[pdal-commits] [PDAL/PDAL] b556d2: Merge remote-tracking branch 'origin/master'
GitHub
noreply at github.com
Tue Apr 3 06:32:57 PDT 2018
Branch: refs/heads/issue-1885
Home: https://github.com/PDAL/PDAL
Commit: b556d27639b4f5e6d5463e81cfc4f201b7691828
https://github.com/PDAL/PDAL/commit/b556d27639b4f5e6d5463e81cfc4f201b7691828
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-04-02 (Mon, 02 Apr 2018)
Changed paths:
M doc/apps/info.rst
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M doc/faq.rst
M doc/pipeline.rst
M doc/references.rst
M doc/stages/filters.gridprojection.rst
M doc/stages/filters.mongus.rst
M doc/stages/filters.movingleastsquares.rst
M doc/stages/filters.poisson.rst
M doc/stages/filters.rst
M doc/stages/readers.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.rst
A doc/stages/writers.sbet.rst
M filters/ApproximateCoplanarFilter.cpp
M filters/AssignFilter.cpp
M filters/ClusterFilter.cpp
M filters/ELMFilter.cpp
M filters/EigenvaluesFilter.cpp
M filters/EstimateRankFilter.cpp
M filters/HAGFilter.cpp
M io/BpfReader.cpp
M io/TextReader.cpp
M kernels/InfoKernel.cpp
M kernels/InfoKernel.hpp
M kernels/PipelineKernel.cpp
M pdal/Stage.hpp
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.hpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/io/BPFTest.cpp
M test/unit/io/PlyReaderTest.cpp
Log Message:
Commit: f38464809729c76689512daddb84dfc3be6453ce
https://github.com/PDAL/PDAL/commit/f38464809729c76689512daddb84dfc3be6453ce
Changed paths:
M pdal/PluginManager.cpp
Log Message:
Add missing '.
Commit: 5dfbb81ad77a07af36f5b15f72cdaeb850713bca
https://github.com/PDAL/PDAL/commit/5dfbb81ad77a07af36f5b15f72cdaeb850713bca
Date: 2018-04-03 (Tue, 03 Apr 2018)
Changed paths:
M CMakeLists.txt
M apps/pdal-config-bat.in
M apps/pdal-config.in
M apps/pdal.cpp
M appveyor.yml
M cmake/examples/hobu-config.sh
M cmake/python.cmake
M scripts/appveyor/build.cmd
M scripts/appveyor/config.cmd
M scripts/appveyor/install.cmd
A scripts/appveyor/test.cmd
M test/unit/SpatialReferenceTest.cpp
M test/unit/TestConfig.hpp.in
M test/unit/apps/TIndexTest.cpp
M test/unit/filters/ColorinterpFilterTest.cpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
M vendor/pdalboost/libs/filesystem/src/windows_file_codecvt.cpp
Log Message:
Commit: 9fa94a8a6b32f29c11e2b17f76a5f69830946318
https://github.com/PDAL/PDAL/commit/9fa94a8a6b32f29c11e2b17f76a5f69830946318
Changed paths:
R io/SbetCommon.cpp
M io/SbetCommon.hpp
M io/SbetReader.cpp
M io/SbetReader.hpp
M plugins/pcl/CMakeLists.txt
R plugins/pcl/io/PcdCommon.cpp
M plugins/pcl/io/PcdCommon.hpp
Log Message:
Make fileDimensions local to translation units.
Close #1885
Compare: https://github.com/PDAL/PDAL/compare/b556d27639b4^...9fa94a8a6b32
More information about the pdal-commits
