[pdal-commits] [PDAL/PDAL] c0efae: generating doxygen (#1761)
GitHub
noreply at github.com
Thu Apr 12 10:22:13 PDT 2018
Branch: refs/heads/mbio
Home: https://github.com/PDAL/PDAL
Commit: c0efae4236db9bc759a7ab8174405bf0ada2a5ac
https://github.com/PDAL/PDAL/commit/c0efae4236db9bc759a7ab8174405bf0ada2a5ac
Author: Vicky Vergara <vicky at georepublic.de>
Date: 2018-03-23 (Fri, 23 Mar 2018)
Changed paths:
A doxygen/.gitignore
A doxygen/Doxyfile
A doxygen/DoxygenLayout.xml
Log Message:
Commit: 6d86aa138c248fd471d34e3f5b29265351654fed
https://github.com/PDAL/PDAL/commit/6d86aa138c248fd471d34e3f5b29265351654fed
Author: Grigory <gr.pomadchin at gmail.com>
Changed paths:
M CMakeLists.txt
M HOWTORELEASE.txt
R cmake/pdaljni.cmake
R java/.gitignore
R java/README.md
R java/build.sbt
R java/core-scala/src/main/scala/io/pdal/pipeline/ExprType.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/FilterTypes.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/Implicits.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/PipelineExpressions.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/ReaderTypes.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/WriterTypes.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/json/Implicits.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/json/package.scala
R java/core-scala/src/main/scala/io/pdal/pipeline/package.scala
R java/core-scala/src/test/scala/io/pdal/pipeline/PipelineExpressionsSpec.scala
R java/core/src/main/scala/io/pdal/DimType.scala
R java/core/src/main/scala/io/pdal/Native.scala
R java/core/src/main/scala/io/pdal/Pipeline.scala
R java/core/src/main/scala/io/pdal/PointCloud.scala
R java/core/src/main/scala/io/pdal/PointLayout.scala
R java/core/src/main/scala/io/pdal/PointView.scala
R java/core/src/main/scala/io/pdal/PointViewIterator.scala
R java/core/src/main/scala/io/pdal/SizedDimType.scala
R java/core/src/test/resources/las.json
R java/core/src/test/scala/io/pdal/PipelineSpec.scala
R java/core/src/test/scala/io/pdal/PointCloudSpec.scala
R java/core/src/test/scala/io/pdal/TestEnvironmentSpec.scala
R java/native/src/Accessors.cpp
R java/native/src/CMakeLists.txt
R java/native/src/JavaPipeline.cpp
R java/native/src/PointViewRawPtr.cpp
R java/native/src/include/Accessors.hpp
R java/native/src/include/JavaIterator.hpp
R java/native/src/include/JavaPipeline.hpp
R java/native/src/include/PointViewRawPtr.hpp
R java/native/src/include/io_pdal_Pipeline.h
R java/native/src/include/io_pdal_PointLayout.h
R java/native/src/include/io_pdal_PointView.h
R java/native/src/include/io_pdal_PointViewIterator.h
R java/native/src/io_pdal_Pipeline.cpp
R java/native/src/io_pdal_PointLayout.cpp
R java/native/src/io_pdal_PointView.cpp
R java/native/src/io_pdal_PointViewIterator.cpp
R java/project/Commands.scala
R java/project/Dependencies.scala
R java/project/Environment.scala
R java/project/Version.scala
R java/project/build.properties
R java/project/plugins.sbt
R java/sbt
R java/scripts/publish-212.sh
R java/scripts/publish-all.sh
R java/scripts/publish-javastyle.sh
R java/scripts/publish-local-212.sh
R java/scripts/publish-local.sh
R java/scripts/publish.sh
Log Message:
Remove PDAL java package as it's in a separate repo now (#1870)
Commit: 9a08de8e1437f7d3276fec3c4c5dd95356d4dcd8
https://github.com/PDAL/PDAL/commit/9a08de8e1437f7d3276fec3c4c5dd95356d4dcd8
Author: Bradley J Chambers <brad.chambers at gmail.com>
Date: 2018-03-24 (Sat, 24 Mar 2018)
Changed paths:
M plugins/nitf/io/tre_plugins.hpp
Log Message:
Suppressing more GCC warnings in nitro
Commit: b9d0b3ccb7a877477811e48541077bb76f5bedc6
https://github.com/PDAL/PDAL/commit/b9d0b3ccb7a877477811e48541077bb76f5bedc6
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-03-26 (Mon, 26 Mar 2018)
Changed paths:
M filters/NeighborClassifierFilter.cpp
M vendor/kazhdan/PoissonRecon.h
Log Message:
Windows warning fixes.
Commit: 0dc6c926bc38158aa71803b2e5ebcf6b05bca8a0
https://github.com/PDAL/PDAL/commit/0dc6c926bc38158aa71803b2e5ebcf6b05bca8a0
Date: 2018-03-27 (Tue, 27 Mar 2018)
Changed paths:
M doc/apps/info.rst
M doc/apps/pipeline.rst
M doc/apps/translate.rst
M doc/faq.rst
M doc/pipeline.rst
M kernels/PipelineKernel.cpp
Log Message:
Make pipeline stream if possible.
Update docs on streaming.
Commit: d7d129dc2dd351323f207c6f277ef46fa23346fd
https://github.com/PDAL/PDAL/commit/d7d129dc2dd351323f207c6f277ef46fa23346fd
Author: Alvaro Huarte <ahuarte47 at yahoo.es>
Date: 2018-03-28 (Wed, 28 Mar 2018)
Changed paths:
M doc/apps/info.rst
M kernels/InfoKernel.cpp
M kernels/InfoKernel.hpp
Log Message:
Add enumerate option to info command (#1875)
Commit: 1db56759ad3a187f7ebbfcf240704cdd74bcb34d
https://github.com/PDAL/PDAL/commit/1db56759ad3a187f7ebbfcf240704cdd74bcb34d
Changed paths:
Log Message:
Undo streaming since it can't work in some cases right now.
Commit: 9629032f4f9e12750c6fb35130f2b8dbd9b93db6
https://github.com/PDAL/PDAL/commit/9629032f4f9e12750c6fb35130f2b8dbd9b93db6
Changed paths:
M doc/apps/info.rst
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: c6588aaa1a39168ffbd165b85f493fbd8a3395e4
https://github.com/PDAL/PDAL/commit/c6588aaa1a39168ffbd165b85f493fbd8a3395e4
Changed paths:
M doc/pipeline.rst
Log Message:
Doc update.
Commit: 2c581e5b628483272d43e4de5b0c1f0b73f846ad
https://github.com/PDAL/PDAL/commit/2c581e5b628483272d43e4de5b0c1f0b73f846ad
Date: 2018-03-29 (Thu, 29 Mar 2018)
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
M pdal/Streamable.cpp
M pdal/Streamable.hpp
M plugins/nitf/io/NitfWriter.cpp
M test/unit/filters/CropFilterTest.cpp
M test/unit/io/BPFTest.cpp
M test/unit/io/PlyReaderTest.cpp
Log Message:
Fix the streaming interface by making the stream-based execute function virtual. (#1876)
Commit: 67950cf055241436b8d4d50baabd67b737b47a6b
https://github.com/PDAL/PDAL/commit/67950cf055241436b8d4d50baabd67b737b47a6b
Changed paths:
Log Message:
Suppress more warnings in NITF plugin
Commit: a577b70159b0f3be927a02caef94b5a54b4aac3a
https://github.com/PDAL/PDAL/commit/a577b70159b0f3be927a02caef94b5a54b4aac3a
Date: 2018-03-30 (Fri, 30 Mar 2018)
Changed paths:
M io/TextReader.cpp
Log Message:
Remove debug.
Commit: e938d5c735fc53cc0d01559199be5b0dff0ab056
https://github.com/PDAL/PDAL/commit/e938d5c735fc53cc0d01559199be5b0dff0ab056
Changed paths:
M io/BpfReader.cpp
M pdal/Stage.hpp
Log Message:
Commit: b844196e8b2964c18dc3abd4691e909f259464fd
https://github.com/PDAL/PDAL/commit/b844196e8b2964c18dc3abd4691e909f259464fd
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M doc/references.rst
M doc/stages/filters.gridprojection.rst
M doc/stages/filters.mongus.rst
M doc/stages/filters.movingleastsquares.rst
M doc/stages/filters.poisson.rst
M doc/stages/filters.rst
M doc/stages/readers.rst
M doc/stages/writers.bpf.rst
M doc/stages/writers.rst
A doc/stages/writers.sbet.rst
M filters/ApproximateCoplanarFilter.cpp
M filters/AssignFilter.cpp
M filters/ClusterFilter.cpp
M filters/ELMFilter.cpp
M filters/EigenvaluesFilter.cpp
M filters/EstimateRankFilter.cpp
M filters/HAGFilter.cpp
Log Message:
Improve stage overview documentation (#1880)
Convert from bulleted TOC stage listings to definition lists, whereby the
filter name and link are shown as the "term" and a brief stage description is
provided as the definition. The intent is to provide a simpler overview of our
growing list of stages.
Filters are also broken into some categories that attempt to capture what they
do to the data (like creating new dimensions, culling points, etc.).
Commit: 08449c3a83f9f4606676fb5a0c8a1b2aba3a96a2
https://github.com/PDAL/PDAL/commit/08449c3a83f9f4606676fb5a0c8a1b2aba3a96a2
Date: 2018-04-02 (Mon, 02 Apr 2018)
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M appveyor.yml
M scripts/appveyor/build.cmd
M scripts/appveyor/config.cmd
M scripts/appveyor/install.cmd
A scripts/appveyor/test.cmd
M test/unit/SpatialReferenceTest.cpp
M test/unit/TestConfig.hpp.in
M test/unit/apps/TIndexTest.cpp
M test/unit/filters/ColorinterpFilterTest.cpp
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
M vendor/pdalboost/libs/filesystem/src/windows_file_codecvt.cpp
Log Message:
Winfix (#1883)
Commit: e02ff75e82d1678f435b6876dc03acd282531b75
https://github.com/PDAL/PDAL/commit/e02ff75e82d1678f435b6876dc03acd282531b75
Author: Howard Butler <howard at hobu.co>
Changed paths:
M apps/pdal-config-bat.in
M apps/pdal-config.in
M cmake/examples/hobu-config.sh
M cmake/python.cmake
Log Message:
cache PDAL_PYTHON_VERSION_STRING to inform pdal-config and friends
Commit: aebfe52f167b9dd152a3701974fc699ba7913c79
https://github.com/PDAL/PDAL/commit/aebfe52f167b9dd152a3701974fc699ba7913c79
Date: 2018-04-03 (Tue, 03 Apr 2018)
Changed paths:
M .gitignore
A doc/stages/readers.numpy.rst
M pdal/PluginManager.cpp
M pdal/StageExtensions.cpp
M plugins/python/CMakeLists.txt
M plugins/python/filters/CMakeLists.txt
A plugins/python/io/CMakeLists.txt
A plugins/python/io/NumpyReader.cpp
A plugins/python/io/NumpyReader.hpp
M plugins/python/plang/Environment.cpp
M plugins/python/plang/Environment.hpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Redirector.hpp
A plugins/python/test/NumpyReaderTest.cpp
A plugins/python/test/make-test-data.py
A test/data/plang/1.2-with-color.npy
A test/data/plang/perlin.npy
Log Message:
Add readers.numpy (#1887)
Commit: 8db9968df50e1f6c78785fc3f1bfbb8d2a585577
https://github.com/PDAL/PDAL/commit/8db9968df50e1f6c78785fc3f1bfbb8d2a585577
Changed paths:
M apps/pdal.cpp
M pdal/Log.cpp
M pdal/Log.hpp
M test/unit/apps/AppTest.cpp
Log Message:
Add log timing on request. (#1884)
Close #1882
Commit: 6718373cedcb30bb701627bbcb845644044f6b7c
https://github.com/PDAL/PDAL/commit/6718373cedcb30bb701627bbcb845644044f6b7c
Changed paths:
M doc/tutorial/las.rst
Log Message:
doc cleanups
Commit: 3c66b820ef87c933cfaec39b06a96112f91eca84
https://github.com/PDAL/PDAL/commit/3c66b820ef87c933cfaec39b06a96112f91eca84
Changed paths:
M cmake/policies.cmake
Log Message:
default to new cmake policy for interface link libraries (CMP0022) (#1890)
Commit: 1f098027ff60e2ba1f13fcec2debb6217b2f0fc0
https://github.com/PDAL/PDAL/commit/1f098027ff60e2ba1f13fcec2debb6217b2f0fc0
Changed paths:
M .travis.yml
M CMakeLists.txt
M ChangeLog
M HOWTORELEASE.txt
M doc/development/compilation/windows.rst
A doc/development/release-notes/1.7.0.md
M doc/download.rst
M doc/index.rst
M doc/quickstart.rst
Log Message:
1.7 release preparation
Commit: ec30308e45f89f70b5fe677b44f6f3123f3ce6b8
https://github.com/PDAL/PDAL/commit/ec30308e45f89f70b5fe677b44f6f3123f3ce6b8
Changed paths:
M CMakeLists.txt
Log Message:
PDAL_PLUGIN_INSTALL_PATH is bin not lib on windows
Commit: 15aaf6b6bf9cf6ac02bd3016e7c207a4fe701ab7
https://github.com/PDAL/PDAL/commit/15aaf6b6bf9cf6ac02bd3016e7c207a4fe701ab7
Changed paths:
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: abf697a42254a4bb5d4955163e755193dfa05da6
https://github.com/PDAL/PDAL/commit/abf697a42254a4bb5d4955163e755193dfa05da6
Changed paths:
M CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master' into 1.7-release-prep
Commit: 20d67ca7385fc10f6269f2cf8265c029f94bb305
https://github.com/PDAL/PDAL/commit/20d67ca7385fc10f6269f2cf8265c029f94bb305
Changed paths:
R io/SbetCommon.cpp
M io/SbetCommon.hpp
M io/SbetReader.cpp
M io/SbetReader.hpp
M plugins/pcl/CMakeLists.txt
R plugins/pcl/io/PcdCommon.cpp
M plugins/pcl/io/PcdCommon.hpp
Log Message:
Issue 1885 (#1888)
* Test updates.
* Add missing '.
* Make fileDimensions local to translation units.
Close #1885
Commit: 1925d08e5ca0659306fbbeda63e9946899bb19c3
https://github.com/PDAL/PDAL/commit/1925d08e5ca0659306fbbeda63e9946899bb19c3
Date: 2018-04-04 (Wed, 04 Apr 2018)
Changed paths:
M filters/ReprojectionFilter.cpp
M pdal/PointView.hpp
Log Message:
Set stage's SRS, not point view's SRS.
Close #1877
Commit: c9a06fd42f48782e505071043ab4ac95c176edf2
https://github.com/PDAL/PDAL/commit/c9a06fd42f48782e505071043ab4ac95c176edf2
Changed paths:
M pdal/PluginDirectory.cpp
M test/unit/PluginManagerTest.cpp
Log Message:
Use semicolon as path separator on Windows (#1891)
Commit: 0c075779e16c044725f5dc4b244e9f5fa94acf76
https://github.com/PDAL/PDAL/commit/0c075779e16c044725f5dc4b244e9f5fa94acf76
Date: 2018-04-05 (Thu, 05 Apr 2018)
Changed paths:
M doc/apps/info.rst
M kernels/PipelineKernel.hpp
M kernels/TranslateKernel.cpp
M kernels/TranslateKernel.hpp
M pdal/Stage.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Add --nostream option to pipeline and translate kernels. (#1897)
Add debug hooks to facilitate stream/standard testing.
Update doc.
Close #1895.
Commit: 032c844a9813317875f219b5468ad80472c363c8
https://github.com/PDAL/PDAL/commit/032c844a9813317875f219b5468ad80472c363c8
Changed paths:
M HOWTORELEASE.txt
Log Message:
note updating download.rst for HOWTORELEASE
Commit: 9551f0bb7f19f1ea3594d0dbe5809fbb8f9698fb
https://github.com/PDAL/PDAL/commit/9551f0bb7f19f1ea3594d0dbe5809fbb8f9698fb
Changed paths:
M doc/apps/info.rst
R io/SbetCommon.cpp
M io/SbetCommon.hpp
M io/SbetReader.cpp
M io/SbetReader.hpp
M pdal/Stage.cpp
Log Message:
Commit: a60d9ac422a4a6511cb7125cd9f2250ec87ee5e4
https://github.com/PDAL/PDAL/commit/a60d9ac422a4a6511cb7125cd9f2250ec87ee5e4
Author: Connor Manning <connor at hobu.co>
Changed paths:
Log Message:
Fix comment typo.
Commit: 71237732860b8c03b93e1fb36fdaf18036084b6c
https://github.com/PDAL/PDAL/commit/71237732860b8c03b93e1fb36fdaf18036084b6c
Changed paths:
M .gitignore
M CMakeLists.txt
M HOWTORELEASE.txt
M apps/pdal.cpp
M appveyor.yml
M doc/apps/info.rst
M doc/faq.rst
M doc/pipeline.rst
A doxygen/Doxyfile
M io/BpfReader.cpp
R io/SbetCommon.cpp
M io/SbetCommon.hpp
M io/SbetReader.cpp
M io/SbetReader.hpp
M io/TextReader.cpp
R java/.gitignore
R java/README.md
R java/build.sbt
R java/sbt
M pdal/Log.cpp
M pdal/Log.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into mbio
Commit: 58f7b04efba329316aada77bdb4dfb3fd409375f
https://github.com/PDAL/PDAL/commit/58f7b04efba329316aada77bdb4dfb3fd409375f
Changed paths:
M doc/faq.rst
Log Message:
point to hipster interview for PDAL background
Commit: 305105239dfd82ea15e121dcb30d7e97f6e612a4
https://github.com/PDAL/PDAL/commit/305105239dfd82ea15e121dcb30d7e97f6e612a4
Changed paths:
Log Message:
Commit: 128e256c2b0952735c77ead940527d3303c59d6c
https://github.com/PDAL/PDAL/commit/128e256c2b0952735c77ead940527d3303c59d6c
Changed paths:
Log Message:
Remove initializer from tm because it generates warning and we're going (#1898)
to fill it in anyway.
Commit: 4f12bec9770716c4506f92196791f02731ed2457
https://github.com/PDAL/PDAL/commit/4f12bec9770716c4506f92196791f02731ed2457
Changed paths:
M ChangeLog
M RELEASENOTES.txt
M doc/development/release-notes/1.7.0.md
Log Message:
release notes updates
Commit: c5816ac474aed534573172cdb578a534291737b4
https://github.com/PDAL/PDAL/commit/c5816ac474aed534573172cdb578a534291737b4
Changed paths:
Log Message:
Commit: efdac171f338087b75e24e40707ea9d32d05b843
https://github.com/PDAL/PDAL/commit/efdac171f338087b75e24e40707ea9d32d05b843
Changed paths:
M doc/pipeline.rst
Log Message:
Update doc.
Commit: 5ab1c360daad552c39eaa63f2c8d5d7b1d93d025
https://github.com/PDAL/PDAL/commit/5ab1c360daad552c39eaa63f2c8d5d7b1d93d025
Changed paths:
M .travis.yml
M CMakeLists.txt
M ChangeLog
M HOWTORELEASE.txt
M RELEASENOTES.txt
M doc/download.rst
M doc/faq.rst
M doc/index.rst
Log Message:
Merge branch '1.7-release-prep'
Commit: 8eff99baf6ea46094631f12a40ec661b2ec389ec
https://github.com/PDAL/PDAL/commit/8eff99baf6ea46094631f12a40ec661b2ec389ec
Changed paths:
M appveyor.yml
Log Message:
osgeo4w triggers from 1.7-maintenance branch now
Commit: f3fdbb56430e36535f4309cfeda3dc551d9a6828
https://github.com/PDAL/PDAL/commit/f3fdbb56430e36535f4309cfeda3dc551d9a6828
Changed paths:
M doc/project/integration.rst
Log Message:
no SVG due to latexpdf
Commit: 11dcf3be74babb5dbf50be8ff91fd866d635ef20
https://github.com/PDAL/PDAL/commit/11dcf3be74babb5dbf50be8ff91fd866d635ef20
Changed paths:
M HOWTORELEASE.txt
Log Message:
more HOWTORELEASE
Commit: 40f1b809263f2f44588260ad6cb52af4a54ae005
https://github.com/PDAL/PDAL/commit/40f1b809263f2f44588260ad6cb52af4a54ae005
Changed paths:
Log Message:
turn back on OSGeo4W package building
Commit: e36d1049903817cdd92021d6580ecc1fcc4316db
https://github.com/PDAL/PDAL/commit/e36d1049903817cdd92021d6580ecc1fcc4316db
Changed paths:
M appveyor.yml
Log Message:
package osgeo4w in the after_build call, not deploy_script
Commit: a7d3f426cb3ed0d3c93fcda8a2355d4a22c0401a
https://github.com/PDAL/PDAL/commit/a7d3f426cb3ed0d3c93fcda8a2355d4a22c0401a
Date: 2018-04-06 (Fri, 06 Apr 2018)
Changed paths:
Log Message:
run install in the build directory
Commit: 952487da55430e3804f7c73387353a73c3c40f62
https://github.com/PDAL/PDAL/commit/952487da55430e3804f7c73387353a73c3c40f62
Changed paths:
M plugins/mbio/io/MbReader.cpp
Log Message:
Set proper dimensions based on datatype option.
Commit: a46d1ce82e7321479d9404817a204480a1364078
https://github.com/PDAL/PDAL/commit/a46d1ce82e7321479d9404817a204480a1364078
Changed paths:
Log Message:
do deployment in deploy_script, only do it when OSGEO4W_BUILD==ON
Commit: fc19e3f3a1a000d07dcd7a62e4c0819394adba01
https://github.com/PDAL/PDAL/commit/fc19e3f3a1a000d07dcd7a62e4c0819394adba01
Changed paths:
Log Message:
bad batch file syntax
Commit: ca9ae47b1c5ecbef8ce82c369be06515f1724cb3
https://github.com/PDAL/PDAL/commit/ca9ae47b1c5ecbef8ce82c369be06515f1724cb3
Changed paths:
M filters/VoxelCenterNearestNeighborFilter.cpp
M filters/VoxelCentroidNearestNeighborFilter.cpp
Log Message:
Fix computation of voxel indices
Commit: 45d48c778245e51b003ee0823ebe2f0220447386
https://github.com/PDAL/PDAL/commit/45d48c778245e51b003ee0823ebe2f0220447386
Changed paths:
Log Message:
another swing at windows batch
Commit: ef623d78adf79796173f5ee3442a42b7645cd0be
https://github.com/PDAL/PDAL/commit/ef623d78adf79796173f5ee3442a42b7645cd0be
Changed paths:
Log Message:
Update comment to reflect current state of code.
Commit: e121748d677eb8b43966f8cbcf437516a19a2507
https://github.com/PDAL/PDAL/commit/e121748d677eb8b43966f8cbcf437516a19a2507
Changed paths:
M .travis.yml
M CMakeLists.txt
M ChangeLog
M HOWTORELEASE.txt
M RELEASENOTES.txt
M doc/download.rst
M doc/faq.rst
M doc/index.rst
Log Message:
Commit: 3b14b89b00656d048d60a106f74709b714dfb657
https://github.com/PDAL/PDAL/commit/3b14b89b00656d048d60a106f74709b714dfb657
Changed paths:
M CMakeLists.txt
M RELEASENOTES.txt
M appveyor.yml
M doc/download.rst
Log Message:
increment version information to 1.7.1
Commit: 732966088590b66b892c1a8ac3061179c966fb82
https://github.com/PDAL/PDAL/commit/732966088590b66b892c1a8ac3061179c966fb82
Changed paths:
M io/HeaderVal.hpp
Log Message:
Initialize m_val in BaseHeaderVal to quiet compiler.
Close #1899
Commit: e7f360c16ecbda448309551ec91b7c0e3b478744
https://github.com/PDAL/PDAL/commit/e7f360c16ecbda448309551ec91b7c0e3b478744
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into 1.7-maintenance
Commit: 0007a2b46b240a318bb4926d7b5e996afcc9a9b4
https://github.com/PDAL/PDAL/commit/0007a2b46b240a318bb4926d7b5e996afcc9a9b4
Changed paths:
M scripts/docker/Dockerfile
Log Message:
Move the eigen-dev package out of the virtual packages list
Commit: 182de2ded55137046cac6b9f988a69bd129717e3
https://github.com/PDAL/PDAL/commit/182de2ded55137046cac6b9f988a69bd129717e3
Changed paths:
M plugins/python/io/CMakeLists.txt
Log Message:
Install NumpyReader.hpp for use by Python extension
Commit: 1aa029a1b50fbbc321a6cb2865f717d55e3ec6c0
https://github.com/PDAL/PDAL/commit/1aa029a1b50fbbc321a6cb2865f717d55e3ec6c0
Changed paths:
Log Message:
Commit: ffadce39ca9d35de588970524759c9994a2e52ee
https://github.com/PDAL/PDAL/commit/ffadce39ca9d35de588970524759c9994a2e52ee
Changed paths:
Log Message:
Move the eigen-dev package out of the virtual packages list (#1909)
Commit: 8277c01091c9c5e6d74697e0eb51a1da14baa2d8
https://github.com/PDAL/PDAL/commit/8277c01091c9c5e6d74697e0eb51a1da14baa2d8
Changed paths:
Log Message:
Commit: 5c3fa7634fc63e755dccf690670bec8b61f67ac2
https://github.com/PDAL/PDAL/commit/5c3fa7634fc63e755dccf690670bec8b61f67ac2
Log Message:
Merge remote-tracking branch 'origin/issue-1908' into 1.7-maintenance
Commit: 3c294b6bccc1388c4257c88fc3611817adf5ef2f
https://github.com/PDAL/PDAL/commit/3c294b6bccc1388c4257c88fc3611817adf5ef2f
Changed paths:
Log Message:
always checkout 1.7-maintenance branch when building PDAL Docker container
Commit: b295cda8a714706120a46e8c6ee74bb18a033730
https://github.com/PDAL/PDAL/commit/b295cda8a714706120a46e8c6ee74bb18a033730
Changed paths:
M io/HeaderVal.hpp
Log Message:
Merge remote-tracking branch 'origin/issue-1899' into 1.7-maintenance
Commit: 7ec8d388c4bf9386ffc86a39e0ee1a8d2664a40a
https://github.com/PDAL/PDAL/commit/7ec8d388c4bf9386ffc86a39e0ee1a8d2664a40a
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/fix-voxel-indices' into 1.7-maintenance
Commit: c709b5d118edd13f2871deb93620630241655d4d
https://github.com/PDAL/PDAL/commit/c709b5d118edd13f2871deb93620630241655d4d
Changed paths:
Log Message:
Link in libdl where necessary. (#1903)
Fix minor bugs in lib builds.
Commit: 2cb436236e71e91e4b420594ac4334798585615f
https://github.com/PDAL/PDAL/commit/2cb436236e71e91e4b420594ac4334798585615f
Changed paths:
M io/HeaderVal.hpp
Log Message:
Initialize m_val in BaseHeaderVal to quiet compiler. (#1907)
Close #1899
Commit: 5fbb7e75f4030595c86dbea0be553952d011282e
https://github.com/PDAL/PDAL/commit/5fbb7e75f4030595c86dbea0be553952d011282e
Changed paths:
M io/GeotiffSupport.cpp
M io/GeotiffSupport.hpp
M io/LasHeader.cpp
M io/LasWriter.cpp
Log Message:
Report error when we can't convert geotiff keys.
Cloase #1910
Commit: 34350aacbaad6ffa4a26b864665aa81a8df4a8a7
https://github.com/PDAL/PDAL/commit/34350aacbaad6ffa4a26b864665aa81a8df4a8a7
Changed paths:
M io/LasHeader.cpp
M io/LasWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/issue-1910' into 1.7-maintenance
Commit: a7046ff1dd2e881a72807bdc4cbc7554038c50e2
https://github.com/PDAL/PDAL/commit/a7046ff1dd2e881a72807bdc4cbc7554038c50e2
Changed paths:
M io/LasHeader.cpp
M io/LasWriter.cpp
Log Message:
Report error when we can't convert geotiff keys. (#1911)
Cloase #1910
Commit: ed68fb5e8901ef4527124bec5588f4700f156bd7
https://github.com/PDAL/PDAL/commit/ed68fb5e8901ef4527124bec5588f4700f156bd7
Changed paths:
Log Message:
Fix computation of voxel indices (#1901)
Commit: af6b7652117fbdb12c9f330570e8463e00058870
https://github.com/PDAL/PDAL/commit/af6b7652117fbdb12c9f330570e8463e00058870
Changed paths:
M doc/index.rst
Log Message:
update front page with 1.7.1
Commit: d31f8fee6d53fb30608e25a984fe4cbb38d2e3a2
https://github.com/PDAL/PDAL/commit/d31f8fee6d53fb30608e25a984fe4cbb38d2e3a2
Changed paths:
Log Message:
Merge missing items
https://github.com/PDAL/PDAL/pull/1903
Commit: f6e2d530c75d2b4378e9bae58ef891be93aca4fc
https://github.com/PDAL/PDAL/commit/f6e2d530c75d2b4378e9bae58ef891be93aca4fc
Changed paths:
M appveyor.yml
Log Message:
install using before_deploy for appveyor
Commit: 81ce1a6ab0625e7a1dc5117ad9f1154a4b9758b3
https://github.com/PDAL/PDAL/commit/81ce1a6ab0625e7a1dc5117ad9f1154a4b9758b3
Changed paths:
M appveyor.yml
Log Message:
package during after_test, not before_deploy for OSGeo4W
Commit: d6902fc3664ecfff7feff4f6b87c57b82b392a48
https://github.com/PDAL/PDAL/commit/d6902fc3664ecfff7feff4f6b87c57b82b392a48
Date: 2018-04-07 (Sat, 07 Apr 2018)
Changed paths:
Log Message:
fix up botched merge #1903
Commit: 5decb5400be5d8dd6a7256799e254d7efcce43b7
https://github.com/PDAL/PDAL/commit/5decb5400be5d8dd6a7256799e254d7efcce43b7
Date: 2018-04-09 (Mon, 09 Apr 2018)
Changed paths:
M io/LasHeader.cpp
Log Message:
Add some validation of Geotiff data. (#1913)
* Add some validation of Geotiff data.
* Constify things. Change an error to warning based on spec.
Commit: fb002d548270c32e866a6f559d2c58bfde0ca5ba
https://github.com/PDAL/PDAL/commit/fb002d548270c32e866a6f559d2c58bfde0ca5ba
Changed paths:
M cmake/unix_compiler_options.cmake
Log Message:
remove -Werror #1915
Commit: 0c4345464037d2c1058b299e9f9f3a33c4f754ae
https://github.com/PDAL/PDAL/commit/0c4345464037d2c1058b299e9f9f3a33c4f754ae
Changed paths:
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasWriter.cpp
Log Message:
Commit: f22bffd723c530af57d89eb97609fcdda253bc4f
https://github.com/PDAL/PDAL/commit/f22bffd723c530af57d89eb97609fcdda253bc4f
Changed paths:
M CMakeLists.txt
M HOWTORELEASE.txt
M RELEASENOTES.txt
M appveyor.yml
M doc/download.rst
M doc/index.rst
Log Message:
Merge commit 'fb002d548270c32e866a6f559d2c58bfde0ca5ba'
Commit: 225e4300d54bd2dda0e0cb879c8740778b3f6d23
https://github.com/PDAL/PDAL/commit/225e4300d54bd2dda0e0cb879c8740778b3f6d23
Date: 2018-04-10 (Tue, 10 Apr 2018)
Changed paths:
M pdal/EigenUtils.cpp
M pdal/EigenUtils.hpp
Log Message:
Change centroid calculation to do online update and return doubles
Commit: 71ea13a65a6006715ffac31cb0d88800ec94da73
https://github.com/PDAL/PDAL/commit/71ea13a65a6006715ffac31cb0d88800ec94da73
Author: Anton Wagensonner <anton.wagensonner at riegl.com>
Changed paths:
M cmake/options.cmake
A doc/stages/readers.rdb.rst
M plugins/CMakeLists.txt
A plugins/rdb/CMakeLists.txt
A plugins/rdb/io/RdbPointcloud.cpp
A plugins/rdb/io/RdbPointcloud.hpp
A plugins/rdb/io/RdbReader.cpp
A plugins/rdb/io/RdbReader.hpp
A plugins/rdb/test/Config.hpp.in
A plugins/rdb/test/RdbReaderTest.cpp
A plugins/rdb/test/data/autzen-thin-srs.rdbx
A plugins/rdb/test/data/autzen-thin-srs.txt
Log Message:
RIEGL RDB reader plugin. (#1917)
Commit: e9353e64c5d8474d7edb55fd0d00fe5f991bd030
https://github.com/PDAL/PDAL/commit/e9353e64c5d8474d7edb55fd0d00fe5f991bd030
Changed paths:
M doc/stages/readers.rxp.rst
M doc/workshop/exercises/georeferencing/index.rst
M doc/workshop/includes/substitutions.rst
M doc/workshop/slides/source/lidar_intro.rst
M plugins/rxp/CMakeLists.txt
Log Message:
Fix spelling of company and product names. (#1918)
Commit: 49baa200fc50b6027f0f747ec16be599754918da
https://github.com/PDAL/PDAL/commit/49baa200fc50b6027f0f747ec16be599754918da
Author: Peter Limkilde Svendsen <34237736+plimkilde at users.noreply.github.com>
Changed paths:
A doc/stages/filters.delaunay.rst
A plugins/delaunay/CMakeLists.txt
A plugins/delaunay/filters/DelaunayFilter.cpp
A plugins/delaunay/filters/DelaunayFilter.hpp
A plugins/delaunay/filters/Delaunay_psm.cpp
A plugins/delaunay/filters/Delaunay_psm.h
Log Message:
Add Delaunay filter (issue #1855) (#1916)
* Fix documentation of greedyprojection and gridprojection to use PLY writer
* Basic scaffolding for new filter
* Correct use of PointView
* Added Geogram PSM, currently crashes when run
* 2D Delaunay working
* Add docs for Delaunay filter
* Add license text
* Add NULL check on mesh
* Remove debugging output
* Add Delaunay filter in stage doc overview
* Fix indentation
Commit: 8d016c5358d4a98fb2fe2551342b69a0d322f470
https://github.com/PDAL/PDAL/commit/8d016c5358d4a98fb2fe2551342b69a0d322f470
Changed paths:
Log Message:
Merge pull request #1920 from PDAL/issue-1919
Commit: f37cff4c1511ffd964e72e0d606ec07cc184a8b0
https://github.com/PDAL/PDAL/commit/f37cff4c1511ffd964e72e0d606ec07cc184a8b0
Changed paths:
M plugins/rdb/CMakeLists.txt
M plugins/rdb/io/RdbPointcloud.cpp
Log Message:
A few cleanups to get RDB working locally for me (#1921)
Commit: aa2a557e542a4280b336a951e1424600519c0ace
https://github.com/PDAL/PDAL/commit/aa2a557e542a4280b336a951e1424600519c0ace
Changed paths:
M io/LasWriter.cpp
Log Message:
Don't write LAS geotiff VLRs if they contain no data. (#1914)
Commit: a85b5351daa96c76f2c3eb38914a3364467f4c67
https://github.com/PDAL/PDAL/commit/a85b5351daa96c76f2c3eb38914a3364467f4c67
Changed paths:
M appveyor.yml
Log Message:
always build appveyor with optional components
Commit: 8540cece4f810920054611bd0515a5ea5d1567cb
https://github.com/PDAL/PDAL/commit/8540cece4f810920054611bd0515a5ea5d1567cb
Changed paths:
M appveyor.yml
Log Message:
always build OSGeo4W package, attempt to consolidate to a single appveyor build
Commit: 6f5115b52ca8bab36a1d55542aa3354ae46132ae
https://github.com/PDAL/PDAL/commit/6f5115b52ca8bab36a1d55542aa3354ae46132ae
Date: 2018-04-12 (Thu, 12 Apr 2018)
Changed paths:
M pdal/util/ProgramArgs.hpp
Log Message:
Add () guard for std::max to deal with Windows.
Commit: 6e077a5d455f953d86393f336f3528318ee6853e
https://github.com/PDAL/PDAL/commit/6e077a5d455f953d86393f336f3528318ee6853e
Changed paths:
M .travis.yml
M CMakeLists.txt
M ChangeLog
M HOWTORELEASE.txt
M RELEASENOTES.txt
M appveyor.yml
M doc/download.rst
M doc/faq.rst
M doc/index.rst
M doc/pipeline.rst
M io/HeaderVal.hpp
M io/LasHeader.cpp
M io/LasWriter.cpp
Log Message:
Compare: https://github.com/PDAL/PDAL/compare/fb90efc3d955...6e077a5d455f
More information about the pdal-commits
