[pdal-commits] [PDAL/PDAL] 341116: missing include
GitHub
noreply at github.com
Fri Mar 3 12:48:32 PST 2017
Branch: refs/heads/mbio-reader
Home: https://github.com/PDAL/PDAL
Commit: 341116619a2e9e4da5f4ed39233c59ad9ab89ff6
https://github.com/PDAL/PDAL/commit/341116619a2e9e4da5f4ed39233c59ad9ab89ff6
Author: Grigory Pomadchin <gr.pomadchin at gmail.com>
Date: 2017-02-08 (Wed, 08 Feb 2017)
Changed paths:
M io/BpfCompressor.hpp
Log Message:
missing include
Commit: 195ecaf723a94506c216f9ca680ea2559a4d5eee
https://github.com/PDAL/PDAL/commit/195ecaf723a94506c216f9ca680ea2559a4d5eee
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-02-10 (Fri, 10 Feb 2017)
Changed paths:
M filters/RangeFilter.cpp
M filters/private/Range.cpp
M filters/private/Range.hpp
Log Message:
Break apart range parsing.
Commit: aa0716532c6cf8676e4e55e4f0142149d1e382b8
https://github.com/PDAL/PDAL/commit/aa0716532c6cf8676e4e55e4f0142149d1e382b8
Author: Connor Manning <connormanning at users.noreply.github.com>
Date: 2017-02-13 (Mon, 13 Feb 2017)
Changed paths:
Log Message:
Merge pull request #1489 from pomadchin/fix/stdexcept
Fix missing include
Commit: 2c2ba00e102c35904b7830807b063404e15bd1f8
https://github.com/PDAL/PDAL/commit/2c2ba00e102c35904b7830807b063404e15bd1f8
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-02-14 (Tue, 14 Feb 2017)
Changed paths:
M pdal/EigenUtils.cpp
Log Message:
Initialize max matrix to NaN, only update values if we have data
Commit: 29de700e73c2273bd35bdc4e02047281c32e5e26
https://github.com/PDAL/PDAL/commit/29de700e73c2273bd35bdc4e02047281c32e5e26
Changed paths:
M kernels/InfoKernel.cpp
M pdal/Log.cpp
Log Message:
Log warning if the user tries to display points that don't exist.
Close #1495
Commit: b61d650572c6dfbbb400acf28fc57e3eafbf7122
https://github.com/PDAL/PDAL/commit/b61d650572c6dfbbb400acf28fc57e3eafbf7122
Date: 2017-02-15 (Wed, 15 Feb 2017)
Changed paths:
M doc/stages/filters.assign.rst
M filters/AssignFilter.cpp
M filters/AssignFilter.hpp
M filters/RangeFilter.hpp
A filters/private/DimRange.cpp
A filters/private/DimRange.hpp
R filters/private/Range.cpp
R filters/private/Range.hpp
M test/data/pipeline/assign.json.in
M test/data/pipeline/options.json.in
M test/unit/apps/pcpipelineTestJSON.cpp
M test/unit/filters/AssignFilterTest.cpp
Log Message:
Enhance filters.assign with range-based filtering of value assignment.
Close #1468
Commit: 858361915bf9c5384d3a56e2f908f57ad5cb90b9
https://github.com/PDAL/PDAL/commit/858361915bf9c5384d3a56e2f908f57ad5cb90b9
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1494 from PDAL/derivative-work
Commit: 0dc234dafa7ed304a979a5ceea6d7ca009035bad
https://github.com/PDAL/PDAL/commit/0dc234dafa7ed304a979a5ceea6d7ca009035bad
Changed paths:
M kernels/PipelineKernel.cpp
M kernels/PipelineKernel.hpp
M pdal/PDALUtils.hpp
Log Message:
Add support for metadata output.
Close #1414
Commit: 9df1dd7695d0f702dc8d87674640088287771f25
https://github.com/PDAL/PDAL/commit/9df1dd7695d0f702dc8d87674640088287771f25
Changed paths:
M doc/apps/pipeline.rst
Log Message:
Add --metadata option to doc.
Commit: 5e04355d8516888e52eca20db7899dde7a29b573
https://github.com/PDAL/PDAL/commit/5e04355d8516888e52eca20db7899dde7a29b573
Author: Connor Manning <connor at hobu.co>
Changed paths:
M vendor/arbiter/arbiter.hpp
Log Message:
Add include. Should fix #1484.
Commit: a65060b7437d7b93240d917d8943a4d013138a02
https://github.com/PDAL/PDAL/commit/a65060b7437d7b93240d917d8943a4d013138a02
Date: 2017-02-17 (Fri, 17 Feb 2017)
Changed paths:
M cmake/curl.cmake
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/test/GreyhoundReaderTest.cpp
M vendor/arbiter/arbiter.cpp
Log Message:
Update arbiter bundle for optional Curl and EC2 instance-profile auth.
Commit: adde2eaaaa960ecb1fd1c8ecd8a64590ce6cd0c2
https://github.com/PDAL/PDAL/commit/adde2eaaaa960ecb1fd1c8ecd8a64590ce6cd0c2
Changed paths:
Log Message:
Update arbiter bundle removing an overzealous throw.
Commit: fbee535ffbae34a95da73c39de3ad842b06311e4
https://github.com/PDAL/PDAL/commit/fbee535ffbae34a95da73c39de3ad842b06311e4
Date: 2017-02-21 (Tue, 21 Feb 2017)
Changed paths:
M plugins/mbio/io/MBSystemReader.cpp
Log Message:
First cut.
Commit: cf1d7db5746208243c668855cc012d9f1ffdf21a
https://github.com/PDAL/PDAL/commit/cf1d7db5746208243c668855cc012d9f1ffdf21a
Changed paths:
M cmake/curl.cmake
M io/DerivativeWriter.cpp
M io/DerivativeWriter.hpp
M pdal/EigenUtils.hpp
M pdal/Log.cpp
M test/unit/EigenTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into assign
Commit: d4bd34f53770d14117434ef91b6a18ef42d0d28c
https://github.com/PDAL/PDAL/commit/d4bd34f53770d14117434ef91b6a18ef42d0d28c
Changed paths:
Log Message:
Update arbiter bundle for opt-in instance profiles and multi-S3 configurability.
Commit: 47da5c221574627f9bf8a88c33bd3cc2c6c307e0
https://github.com/PDAL/PDAL/commit/47da5c221574627f9bf8a88c33bd3cc2c6c307e0
Changed paths:
Log Message:
Commit: 04be34d1be912f5cc6dc4853763262c782db3b2b
https://github.com/PDAL/PDAL/commit/04be34d1be912f5cc6dc4853763262c782db3b2b
Date: 2017-02-22 (Wed, 22 Feb 2017)
Changed paths:
M cmake/curl.cmake
M pdal/Log.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into mbio
Commit: 7bded02673ffc883193d4eae0966f2f57a413bb7
https://github.com/PDAL/PDAL/commit/7bded02673ffc883193d4eae0966f2f57a413bb7
Date: 2017-03-03 (Fri, 03 Mar 2017)
Changed paths:
M cmake/options.cmake
M dimbuilder/DimBuilder.cpp
M pdal/pdal_types.hpp
M pdal/util/ProgramArgs.hpp
M plugins/mbio/CMakeLists.txt
R plugins/mbio/io/MBSystemReader.cpp
R plugins/mbio/io/MBSystemReader.hpp
A plugins/mbio/io/MbError.cpp
A plugins/mbio/io/MbError.hpp
A plugins/mbio/io/MbFormat.cpp
A plugins/mbio/io/MbFormat.hpp
A plugins/mbio/io/MbReader.cpp
A plugins/mbio/io/MbReader.hpp
Log Message:
Working MbReader.
Compare: https://github.com/PDAL/PDAL/compare/5c155e99c275...7bded02673ff
More information about the pdal-commits
