[pdal-commits] [PDAL/PDAL] 950870: Poisson surface reconstruction algorithm.
GitHub noreply at github.com
Mon Jul 24 12:27:54 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 9508702edf7ff14bc078aabce155c93af2646c0e
      https://github.com/PDAL/PDAL/commit/9508702edf7ff14bc078aabce155c93af2646c0e
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-07-24 (Mon, 24 Jul 2017)
  Changed paths:
    M CMakeLists.txt
    M doc/stages/filters.poisson.rst
    A filters/PoissonFilter.cpp
    A filters/PoissonFilter.hpp
    M io/GeotiffSupport.cpp
    M pdal/Dimension.json
    M pdal/StageFactory.cpp
    A vendor/kazhdan/Allocator.h
    A vendor/kazhdan/Array.h
    A vendor/kazhdan/BSplineData.h
    A vendor/kazhdan/BSplineData.inl
    A vendor/kazhdan/BinaryNode.h
    A vendor/kazhdan/CMakeLists.txt
    A vendor/kazhdan/CmdLineParser.cpp
    A vendor/kazhdan/CmdLineParser.h
    A vendor/kazhdan/CmdLineParser.inl
    A vendor/kazhdan/Factor.cpp
    A vendor/kazhdan/Factor.h
    A vendor/kazhdan/Geometry.cpp
    A vendor/kazhdan/Geometry.h
    A vendor/kazhdan/Geometry.inl
    A vendor/kazhdan/MAT.h
    A vendor/kazhdan/MAT.inl
    A vendor/kazhdan/MarchingCubes.cpp
    A vendor/kazhdan/MarchingCubes.h
    A vendor/kazhdan/MemoryUsage.h
    A vendor/kazhdan/Mesh.h
    A vendor/kazhdan/MultiGridOctreeData.Evaluation.inl
    A vendor/kazhdan/MultiGridOctreeData.IsoSurface.inl
    A vendor/kazhdan/MultiGridOctreeData.SortedTreeNodes.inl
    A vendor/kazhdan/MultiGridOctreeData.System.inl
    A vendor/kazhdan/MultiGridOctreeData.WeightedSamples.inl
    A vendor/kazhdan/MultiGridOctreeData.h
    A vendor/kazhdan/MultiGridOctreeData.inl
    A vendor/kazhdan/MyTime.h
    A vendor/kazhdan/Octree.h
    A vendor/kazhdan/Octree.inl
    A vendor/kazhdan/PPolynomial.h
    A vendor/kazhdan/PPolynomial.inl
    A vendor/kazhdan/Ply.h
    A vendor/kazhdan/PlyFile.cpp
    A vendor/kazhdan/PoissonRecon.h
    A vendor/kazhdan/Polynomial.h
    A vendor/kazhdan/Polynomial.inl
    A vendor/kazhdan/SparseMatrix.h
    A vendor/kazhdan/SparseMatrix.inl
    A vendor/kazhdan/SurfaceTrimmer.h
    A vendor/kazhdan/SurfaceTrimmerMain.cpp
    A vendor/kazhdan/point_source/AsciiPointSource.h
    A vendor/kazhdan/point_source/AsciiPointSource.inl
    A vendor/kazhdan/point_source/BinaryPointSource.h
    A vendor/kazhdan/point_source/BinaryPointSource.inl
    A vendor/kazhdan/point_source/MemoryPointSource.h
    A vendor/kazhdan/point_source/PlyPointSource.h
    A vendor/kazhdan/point_source/PlyPointSource.inl
    A vendor/kazhdan/point_source/PointSource.h
    A vendor/kazhdan/point_source/TransformedPointSource.h
    A vendor/poisson_surface/allocator.h
    A vendor/poisson_surface/binary_node.h
    A vendor/poisson_surface/bspline_data.h
    A vendor/poisson_surface/bspline_data.hpp
    A vendor/poisson_surface/factor.h
    A vendor/poisson_surface/function_data.h
    A vendor/poisson_surface/function_data.hpp
    A vendor/poisson_surface/geometry.h
    A vendor/poisson_surface/geometry.hpp
    A vendor/poisson_surface/hash.h
    A vendor/poisson_surface/marching_cubes_poisson.h
    A vendor/poisson_surface/mat.h
    A vendor/poisson_surface/mat.hpp
    A vendor/poisson_surface/multi_grid_octree_data.h
    A vendor/poisson_surface/multi_grid_octree_data.hpp
    A vendor/poisson_surface/octree_poisson.h
    A vendor/poisson_surface/octree_poisson.hpp
    A vendor/poisson_surface/polynomial.h
    A vendor/poisson_surface/polynomial.hpp
    A vendor/poisson_surface/ppolynomial.h
    A vendor/poisson_surface/ppolynomial.hpp
    A vendor/poisson_surface/sparse_matrix.h
    A vendor/poisson_surface/sparse_matrix.hpp
    A vendor/poisson_surface/vector.h
    A vendor/poisson_surface/vector.hpp
  Log Message:
More information about the pdal-commits mailing list
