[pdal-commits] [PDAL/PDAL] 43b204: Range default lower bounds should use lowest, not ...
GitHub
noreply at github.com
Mon Feb 13 09:47:23 PST 2017
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 43b20485f4aa237aee0dc73a4c6c8a3165135575
https://github.com/PDAL/PDAL/commit/43b20485f4aa237aee0dc73a4c6c8a3165135575
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-02-10 (Fri, 10 Feb 2017)
Changed paths:
M filters/RangeFilter.cpp
M filters/private/Range.cpp
Log Message:
Range default lower bounds should use lowest, not min
Commit: 8342abdf98ab81877aa905ae1ccbc77c73f4c6f3
https://github.com/PDAL/PDAL/commit/8342abdf98ab81877aa905ae1ccbc77c73f4c6f3
Author: chambbj <brad.chambers at gmail.com>
Date: 2017-02-13 (Mon, 13 Feb 2017)
Changed paths:
Log Message:
Merge pull request #1491 from PDAL/range-filter-lower-bound-fix
Range filter default lower bounds should use lowest, not min
Compare: https://github.com/PDAL/PDAL/compare/c7cef916aca1...8342abdf98ab
More information about the pdal-commits
