[pdal-commits] [PDAL/PDAL] dd3df0: Use Alpine v3.6 for main and community, edge for t...
GitHub
noreply at github.com
Wed Oct 25 08:32:23 PDT 2017
Branch: refs/heads/compression
Home: https://github.com/PDAL/PDAL
Commit: dd3df03b15c61dfe3df696efededff5194e35029
https://github.com/PDAL/PDAL/commit/dd3df03b15c61dfe3df696efededff5194e35029
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-10-13 (Fri, 13 Oct 2017)
Changed paths:
M .travis.yml
Log Message:
Use Alpine v3.6 for main and community, edge for testing
Commit: 7f35d09cbe39fd48bc4dce5862a9be0def3de4c3
https://github.com/PDAL/PDAL/commit/7f35d09cbe39fd48bc4dce5862a9be0def3de4c3
Changed paths:
M scripts/docker/1.4-maintenance/alpine/Dockerfile
M scripts/docker/1.5-maintenance/alpine/Dockerfile
A scripts/docker/1.6-maintenance/alpine/Dockerfile
A scripts/docker/1.6-maintenance/ubuntu/Dockerfile
M scripts/docker/master/alpine/Dockerfile
Log Message:
Base all Alpine Docker images on Alpine v3.6 instead of edge; add 1.6-maintenance images
Commit: 3221f81108c04c10a70f3480dabdade0c267de86
https://github.com/PDAL/PDAL/commit/3221f81108c04c10a70f3480dabdade0c267de86
Author: Howard Butler <howard at hobu.co>
Changed paths:
M cmake/cpack.cmake
Log Message:
cpack ignores
Commit: e1323ac27635df38bd7ba3b284101fb8ffd636a2
https://github.com/PDAL/PDAL/commit/e1323ac27635df38bd7ba3b284101fb8ffd636a2
Author: Pete Gadomski <pete.gadomski at gmail.com>
Date: 2017-10-24 (Tue, 24 Oct 2017)
Changed paths:
M filters/private/DimRange.cpp
A test/data/las/gps-time-nan.las
M test/unit/filters/RangeFilterTest.cpp
Log Message:
Always reject nan values with the range filter
`DimRange::valuePasses` should always be false (modulo `m_negate`) if v
is nan. Includes test case.
Commit: 22f2dfc4f3e5d28435c15178548f2539f4e31b0f
https://github.com/PDAL/PDAL/commit/22f2dfc4f3e5d28435c15178548f2539f4e31b0f
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2017-10-25 (Wed, 25 Oct 2017)
Changed paths:
Log Message:
Merge pull request #1708 from gadomski/range-with-nan
Commit: 9742cab1d6d0cd29f8a006dd3bfc25422809372a
https://github.com/PDAL/PDAL/commit/9742cab1d6d0cd29f8a006dd3bfc25422809372a
Changed paths:
A doc/development/alpine.rst
M doc/development/index.rst
Log Message:
Add some Alpine docs in the development section
Commit: ea6d62c0e8b86de582f85c95470d74fcafa58783
https://github.com/PDAL/PDAL/commit/ea6d62c0e8b86de582f85c95470d74fcafa58783
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1709 from PDAL/alpine-docs
Commit: e92e5f79e4cf452656af24fa7d5b26ac1b458b43
https://github.com/PDAL/PDAL/commit/e92e5f79e4cf452656af24fa7d5b26ac1b458b43
Changed paths:
M doc/apps/index.rst
Log Message:
Use json instead of xml in apps/index docs (#1710)
Commit: c53ad0b84dc5c4340afb84c5608dd82fb547b00c
https://github.com/PDAL/PDAL/commit/c53ad0b84dc5c4340afb84c5608dd82fb547b00c
Author: Grigory <gr.pomadchin at gmail.com>
Changed paths:
M java/README.md
M java/build.sbt
M java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
M java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
M java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
M java/project/build.properties
Log Message:
Update PDAL Scala DSL up to 1.6.0 (#1707)
Commit: 97d92a4510a984e150399b7ba7a25ed38823f6ce
https://github.com/PDAL/PDAL/commit/97d92a4510a984e150399b7ba7a25ed38823f6ce
Changed paths:
M .travis.yml
Log Message:
Merge pull request #1704 from PDAL/base-travis-on-alpine-3.6
Commit: 94fccefbd16663bd32f1d3d8f724681a74e24aa9
https://github.com/PDAL/PDAL/commit/94fccefbd16663bd32f1d3d8f724681a74e24aa9
Changed paths:
Log Message:
Merge pull request #1705 from PDAL/update-dockerfiles-too
Base all Alpine Docker images on Alpine v3.6 instead of edge; add 1.6…
Commit: 4c6f66f3544d7142e66b8054ef05b6d6a6e6567c
https://github.com/PDAL/PDAL/commit/4c6f66f3544d7142e66b8054ef05b6d6a6e6567c
Changed paths:
M .travis.yml
M cmake/cpack.cmake
M java/README.md
M java/build.sbt
Log Message:
Merge remote-tracking branch 'origin/master' into compression
Commit: 9752ac45b3271a6fb56f3e7cf5368b5c9a023525
https://github.com/PDAL/PDAL/commit/9752ac45b3271a6fb56f3e7cf5368b5c9a023525
Changed paths:
M pdal/Compression.hpp
Log Message:
Use proper casting to avoid warnings on Linux.
Compare: https://github.com/PDAL/PDAL/compare/116e28df2523...9752ac45b327
More information about the pdal-commits
