[pdal-commits] [PDAL/PDAL] 0dc6c9: Make pipeline stream if possible.
GitHub
noreply at github.com
Mon Apr 2 11:18:54 PDT 2018
Branch: refs/heads/numpy
Home: https://github.com/PDAL/PDAL
Commit: 0dc6c926bc38158aa71803b2e5ebcf6b05bca8a0
https://github.com/PDAL/PDAL/commit/0dc6c926bc38158aa71803b2e5ebcf6b05bca8a0
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-03-27 (Tue, 27 Mar 2018)
Changed paths:
M doc/apps/info.rst
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M doc/faq.rst
M doc/pipeline.rst
M kernels/PipelineKernel.cpp
Log Message:
Update docs on streaming.
Commit: d7d129dc2dd351323f207c6f277ef46fa23346fd
https://github.com/PDAL/PDAL/commit/d7d129dc2dd351323f207c6f277ef46fa23346fd
Author: Alvaro Huarte <ahuarte47 at yahoo.es>
Date: 2018-03-28 (Wed, 28 Mar 2018)
Changed paths:
M doc/apps/info.rst
M kernels/InfoKernel.cpp
M kernels/InfoKernel.hpp
Log Message:
Add enumerate option to info command (#1875)
Commit: 1db56759ad3a187f7ebbfcf240704cdd74bcb34d
https://github.com/PDAL/PDAL/commit/1db56759ad3a187f7ebbfcf240704cdd74bcb34d
Changed paths:
Log Message:
Undo streaming since it can't work in some cases right now.
Commit: 9629032f4f9e12750c6fb35130f2b8dbd9b93db6
https://github.com/PDAL/PDAL/commit/9629032f4f9e12750c6fb35130f2b8dbd9b93db6
Changed paths:
M doc/apps/info.rst
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: c6588aaa1a39168ffbd165b85f493fbd8a3395e4
https://github.com/PDAL/PDAL/commit/c6588aaa1a39168ffbd165b85f493fbd8a3395e4
Changed paths:
M doc/pipeline.rst
Log Message:
Doc update.
Commit: 2c581e5b628483272d43e4de5b0c1f0b73f846ad
https://github.com/PDAL/PDAL/commit/2c581e5b628483272d43e4de5b0c1f0b73f846ad
Date: 2018-03-29 (Thu, 29 Mar 2018)
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M plugins/nitf/io/NitfWriter.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/io/BPFTest.cpp
M test/unit/io/PlyReaderTest.cpp
Log Message:
Fix the streaming interface by making the stream-based execute function virtual. (#1876)
Commit: 67950cf055241436b8d4d50baabd67b737b47a6b
https://github.com/PDAL/PDAL/commit/67950cf055241436b8d4d50baabd67b737b47a6b
Author: Bradley J Chambers <brad.chambers at gmail.com>
Changed paths:
M plugins/nitf/io/tre_plugins.hpp
Log Message:
Suppress more warnings in NITF plugin
Commit: a577b70159b0f3be927a02caef94b5a54b4aac3a
https://github.com/PDAL/PDAL/commit/a577b70159b0f3be927a02caef94b5a54b4aac3a
Date: 2018-03-30 (Fri, 30 Mar 2018)
Changed paths:
M io/TextReader.cpp
Log Message:
Remove debug.
Commit: e938d5c735fc53cc0d01559199be5b0dff0ab056
https://github.com/PDAL/PDAL/commit/e938d5c735fc53cc0d01559199be5b0dff0ab056
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
Log Message:
Commit: 890eb6610d16949c8949c4656af425b167a6005b
https://github.com/PDAL/PDAL/commit/890eb6610d16949c8949c4656af425b167a6005b
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M scripts/appveyor/config.cmd
M test/unit/SpatialReferenceTest.cpp
M test/unit/TestConfig.hpp.in
M test/unit/apps/TIndexTest.cpp
M test/unit/filters/ColorinterpFilterTest.cpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
M vendor/pdalboost/libs/filesystem/src/windows_file_codecvt.cpp
Log Message:
Fixes for windows
Commit: 6a107f9af02f048d8613ff516e4d1fbc017e5b66
https://github.com/PDAL/PDAL/commit/6a107f9af02f048d8613ff516e4d1fbc017e5b66
Changed paths:
Log Message:
Build in subdirectory
Commit: 193740bc036d505a4e163112bf7edde1adfc9920
https://github.com/PDAL/PDAL/commit/193740bc036d505a4e163112bf7edde1adfc9920
Changed paths:
M appveyor.yml
Log Message:
Stay in build directory
Commit: bc8ad4c6c4ee1a4ee863d58bbd5b7ea54a098458
https://github.com/PDAL/PDAL/commit/bc8ad4c6c4ee1a4ee863d58bbd5b7ea54a098458
Changed paths:
M appveyor.yml
Log Message:
Test.
Commit: 7846dd8a1579342ab88bde55e89ed67e8d05d0e8
https://github.com/PDAL/PDAL/commit/7846dd8a1579342ab88bde55e89ed67e8d05d0e8
Changed paths:
M appveyor.yml
M scripts/appveyor/install.cmd
A scripts/appveyor/test.cmd
Log Message:
Test.
Commit: ee2f117ba773a5444ac4debcb8d7402d2c42438b
https://github.com/PDAL/PDAL/commit/ee2f117ba773a5444ac4debcb8d7402d2c42438b
Changed paths:
M appveyor.yml
Log Message:
Another test.
Commit: 1d38650dfad62003ecad048a88f6165f1c114dbc
https://github.com/PDAL/PDAL/commit/1d38650dfad62003ecad048a88f6165f1c114dbc
Changed paths:
M appveyor.yml
Log Message:
Test 3
Commit: e61736d314c1a709b3f711382cc5b516a0295d3d
https://github.com/PDAL/PDAL/commit/e61736d314c1a709b3f711382cc5b516a0295d3d
Changed paths:
M scripts/appveyor/build.cmd
Log Message:
Test 4.
Commit: f01026904c12666438522965d899cc238173dc14
https://github.com/PDAL/PDAL/commit/f01026904c12666438522965d899cc238173dc14
Date: 2018-03-31 (Sat, 31 Mar 2018)
Changed paths:
M scripts/appveyor/test.cmd
Log Message:
Test 5.
Commit: 47a85d1894de345623e550ebb99bf1b98b42c6a1
https://github.com/PDAL/PDAL/commit/47a85d1894de345623e550ebb99bf1b98b42c6a1
Changed paths:
Log Message:
Test 6.
Commit: f1d0538f10a194121ba4022d4757d8d455b85c40
https://github.com/PDAL/PDAL/commit/f1d0538f10a194121ba4022d4757d8d455b85c40
Date: 2018-04-01 (Sun, 01 Apr 2018)
Changed paths:
M appveyor.yml
Log Message:
Test 7.
Commit: 656ba732b291df7e7d3b26340329494a8540f853
https://github.com/PDAL/PDAL/commit/656ba732b291df7e7d3b26340329494a8540f853
Changed paths:
M appveyor.yml
Log Message:
Test 8.
Commit: 52d48a17ff56fcebfd04fc8b35aec3870802eae7
https://github.com/PDAL/PDAL/commit/52d48a17ff56fcebfd04fc8b35aec3870802eae7
Changed paths:
M appveyor.yml
Log Message:
Test 9.
Commit: 58fe027c6fd1051be314a476350adf875125426b
https://github.com/PDAL/PDAL/commit/58fe027c6fd1051be314a476350adf875125426b
Changed paths:
M CMakeLists.txt
M appveyor.yml
Log Message:
Test 10.
Commit: e34b748569b0ad24d8238b462989018eea7913de
https://github.com/PDAL/PDAL/commit/e34b748569b0ad24d8238b462989018eea7913de
Changed paths:
M appveyor.yml
Log Message:
Test 10
Commit: d47992e519aa054654641f7e5c54b41583772991
https://github.com/PDAL/PDAL/commit/d47992e519aa054654641f7e5c54b41583772991
Changed paths:
M appveyor.yml
Log Message:
Test 11
Commit: d2c83420fcb6f3999c5e973bb566d3c3962d5000
https://github.com/PDAL/PDAL/commit/d2c83420fcb6f3999c5e973bb566d3c3962d5000
Date: 2018-04-02 (Mon, 02 Apr 2018)
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M appveyor.yml
M doc/apps/info.rst
M doc/faq.rst
M doc/pipeline.rst
M io/BpfReader.cpp
M io/TextReader.cpp
M pdal/Stage.hpp
Log Message:
Merge branch 'winfix' into numpy
Commit: df9f9569384405fb1d99e1bd6d7eca297a282e05
https://github.com/PDAL/PDAL/commit/df9f9569384405fb1d99e1bd6d7eca297a282e05
Changed paths:
M pdal/PluginManager.cpp
A test/data/plang/perlin.npy
Log Message:
Merge remote-tracking branch 'origin/numpy' into numpy
Commit: e40e273667e6b1d9de33374d7624724b7e7f6585
https://github.com/PDAL/PDAL/commit/e40e273667e6b1d9de33374d7624724b7e7f6585
Changed paths:
M plugins/python/io/CMakeLists.txt
M plugins/python/plang/Environment.cpp
M plugins/python/test/NumpyReaderTest.cpp
Log Message:
Fixes for build/test
Compare: https://github.com/PDAL/PDAL/compare/265e33b50da1...e40e273667e6
More information about the pdal-commits
