[pdal-commits] [PDAL/PDAL] 75eb05: metadata and srs support for Matlab stages
GitHub
noreply at github.com
Tue Oct 10 11:14:53 PDT 2017
Branch: refs/heads/matlab-metadata
Home: https://github.com/PDAL/PDAL
Commit: 75eb05771a5b7dda15ed16aabd902d2a878cc8ad
https://github.com/PDAL/PDAL/commit/75eb05771a5b7dda15ed16aabd902d2a878cc8ad
Author: Howard Butler <howard at hobu.co>
Date: 2017-08-31 (Thu, 31 Aug 2017)
Changed paths:
M plugins/matlab/filters/MatlabFilter.cpp
M plugins/matlab/filters/MatlabFilter.hpp
M plugins/matlab/filters/Script.cpp
M plugins/matlab/filters/Script.hpp
M plugins/matlab/io/MatlabReader.cpp
M plugins/matlab/io/MatlabReader.hpp
M plugins/matlab/io/MatlabWriter.cpp
M plugins/matlab/io/MatlabWriter.hpp
M plugins/matlab/test/MatlabReaderTest.cpp
M test/data/matlab/autzen.mat
Log Message:
Commit: 7301259b3f2e0f60af4a4bfea5bbd77308a4309d
https://github.com/PDAL/PDAL/commit/7301259b3f2e0f60af4a4bfea5bbd77308a4309d
Date: 2017-10-10 (Tue, 10 Oct 2017)
Changed paths:
M .gitignore
M .travis.yml
M CMakeLists.txt
M HOWTORELEASE.txt
M apps/pdal.cpp
A cmake/arbiter.cmake
M cmake/curl.cmake
M cmake/json.cmake
M cmake/laszip.cmake
M cmake/modules/FindLASzip.cmake
M doc/apps/delta.rst
M doc/stages/filters.assign.rst
M doc/stages/filters.cpd.rst
M doc/stages/filters.ferry.rst
M doc/stages/filters.greedyprojection.rst
M doc/stages/filters.smrf.rst
M doc/stages/readers.greyhound.rst
M doc/stages/readers.text.rst
M doc/stages/writers.gdal.rst
M doc/stages/writers.ply.rst
M filters/AssignFilter.cpp
M filters/ColorinterpFilter.cpp
M filters/ColorinterpFilter.hpp
M filters/ColorizationFilter.cpp
M filters/FerryFilter.cpp
M filters/FerryFilter.hpp
M filters/SampleFilter.cpp
M filters/StreamCallbackFilter.hpp
M filters/private/DimRange.cpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/GDALWriter.cpp
M io/GDALWriter.hpp
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasHeader.hpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasUtils.cpp
M io/LasUtils.hpp
M io/LasVLR.cpp
M io/LasVLR.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
R io/LasZipPoint.cpp
R io/LasZipPoint.hpp
M io/PlyReader.cpp
M java/README.md
M java/build.sbt
A java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
A java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
A java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
M java/project/Commands.scala
A java/project/Dependencies.scala
A java/project/Version.scala
M java/project/build.properties
M java/project/plugins.sbt
M java/sbt
M java/scripts/publish-212.sh
M java/scripts/publish-javastyle.sh
M java/scripts/publish-local-212.sh
M java/scripts/publish-local.sh
M java/scripts/publish.sh
M kernels/DeltaKernel.cpp
M kernels/DeltaKernel.hpp
M kernels/GroundKernel.cpp
M kernels/GroundKernel.hpp
M kernels/SortKernel.cpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/TranslateKernel.cpp
M pdal/DimUtil.hpp
M pdal/Dimension.json
M pdal/EigenUtils.cpp
M pdal/GDALUtils.cpp
M pdal/GDALUtils.hpp
M pdal/Kernel.cpp
R pdal/KernelFactory.cpp
R pdal/KernelFactory.hpp
M pdal/Metadata.hpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PipelineManager.cpp
R pdal/PipelineReaderXML.cpp
M pdal/PointTable.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/StageFactory.cpp
M pdal/pdal_config.cpp
R pdal/private/PipelineReaderXML.hpp
M pdal/util/Bounds.cpp
M pdal/util/ProgramArgs.hpp
M pdal/util/Utils.cpp
M pdal/util/Utils.hpp
M pdal_defines.h.in
M plugins/cpd/filters/CpdFilter.cpp
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/GreyhoundReader.hpp
R plugins/greyhound/io/pool.cpp
R plugins/greyhound/io/pool.hpp
M plugins/greyhound/test/GreyhoundReaderTest.cpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/pcl/filters/IcpFilter.cpp
M plugins/pcl/kernel/PCLKernel.cpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M scripts/ci/script.sh
A scripts/docker/1.4-maintenance/alpine/10-backtrace-guards.patch
A scripts/docker/1.4-maintenance/alpine/Dockerfile
A scripts/docker/1.4-maintenance/ubuntu/Dockerfile
A scripts/docker/1.5-maintenance/alpine/10-backtrace-guards.patch
A scripts/docker/1.5-maintenance/alpine/Dockerfile
A scripts/docker/1.5-maintenance/ubuntu/Dockerfile
M scripts/docker/dependencies/Dockerfile
A scripts/docker/master/alpine/Dockerfile
A scripts/docker/master/ubuntu/Dockerfile
M test/data/gdal/grid.txt
R test/data/hole/autzen-dd.las
R test/data/hole/hole.dbf
R test/data/hole/hole.las
R test/data/hole/hole.prj
R test/data/hole/hole.qpj
R test/data/hole/hole.shp
R test/data/hole/hole.shx
R test/data/hole/make-spurious.py
R test/data/hole/spurious.las
A test/data/las/autzen_trim_7.las
A test/data/las/spurious.las
M test/data/pipeline/crop-hole.json.in
M test/unit/CMakeLists.txt
M test/unit/MetadataTest.cpp
M test/unit/UtilsTest.cpp
M test/unit/apps/pc2pcTest.cpp
R test/unit/apps/pcinfoTest.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
A test/unit/filters/ColorinterpFilterTest.cpp
M test/unit/filters/FerryFilterTest.cpp
M test/unit/io/GDALWriterTest.cpp
M test/unit/io/LasReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
M tools/lasdump/Dumper.cpp
M tools/lasdump/Dumper.hpp
M vendor/arbiter/CMakeLists.txt
M vendor/eigen/Eigen/CMakeLists.txt
M vendor/eigen/Eigen/Cholesky
M vendor/eigen/Eigen/CholmodSupport
M vendor/eigen/Eigen/Core
M vendor/eigen/Eigen/Eigen
M vendor/eigen/Eigen/Eigenvalues
M vendor/eigen/Eigen/Geometry
M vendor/eigen/Eigen/Householder
M vendor/eigen/Eigen/IterativeLinearSolvers
M vendor/eigen/Eigen/Jacobi
M vendor/eigen/Eigen/LU
M vendor/eigen/Eigen/MetisSupport
M vendor/eigen/Eigen/OrderingMethods
M vendor/eigen/Eigen/PaStiXSupport
M vendor/eigen/Eigen/PardisoSupport
M vendor/eigen/Eigen/QR
M vendor/eigen/Eigen/QtAlignedMalloc
M vendor/eigen/Eigen/SPQRSupport
M vendor/eigen/Eigen/SVD
M vendor/eigen/Eigen/Sparse
M vendor/eigen/Eigen/SparseCholesky
M vendor/eigen/Eigen/SparseCore
M vendor/eigen/Eigen/SparseLU
M vendor/eigen/Eigen/SparseQR
M vendor/eigen/Eigen/StdDeque
M vendor/eigen/Eigen/StdList
M vendor/eigen/Eigen/StdVector
M vendor/eigen/Eigen/SuperLUSupport
M vendor/eigen/Eigen/UmfPackSupport
M vendor/eigen/Eigen/src/Cholesky/LDLT.h
M vendor/eigen/Eigen/src/Cholesky/LLT.h
A vendor/eigen/Eigen/src/Cholesky/LLT_LAPACKE.h
M vendor/eigen/Eigen/src/CholmodSupport/CholmodSupport.h
M vendor/eigen/Eigen/src/Core/Array.h
M vendor/eigen/Eigen/src/Core/ArrayBase.h
M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
M vendor/eigen/Eigen/src/Core/Assign.h
A vendor/eigen/Eigen/src/Core/AssignEvaluator.h
M vendor/eigen/Eigen/src/Core/Assign_MKL.h
M vendor/eigen/Eigen/src/Core/BandMatrix.h
M vendor/eigen/Eigen/src/Core/Block.h
M vendor/eigen/Eigen/src/Core/BooleanRedux.h
M vendor/eigen/Eigen/src/Core/CommaInitializer.h
A vendor/eigen/Eigen/src/Core/ConditionEstimator.h
A vendor/eigen/Eigen/src/Core/CoreEvaluators.h
M vendor/eigen/Eigen/src/Core/CoreIterators.h
M vendor/eigen/Eigen/src/Core/CwiseBinaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseNullaryOp.h
A vendor/eigen/Eigen/src/Core/CwiseTernaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseUnaryOp.h
M vendor/eigen/Eigen/src/Core/CwiseUnaryView.h
M vendor/eigen/Eigen/src/Core/DenseBase.h
M vendor/eigen/Eigen/src/Core/DenseCoeffsBase.h
M vendor/eigen/Eigen/src/Core/DenseStorage.h
M vendor/eigen/Eigen/src/Core/Diagonal.h
M vendor/eigen/Eigen/src/Core/DiagonalMatrix.h
M vendor/eigen/Eigen/src/Core/DiagonalProduct.h
M vendor/eigen/Eigen/src/Core/Dot.h
M vendor/eigen/Eigen/src/Core/EigenBase.h
M vendor/eigen/Eigen/src/Core/ForceAlignedAccess.h
M vendor/eigen/Eigen/src/Core/Fuzzy.h
M vendor/eigen/Eigen/src/Core/GeneralProduct.h
M vendor/eigen/Eigen/src/Core/GenericPacketMath.h
M vendor/eigen/Eigen/src/Core/GlobalFunctions.h
M vendor/eigen/Eigen/src/Core/IO.h
A vendor/eigen/Eigen/src/Core/Inverse.h
M vendor/eigen/Eigen/src/Core/Map.h
M vendor/eigen/Eigen/src/Core/MapBase.h
M vendor/eigen/Eigen/src/Core/MathFunctions.h
A vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
M vendor/eigen/Eigen/src/Core/Matrix.h
M vendor/eigen/Eigen/src/Core/MatrixBase.h
M vendor/eigen/Eigen/src/Core/NestByValue.h
M vendor/eigen/Eigen/src/Core/NoAlias.h
M vendor/eigen/Eigen/src/Core/NumTraits.h
M vendor/eigen/Eigen/src/Core/PermutationMatrix.h
M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
A vendor/eigen/Eigen/src/Core/Product.h
A vendor/eigen/Eigen/src/Core/ProductEvaluators.h
M vendor/eigen/Eigen/src/Core/Random.h
M vendor/eigen/Eigen/src/Core/Redux.h
M vendor/eigen/Eigen/src/Core/Ref.h
M vendor/eigen/Eigen/src/Core/Replicate.h
M vendor/eigen/Eigen/src/Core/ReturnByValue.h
M vendor/eigen/Eigen/src/Core/Reverse.h
M vendor/eigen/Eigen/src/Core/Select.h
M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
M vendor/eigen/Eigen/src/Core/SelfCwiseBinaryOp.h
A vendor/eigen/Eigen/src/Core/Solve.h
M vendor/eigen/Eigen/src/Core/SolveTriangular.h
A vendor/eigen/Eigen/src/Core/SolverBase.h
M vendor/eigen/Eigen/src/Core/StableNorm.h
M vendor/eigen/Eigen/src/Core/Stride.h
M vendor/eigen/Eigen/src/Core/Swap.h
M vendor/eigen/Eigen/src/Core/Transpose.h
M vendor/eigen/Eigen/src/Core/Transpositions.h
M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
M vendor/eigen/Eigen/src/Core/VectorBlock.h
M vendor/eigen/Eigen/src/Core/VectorwiseOp.h
M vendor/eigen/Eigen/src/Core/Visitor.h
A vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
A vendor/eigen/Eigen/src/Core/arch/AVX/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/AVX/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
A vendor/eigen/Eigen/src/Core/arch/AltiVec/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/Complex.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/Half.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMathHalf.h
A vendor/eigen/Eigen/src/Core/arch/CUDA/TypeCasting.h
M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
A vendor/eigen/Eigen/src/Core/arch/NEON/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
M vendor/eigen/Eigen/src/Core/arch/SSE/MathFunctions.h
M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
A vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/MathFunctions.h
A vendor/eigen/Eigen/src/Core/arch/ZVector/PacketMath.h
A vendor/eigen/Eigen/src/Core/functors/AssignmentFunctors.h
A vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/NullaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/StlFunctors.h
A vendor/eigen/Eigen/src/Core/functors/TernaryFunctors.h
A vendor/eigen/Eigen/src/Core/functors/UnaryFunctors.h
M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/Parallelizer.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix.h
A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointProduct.h
M vendor/eigen/Eigen/src/Core/products/SelfadjointRank2Update.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
A vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector.h
A vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix.h
A vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
M vendor/eigen/Eigen/src/Core/products/TriangularSolverVector.h
M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
M vendor/eigen/Eigen/src/Core/util/Constants.h
M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
M vendor/eigen/Eigen/src/Core/util/ForwardDeclarations.h
M vendor/eigen/Eigen/src/Core/util/MKL_support.h
M vendor/eigen/Eigen/src/Core/util/Macros.h
M vendor/eigen/Eigen/src/Core/util/Memory.h
M vendor/eigen/Eigen/src/Core/util/Meta.h
M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
M vendor/eigen/Eigen/src/Core/util/XprHelper.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur.h
A vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/EigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedSelfAdjointEigenSolver.h
M vendor/eigen/Eigen/src/Eigenvalues/HessenbergDecomposition.h
M vendor/eigen/Eigen/src/Eigenvalues/RealQZ.h
M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
A vendor/eigen/Eigen/src/Eigenvalues/RealSchur_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver.h
A vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver_LAPACKE.h
M vendor/eigen/Eigen/src/Eigenvalues/Tridiagonalization.h
M vendor/eigen/Eigen/src/Geometry/AlignedBox.h
M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
M vendor/eigen/Eigen/src/Geometry/EulerAngles.h
M vendor/eigen/Eigen/src/Geometry/Homogeneous.h
M vendor/eigen/Eigen/src/Geometry/Hyperplane.h
M vendor/eigen/Eigen/src/Geometry/OrthoMethods.h
M vendor/eigen/Eigen/src/Geometry/ParametrizedLine.h
M vendor/eigen/Eigen/src/Geometry/Quaternion.h
M vendor/eigen/Eigen/src/Geometry/Rotation2D.h
M vendor/eigen/Eigen/src/Geometry/RotationBase.h
M vendor/eigen/Eigen/src/Geometry/Scaling.h
M vendor/eigen/Eigen/src/Geometry/Transform.h
M vendor/eigen/Eigen/src/Geometry/Translation.h
M vendor/eigen/Eigen/src/Geometry/Umeyama.h
M vendor/eigen/Eigen/src/Geometry/arch/Geometry_SSE.h
M vendor/eigen/Eigen/src/Householder/BlockHouseholder.h
M vendor/eigen/Eigen/src/Householder/Householder.h
M vendor/eigen/Eigen/src/Householder/HouseholderSequence.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/BasicPreconditioners.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/BiCGSTAB.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteCholesky.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteLUT.h
M vendor/eigen/Eigen/src/IterativeLinearSolvers/IterativeSolverBase.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/LeastSquareConjugateGradient.h
A vendor/eigen/Eigen/src/IterativeLinearSolvers/SolveWithGuess.h
M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
M vendor/eigen/Eigen/src/LU/Determinant.h
M vendor/eigen/Eigen/src/LU/FullPivLU.h
A vendor/eigen/Eigen/src/LU/InverseImpl.h
M vendor/eigen/Eigen/src/LU/PartialPivLU.h
A vendor/eigen/Eigen/src/LU/PartialPivLU_LAPACKE.h
M vendor/eigen/Eigen/src/LU/arch/Inverse_SSE.h
M vendor/eigen/Eigen/src/MetisSupport/MetisSupport.h
M vendor/eigen/Eigen/src/OrderingMethods/Amd.h
M vendor/eigen/Eigen/src/OrderingMethods/Eigen_Colamd.h
M vendor/eigen/Eigen/src/OrderingMethods/Ordering.h
M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
M vendor/eigen/Eigen/src/PardisoSupport/PardisoSupport.h
M vendor/eigen/Eigen/src/QR/ColPivHouseholderQR.h
A vendor/eigen/Eigen/src/QR/ColPivHouseholderQR_LAPACKE.h
A vendor/eigen/Eigen/src/QR/CompleteOrthogonalDecomposition.h
M vendor/eigen/Eigen/src/QR/FullPivHouseholderQR.h
M vendor/eigen/Eigen/src/QR/HouseholderQR.h
A vendor/eigen/Eigen/src/QR/HouseholderQR_LAPACKE.h
M vendor/eigen/Eigen/src/SPQRSupport/SuiteSparseQRSupport.h
A vendor/eigen/Eigen/src/SVD/BDCSVD.h
M vendor/eigen/Eigen/src/SVD/JacobiSVD.h
A vendor/eigen/Eigen/src/SVD/JacobiSVD_LAPACKE.h
A vendor/eigen/Eigen/src/SVD/SVDBase.h
M vendor/eigen/Eigen/src/SVD/UpperBidiagonalization.h
M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
M vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
M vendor/eigen/Eigen/src/SparseCore/CompressedStorage.h
M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/MappedSparseMatrix.h
A vendor/eigen/Eigen/src/SparseCore/SparseAssign.h
M vendor/eigen/Eigen/src/SparseCore/SparseBlock.h
M vendor/eigen/Eigen/src/SparseCore/SparseColEtree.h
A vendor/eigen/Eigen/src/SparseCore/SparseCompressedBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseBinaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseCwiseUnaryOp.h
M vendor/eigen/Eigen/src/SparseCore/SparseDenseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseDiagonalProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseDot.h
M vendor/eigen/Eigen/src/SparseCore/SparseFuzzy.h
A vendor/eigen/Eigen/src/SparseCore/SparseMap.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
M vendor/eigen/Eigen/src/SparseCore/SparseMatrixBase.h
M vendor/eigen/Eigen/src/SparseCore/SparsePermutation.h
M vendor/eigen/Eigen/src/SparseCore/SparseProduct.h
M vendor/eigen/Eigen/src/SparseCore/SparseRedux.h
A vendor/eigen/Eigen/src/SparseCore/SparseRef.h
M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
A vendor/eigen/Eigen/src/SparseCore/SparseSolverBase.h
M vendor/eigen/Eigen/src/SparseCore/SparseSparseProductWithPruning.h
M vendor/eigen/Eigen/src/SparseCore/SparseTranspose.h
M vendor/eigen/Eigen/src/SparseCore/SparseTriangularView.h
M vendor/eigen/Eigen/src/SparseCore/SparseUtil.h
M vendor/eigen/Eigen/src/SparseCore/SparseVector.h
M vendor/eigen/Eigen/src/SparseCore/SparseView.h
M vendor/eigen/Eigen/src/SparseCore/TriangularSolver.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
M vendor/eigen/Eigen/src/SparseLU/SparseLUImpl.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Memory.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Structs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_SupernodalMatrix.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_Utils.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_column_dfs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_copy_to_ucol.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_gemm_kernel.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_heap_relax_snode.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_kernel_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_bmod.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_panel_dfs.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_pivotL.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_pruneL.h
M vendor/eigen/Eigen/src/SparseLU/SparseLU_relax_snode.h
M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
M vendor/eigen/Eigen/src/StlSupport/StdDeque.h
M vendor/eigen/Eigen/src/StlSupport/StdList.h
M vendor/eigen/Eigen/src/StlSupport/StdVector.h
M vendor/eigen/Eigen/src/StlSupport/details.h
M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
M vendor/eigen/Eigen/src/UmfPackSupport/UmfPackSupport.h
M vendor/eigen/Eigen/src/misc/Image.h
M vendor/eigen/Eigen/src/misc/Kernel.h
A vendor/eigen/Eigen/src/misc/RealSvd2x2.h
M vendor/eigen/Eigen/src/misc/blas.h
A vendor/eigen/Eigen/src/misc/lapack.h
A vendor/eigen/Eigen/src/misc/lapacke.h
A vendor/eigen/Eigen/src/misc/lapacke_mangling.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/ArrayCwiseUnaryOps.h
M vendor/eigen/Eigen/src/plugins/BlockMethods.h
M vendor/eigen/Eigen/src/plugins/CommonCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/CommonCwiseUnaryOps.h
M vendor/eigen/Eigen/src/plugins/MatrixCwiseBinaryOps.h
M vendor/eigen/Eigen/src/plugins/MatrixCwiseUnaryOps.h
Log Message:
Merge remote-tracking branch 'origin/master' into matlab-metadata
Commit: 50af9a5af0737e460886af31e12d8c3721cd2691
https://github.com/PDAL/PDAL/commit/50af9a5af0737e460886af31e12d8c3721cd2691
Changed paths:
M cmake/modules/FindMatlab.cmake
Log Message:
support 2017b
Commit: e4801dfc1a04a3e8ce9696045d2fea4c23096fda
https://github.com/PDAL/PDAL/commit/e4801dfc1a04a3e8ce9696045d2fea4c23096fda
Changed paths:
M cmake/examples/hobu-config.sh
Log Message:
update for 2017b matlab
Commit: 25b855c762b2bc78e233ea0279bb94d107941f06
https://github.com/PDAL/PDAL/commit/25b855c762b2bc78e233ea0279bb94d107941f06
Changed paths:
M plugins/matlab/test/MatlabFilterTest.cpp
Log Message:
pdalargs option placed on PDAL.metadata.pdalargs member
Compare: https://github.com/PDAL/PDAL/compare/75eb05771a5b^...25b855c762b2
More information about the pdal-commits
