[pdal-commits] [PDAL/PDAL] 8eff99: osgeo4w triggers from 1.7-maintenance branch now
GitHub noreply at github.com
Mon Apr 9 14:17:45 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 8eff99baf6ea46094631f12a40ec661b2ec389ec
      https://github.com/PDAL/PDAL/commit/8eff99baf6ea46094631f12a40ec661b2ec389ec
  Author: Howard Butler <howard at hobu.co>
  Date:   2018-04-05 (Thu, 05 Apr 2018)
  Changed paths:
    M appveyor.yml
  Log Message:
  Commit: f3fdbb56430e36535f4309cfeda3dc551d9a6828
      https://github.com/PDAL/PDAL/commit/f3fdbb56430e36535f4309cfeda3dc551d9a6828
  Changed paths:
    M doc/project/integration.rst
  Log Message:
  no SVG due to latexpdf
  Commit: 11dcf3be74babb5dbf50be8ff91fd866d635ef20
      https://github.com/PDAL/PDAL/commit/11dcf3be74babb5dbf50be8ff91fd866d635ef20
  Changed paths:
    M HOWTORELEASE.txt
  Log Message:
  more HOWTORELEASE
  Commit: 40f1b809263f2f44588260ad6cb52af4a54ae005
      https://github.com/PDAL/PDAL/commit/40f1b809263f2f44588260ad6cb52af4a54ae005
  Changed paths:
    M scripts/appveyor/install.cmd
  Log Message:
  turn back on OSGeo4W package building
  Commit: e36d1049903817cdd92021d6580ecc1fcc4316db
      https://github.com/PDAL/PDAL/commit/e36d1049903817cdd92021d6580ecc1fcc4316db
  Changed paths:
    M appveyor.yml
  Log Message:
  package osgeo4w in the after_build call, not deploy_script
  Commit: a7d3f426cb3ed0d3c93fcda8a2355d4a22c0401a
      https://github.com/PDAL/PDAL/commit/a7d3f426cb3ed0d3c93fcda8a2355d4a22c0401a
  Date:   2018-04-06 (Fri, 06 Apr 2018)
  Changed paths:
  Log Message:
  run install in the build directory
  Commit: a46d1ce82e7321479d9404817a204480a1364078
      https://github.com/PDAL/PDAL/commit/a46d1ce82e7321479d9404817a204480a1364078
  Changed paths:
  Log Message:
  do deployment in deploy_script, only do it when OSGEO4W_BUILD==ON
  Commit: fc19e3f3a1a000d07dcd7a62e4c0819394adba01
      https://github.com/PDAL/PDAL/commit/fc19e3f3a1a000d07dcd7a62e4c0819394adba01
  Changed paths:
  Log Message:
  bad batch file syntax
  Commit: ca9ae47b1c5ecbef8ce82c369be06515f1724cb3
      https://github.com/PDAL/PDAL/commit/ca9ae47b1c5ecbef8ce82c369be06515f1724cb3
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Changed paths:
    M filters/VoxelCenterNearestNeighborFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
  Log Message:
  Fix computation of voxel indices
  Commit: 45d48c778245e51b003ee0823ebe2f0220447386
      https://github.com/PDAL/PDAL/commit/45d48c778245e51b003ee0823ebe2f0220447386
  Changed paths:
  Log Message:
  another swing at windows batch
  Commit: 3b14b89b00656d048d60a106f74709b714dfb657
      https://github.com/PDAL/PDAL/commit/3b14b89b00656d048d60a106f74709b714dfb657
  Changed paths:
    M CMakeLists.txt
    M RELEASENOTES.txt
    M appveyor.yml
    M doc/development/release-notes/1.7.0.md
    M doc/download.rst
  Log Message:
  increment version information to 1.7.1
  Commit: 732966088590b66b892c1a8ac3061179c966fb82
      https://github.com/PDAL/PDAL/commit/732966088590b66b892c1a8ac3061179c966fb82
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M io/HeaderVal.hpp
  Log Message:
  Initialize m_val in BaseHeaderVal to quiet compiler.
Close #1899
  Commit: e7f360c16ecbda448309551ec91b7c0e3b478744
      https://github.com/PDAL/PDAL/commit/e7f360c16ecbda448309551ec91b7c0e3b478744
  Changed paths:
    M plugins/python/plang/Environment.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into 1.7-maintenance
  Commit: 0007a2b46b240a318bb4926d7b5e996afcc9a9b4
      https://github.com/PDAL/PDAL/commit/0007a2b46b240a318bb4926d7b5e996afcc9a9b4
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  Move the eigen-dev package out of the virtual packages list
  Commit: 182de2ded55137046cac6b9f988a69bd129717e3
      https://github.com/PDAL/PDAL/commit/182de2ded55137046cac6b9f988a69bd129717e3
  Changed paths:
    M plugins/python/io/CMakeLists.txt
  Log Message:
  Install NumpyReader.hpp for use by Python extension
  Commit: 1aa029a1b50fbbc321a6cb2865f717d55e3ec6c0
      https://github.com/PDAL/PDAL/commit/1aa029a1b50fbbc321a6cb2865f717d55e3ec6c0
  Changed paths:
  Log Message:
  Commit: 8277c01091c9c5e6d74697e0eb51a1da14baa2d8
      https://github.com/PDAL/PDAL/commit/8277c01091c9c5e6d74697e0eb51a1da14baa2d8
  Changed paths:
  Log Message:
  Commit: 5c3fa7634fc63e755dccf690670bec8b61f67ac2
      https://github.com/PDAL/PDAL/commit/5c3fa7634fc63e755dccf690670bec8b61f67ac2
  Log Message:
  Merge remote-tracking branch 'origin/issue-1908' into 1.7-maintenance
  Commit: 3c294b6bccc1388c4257c88fc3611817adf5ef2f
      https://github.com/PDAL/PDAL/commit/3c294b6bccc1388c4257c88fc3611817adf5ef2f
  Changed paths:
  Log Message:
  always checkout 1.7-maintenance branch when building PDAL Docker container
  Commit: b295cda8a714706120a46e8c6ee74bb18a033730
      https://github.com/PDAL/PDAL/commit/b295cda8a714706120a46e8c6ee74bb18a033730
  Changed paths:
    M io/HeaderVal.hpp
  Log Message:
  Merge remote-tracking branch 'origin/issue-1899' into 1.7-maintenance
  Commit: 7ec8d388c4bf9386ffc86a39e0ee1a8d2664a40a
      https://github.com/PDAL/PDAL/commit/7ec8d388c4bf9386ffc86a39e0ee1a8d2664a40a
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/fix-voxel-indices' into 1.7-maintenance
  Commit: 5fbb7e75f4030595c86dbea0be553952d011282e
      https://github.com/PDAL/PDAL/commit/5fbb7e75f4030595c86dbea0be553952d011282e
  Changed paths:
    M io/GeotiffSupport.cpp
    M io/GeotiffSupport.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
  Log Message:
  Report error when we can't convert geotiff keys.
Cloase #1910
  Commit: 34350aacbaad6ffa4a26b864665aa81a8df4a8a7
      https://github.com/PDAL/PDAL/commit/34350aacbaad6ffa4a26b864665aa81a8df4a8a7
  Changed paths:
    M io/LasHeader.cpp
    M io/LasWriter.cpp
  Log Message:
  Merge remote-tracking branch 'origin/issue-1910' into 1.7-maintenance
  Commit: af6b7652117fbdb12c9f330570e8463e00058870
      https://github.com/PDAL/PDAL/commit/af6b7652117fbdb12c9f330570e8463e00058870
  Changed paths:
    M doc/index.rst
  Log Message:
  update front page with 1.7.1
  Commit: d31f8fee6d53fb30608e25a984fe4cbb38d2e3a2
      https://github.com/PDAL/PDAL/commit/d31f8fee6d53fb30608e25a984fe4cbb38d2e3a2
  Changed paths:
    M plugins/python/filters/CMakeLists.txt
  Log Message:
  Merge missing items
https://github.com/PDAL/PDAL/pull/1903
  Commit: f6e2d530c75d2b4378e9bae58ef891be93aca4fc
      https://github.com/PDAL/PDAL/commit/f6e2d530c75d2b4378e9bae58ef891be93aca4fc
  Changed paths:
    M appveyor.yml
  Log Message:
  install using before_deploy for appveyor
  Commit: 81ce1a6ab0625e7a1dc5117ad9f1154a4b9758b3
      https://github.com/PDAL/PDAL/commit/81ce1a6ab0625e7a1dc5117ad9f1154a4b9758b3
  Changed paths:
    M appveyor.yml
  Log Message:
  package during after_test, not before_deploy for OSGeo4W
  Commit: d6902fc3664ecfff7feff4f6b87c57b82b392a48
      https://github.com/PDAL/PDAL/commit/d6902fc3664ecfff7feff4f6b87c57b82b392a48
  Date:   2018-04-07 (Sat, 07 Apr 2018)
  Changed paths:
  Log Message:
  fix up botched merge #1903
  Commit: fb002d548270c32e866a6f559d2c58bfde0ca5ba
      https://github.com/PDAL/PDAL/commit/fb002d548270c32e866a6f559d2c58bfde0ca5ba
  Date:   2018-04-09 (Mon, 09 Apr 2018)
  Changed paths:
    M cmake/unix_compiler_options.cmake
  Log Message:
  remove -Werror #1915
  Commit: 0c4345464037d2c1058b299e9f9f3a33c4f754ae
      https://github.com/PDAL/PDAL/commit/0c4345464037d2c1058b299e9f9f3a33c4f754ae
  Changed paths:
    M io/HeaderVal.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
  Log Message:
  Merge branch 'master' of github.com:PDAL/PDAL
  Commit: f22bffd723c530af57d89eb97609fcdda253bc4f
      https://github.com/PDAL/PDAL/commit/f22bffd723c530af57d89eb97609fcdda253bc4f
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M RELEASENOTES.txt
    M appveyor.yml
    M doc/download.rst
    M doc/index.rst
  Log Message:
  Merge commit 'fb002d548270c32e866a6f559d2c58bfde0ca5ba'
Compare: https://github.com/PDAL/PDAL/compare/5decb5400be5...f22bffd723c5
More information about the pdal-commits mailing list
