";" [-Wpedantic] when compiling io directory
* Remove warn warning: extra ";" [-Wpedantic] when compiling plugins directory
Commit: 6909499004a5da4188e30927c5797f95018a3c31
https://github.com/PDAL/PDAL/commit/6909499004a5da4188e30927c5797f95018a3c31
Changed paths:
M scripts/docker/Dockerfile
Log Message:
JSONcpp-related updates, precipitated by Alpine Docker building (#1764)
* jsoncpp changed the return signature of removeMember and we need to get the same behavior in two steps now
* jsoncpp + alpine = sad panda
* default to checking out pdal master for docker build
Commit: 3b74dcbee43f747582d46a2ad4b01c9608ce94ed
https://github.com/PDAL/PDAL/commit/3b74dcbee43f747582d46a2ad4b01c9608ce94ed
Changed paths:
Log Message:
run 'pdal' CMD for Dockerfile
Commit: 8fbfde119762286ecc4906a037687ae1fe7fa1cc
https://github.com/PDAL/PDAL/commit/8fbfde119762286ecc4906a037687ae1fe7fa1cc
Changed paths:
M plugins/nitf/io/tre_plugins.cpp
Log Message:
remove redundant semicolons in nitf tre_plugins macro usage (#1765)
Commit: b076199e5e9aa98517641bb49ceb6b6d5163be92
https://github.com/PDAL/PDAL/commit/b076199e5e9aa98517641bb49ceb6b6d5163be92
Changed paths:
M appveyor.yml
M cmake/lzma.cmake
M cmake/zlib.cmake
M cmake/zstd.cmake
M io/BpfReader.cpp
M io/BpfWriter.cpp
M io/GDALReader.cpp
M io/GDALWriter.cpp
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/OGRWriter.cpp
M io/OGRWriter.hpp
M io/PlyReader.cpp
M pdal/Kernel.hpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/PyArray.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M python/setup.py
Log Message:
Merge remote-tracking branch 'origin/master' into inline-dimdetail-pointlayout
Commit: 4aba5d909dd7b26f3398c621bfbb2779a7640e8e
https://github.com/PDAL/PDAL/commit/4aba5d909dd7b26f3398c621bfbb2779a7640e8e
Changed paths:
M pdal/PointLayout.hpp
Log Message:
no need for inline statement
Compare: https://github.com/PDAL/PDAL/compare/5deb838bb0fd...4aba5d909dd7
More information about the pdal-commits
