[pdal-commits] [PDAL/PDAL] 389be3: Remove '..' in configured temp path for unit tests
GitHub
noreply at github.com
Fri Oct 13 08:29:36 PDT 2017
Branch: refs/heads/1.6-maintenance
Home: https://github.com/PDAL/PDAL
Commit: 389be3d92dffd1905f97508ef01fc80437866aa8
https://github.com/PDAL/PDAL/commit/389be3d92dffd1905f97508ef01fc80437866aa8
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-10-12 (Thu, 12 Oct 2017)
Changed paths:
M test/unit/Support.cpp
M test/unit/TestConfig.hpp.in
Log Message:
musl has changed it's handling of '.' and '..' when globbing [1]. These only
recently made their way into the alpine:edge image that we use in Travis and
for Docker automated builds [2]. For now, we simply configure the temp path
directly, rather than relying on '..'.
[1] https://github.com/alpinelinux/aports/blob/afdba0ba0b8c0e92c376e7f1bfb151c07bf654b6/main/musl/0068-fix-glob-descent-into-.-and-.-with-GLOB_PERIOD.patch
[2] http://www.openwall.com/lists/musl/2017/01/12/5
Commit: 58b586fb392085a0ea32dcdedc488f78d7ea2c00
https://github.com/PDAL/PDAL/commit/58b586fb392085a0ea32dcdedc488f78d7ea2c00
Author: Howard Butler <howard at hobu.co>
Date: 2017-10-13 (Fri, 13 Oct 2017)
Changed paths:
Log Message:
Merge pull request #1703 from PDAL/alpine-edge-issues
Compare: https://github.com/PDAL/PDAL/compare/ac17d3dd8601...58b586fb3920
More information about the pdal-commits
