[pdal-commits] [PDAL/PDAL] 195eca: Break apart range parsing.
GitHub
noreply at github.com
Tue Feb 21 14:54:42 PST 2017
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 195ecaf723a94506c216f9ca680ea2559a4d5eee
https://github.com/PDAL/PDAL/commit/195ecaf723a94506c216f9ca680ea2559a4d5eee
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-02-10 (Fri, 10 Feb 2017)
Changed paths:
M filters/RangeFilter.cpp
M filters/private/Range.cpp
M filters/private/Range.hpp
Log Message:
Commit: b61d650572c6dfbbb400acf28fc57e3eafbf7122
https://github.com/PDAL/PDAL/commit/b61d650572c6dfbbb400acf28fc57e3eafbf7122
Date: 2017-02-15 (Wed, 15 Feb 2017)
Changed paths:
M doc/stages/filters.assign.rst
M filters/AssignFilter.cpp
M filters/AssignFilter.hpp
M filters/RangeFilter.hpp
A filters/private/DimRange.cpp
A filters/private/DimRange.hpp
R filters/private/Range.cpp
R filters/private/Range.hpp
M test/data/pipeline/assign.json.in
M test/data/pipeline/options.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
M test/unit/filters/AssignFilterTest.cpp
Log Message:
Enhance filters.assign with range-based filtering of value assignment.
Close #1468
Commit: cf1d7db5746208243c668855cc012d9f1ffdf21a
https://github.com/PDAL/PDAL/commit/cf1d7db5746208243c668855cc012d9f1ffdf21a
Date: 2017-02-21 (Tue, 21 Feb 2017)
Changed paths:
M cmake/curl.cmake
M doc/apps/pipeline.rst
M io/BpfCompressor.hpp
M io/DerivativeWriter.cpp
M io/DerivativeWriter.hpp
M kernels/InfoKernel.cpp
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M pdal/EigenUtils.cpp
M pdal/EigenUtils.hpp
M pdal/Log.cpp
M pdal/PDALUtils.hpp
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/test/GreyhoundReaderTest.cpp
M test/unit/EigenTest.cpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into assign
Commit: 47da5c221574627f9bf8a88c33bd3cc2c6c307e0
https://github.com/PDAL/PDAL/commit/47da5c221574627f9bf8a88c33bd3cc2c6c307e0
Changed paths:
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/d4bd34f53770...47da5c221574
More information about the pdal-commits
