[pdal-commits] [PDAL/PDAL] 2969f8: Add sort order option, with new descending sort #1...
GitHub
noreply at github.com
Mon Mar 27 07:09:43 PDT 2017
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: 2969f8931fd4ceb626978310ccbb859ea959194d
https://github.com/PDAL/PDAL/commit/2969f8931fd4ceb626978310ccbb859ea959194d
Author: Weston Renoud <wrenoud at gmail.com>
Date: 2017-03-27 (Mon, 27 Mar 2017)
Changed paths:
M doc/stages/filters.sort.rst
M filters/SortFilter.cpp
M filters/SortFilter.hpp
M pdal/PointViewIter.hpp
M test/unit/filters/SortFilterTest.cpp
Log Message:
Add sort order option, with new descending sort #1121 (#1530)
* Add sort order Option, with new descending (largest to smallest) sort #1121
Default behavior remains unchanged.
This includes unittests and documentation updates.
* reformat sort filter to follow style guide
* undue change to sort filter test interations
I'm unsure if there is a reason for the number of iterations.
* better handling of unknown options for sort
per suggestion from @abellgithub
* wrong out text for SortOrder enum
* switch sort filter to std::stable_sort
needed a default constructor for pdal::PointViewIter
* update sort filter description in documentation
* bug exposed when trying to use std::stable_sort with the SortFilter
More information about the pdal-commits
