[pdal-commits] [PDAL/PDAL] d3dc64: Remove 2D and output filename options from delta k...
GitHub
noreply at github.com
Wed Sep 20 11:20:17 PDT 2017
Branch: refs/heads/master
Home: https://github.com/PDAL/PDAL
Commit: d3dc64b9afe6ddf21d8ab7ec1524de5cb0b90474
https://github.com/PDAL/PDAL/commit/d3dc64b9afe6ddf21d8ab7ec1524de5cb0b90474
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2017-09-20 (Wed, 20 Sep 2017)
Changed paths:
M doc/apps/delta.rst
M kernels/DeltaKernel.cpp
M kernels/DeltaKernel.hpp
Log Message:
Remove 2D and output filename options from delta kernel
While parsed (and even required in the case of output filename), neither of
these have any impact on the code as written.
Commit: c44471ebb7790a521c1449dee4e4e773137f22a2
https://github.com/PDAL/PDAL/commit/c44471ebb7790a521c1449dee4e4e773137f22a2
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
Log Message:
Merge pull request #1676 from PDAL/issue/1674-dead-args
Compare: https://github.com/PDAL/PDAL/compare/0a36d7048bfb...c44471ebb779
More information about the pdal-commits
