[pdal-commits] [PDAL/PDAL] e1323a: Always reject nan values with the range filter
GitHub noreply at github.com
Wed Oct 25 06:21:10 PDT 2017
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: e1323ac27635df38bd7ba3b284101fb8ffd636a2
      https://github.com/PDAL/PDAL/commit/e1323ac27635df38bd7ba3b284101fb8ffd636a2
  Author: Pete Gadomski <pete.gadomski at gmail.com>
  Date:   2017-10-24 (Tue, 24 Oct 2017)
  Changed paths:
    M filters/private/DimRange.cpp
    A test/data/las/gps-time-nan.las
    M test/unit/filters/RangeFilterTest.cpp
  Log Message:
`DimRange::valuePasses` should always be false (modulo `m_negate`) if v
is nan. Includes test case.
  Commit: 22f2dfc4f3e5d28435c15178548f2539f4e31b0f
      https://github.com/PDAL/PDAL/commit/22f2dfc4f3e5d28435c15178548f2539f4e31b0f
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2017-10-25 (Wed, 25 Oct 2017)
  Changed paths:
  Log Message:
  Merge pull request #1708 from gadomski/range-with-nan
Compare: https://github.com/PDAL/PDAL/compare/3221f81108c0...22f2dfc4f3e5
More information about the pdal-commits mailing list
