[pdal-commits] [PDAL/PDAL] 58e267: Implement support for LASzip 3.1.0 (#1668)
GitHub noreply at github.com
Wed Sep 13 19:35:41 PDT 2017
  Branch: refs/tags/dependencies
  Home:   https://github.com/PDAL/PDAL
  Commit: 58e2678232fb6ff02333d9ebdf94851769553d1b
      https://github.com/PDAL/PDAL/commit/58e2678232fb6ff02333d9ebdf94851769553d1b
  Author: Howard Butler <howard at hobu.co>
  Date:   2017-09-13 (Wed, 13 Sep 2017)
  Changed paths:
    M CMakeLists.txt
    M cmake/laszip.cmake
    M cmake/modules/FindLASzip.cmake
    M io/LasHeader.cpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    R io/LasZipPoint.cpp
    R io/LasZipPoint.hpp
    M pdal/pdal_config.cpp
    A test/data/las/autzen_trim_7.las
    M test/unit/apps/pc2pcTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
* Testing
* More testing
* More testing
* More testing.
* More testing.
* Test travis build.
* Works against new laszip api.
* This is a merge.
* Test for laszip of 1.4 point format.
* Update for new API.
* Fix location of setting point format/size.
Add error handling to laszip functions.
* Fixes for laszip API installation/version detection.
* Add missing comma .
* Remove dead code.
* Update to changed API.
* require LASzip 3.1.0
  Commit: a3c4c84a4c36ad51dd7bb46ebd5a5e33f9c00418
      https://github.com/PDAL/PDAL/commit/a3c4c84a4c36ad51dd7bb46ebd5a5e33f9c00418
  Changed paths:
    M CMakeLists.txt
    M io/LasHeader.cpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
Compare: https://github.com/PDAL/PDAL/compare/a3f46d60e227...a3c4c84a4c36
More information about the pdal-commits mailing list
