[pdal-commits] [PDAL/PDAL] 9a5b2e: Test updates.
GitHub noreply at github.com
Mon Apr 23 08:11:07 PDT 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 9a5b2e6712c591f73c15ef4ba78004c228d6574b
      https://github.com/PDAL/PDAL/commit/9a5b2e6712c591f73c15ef4ba78004c228d6574b
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-03-26 (Mon, 26 Mar 2018)
  Changed paths:
    M plugins/python/plang/Redirector.hpp
  Log Message:
  Test updates.
  Commit: b556d27639b4f5e6d5463e81cfc4f201b7691828
      https://github.com/PDAL/PDAL/commit/b556d27639b4f5e6d5463e81cfc4f201b7691828
  Date:   2018-04-02 (Mon, 02 Apr 2018)
  Changed paths:
    M doc/apps/info.rst
    M doc/apps/pipeline.rst
    M doc/apps/translate.rst
    M doc/faq.rst
    M doc/pipeline.rst
    M doc/references.rst
    M doc/stages/filters.gridprojection.rst
    M doc/stages/filters.mongus.rst
    M doc/stages/filters.movingleastsquares.rst
    M doc/stages/filters.poisson.rst
    M doc/stages/filters.rst
    M doc/stages/readers.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.rst
    A doc/stages/writers.sbet.rst
    M filters/ApproximateCoplanarFilter.cpp
    M filters/AssignFilter.cpp
    M filters/ClusterFilter.cpp
    M filters/ELMFilter.cpp
    M filters/EigenvaluesFilter.cpp
    M filters/EstimateRankFilter.cpp
    M filters/HAGFilter.cpp
    M io/BpfReader.cpp
    M io/TextReader.cpp
    M kernels/InfoKernel.cpp
    M kernels/InfoKernel.hpp
    M kernels/PipelineKernel.cpp
    M pdal/Stage.hpp
    M pdal/Streamable.cpp
    M pdal/Streamable.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.hpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/io/BPFTest.cpp
    M test/unit/io/PlyReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: f38464809729c76689512daddb84dfc3be6453ce
      https://github.com/PDAL/PDAL/commit/f38464809729c76689512daddb84dfc3be6453ce
  Changed paths:
    M pdal/PluginManager.cpp
  Log Message:
  Add missing '.
  Commit: 5dfbb81ad77a07af36f5b15f72cdaeb850713bca
      https://github.com/PDAL/PDAL/commit/5dfbb81ad77a07af36f5b15f72cdaeb850713bca
  Date:   2018-04-03 (Tue, 03 Apr 2018)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal-config-bat.in
    M apps/pdal-config.in
    M apps/pdal.cpp
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/python.cmake
    M scripts/appveyor/build.cmd
    M scripts/appveyor/config.cmd
    M scripts/appveyor/install.cmd
    A scripts/appveyor/test.cmd
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/TestConfig.hpp.in
    M test/unit/apps/TIndexTest.cpp
    M test/unit/filters/ColorinterpFilterTest.cpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
    M vendor/pdalboost/libs/filesystem/src/windows_file_codecvt.cpp
  Log Message:
  Commit: fdb58741ada301c48f73512b1e7f1d9e147793c3
      https://github.com/PDAL/PDAL/commit/fdb58741ada301c48f73512b1e7f1d9e147793c3
  Changed paths:
    M .gitignore
    M apps/pdal.cpp
    A doc/stages/readers.numpy.rst
    M pdal/Log.cpp
    M pdal/Log.hpp
    M pdal/StageExtensions.cpp
    M plugins/python/CMakeLists.txt
    M plugins/python/filters/CMakeLists.txt
    A plugins/python/io/CMakeLists.txt
    A plugins/python/io/NumpyReader.cpp
    A plugins/python/io/NumpyReader.hpp
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Environment.hpp
    M plugins/python/plang/Invocation.cpp
    A plugins/python/test/NumpyReaderTest.cpp
    A plugins/python/test/make-test-data.py
    A test/data/plang/1.2-with-color.npy
    A test/data/plang/perlin.npy
    M test/unit/apps/AppTest.cpp
  Log Message:
  Commit: 2966800eb703f9caedeee5471c8a2f74f772b23b
      https://github.com/PDAL/PDAL/commit/2966800eb703f9caedeee5471c8a2f74f772b23b
  Date:   2018-04-16 (Mon, 16 Apr 2018)
  Changed paths:
    M .travis.yml
    M CMakeLists.txt
    M ChangeLog
    M HOWTORELEASE.txt
    M RELEASENOTES.txt
    M appveyor.yml
    M cmake/options.cmake
    M cmake/policies.cmake
    M cmake/unix_compiler_options.cmake
    M doc/apps/info.rst
    M doc/development/compilation/windows.rst
    A doc/development/release-notes/1.7.0.md
    M doc/download.rst
    M doc/faq.rst
    M doc/index.rst
    M doc/pipeline.rst
    M doc/project/integration.rst
    M doc/quickstart.rst
    A doc/stages/filters.delaunay.rst
    A doc/stages/readers.rdb.rst
    M doc/stages/readers.rxp.rst
    M doc/tutorial/las.rst
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/slides/source/lidar_intro.rst
    M filters/ReprojectionFilter.cpp
    M filters/VoxelCenterNearestNeighborFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
    M io/GeotiffSupport.cpp
    M io/GeotiffSupport.hpp
    M io/HeaderVal.hpp
    M io/LasHeader.cpp
    M io/LasWriter.cpp
    R io/SbetCommon.cpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M kernels/PipelineKernel.hpp
    M kernels/TranslateKernel.cpp
    M kernels/TranslateKernel.hpp
    M pdal/EigenUtils.cpp
    M pdal/EigenUtils.hpp
    M pdal/PluginDirectory.cpp
    M pdal/PointView.hpp
    M pdal/Stage.cpp
    M pdal/util/ProgramArgs.hpp
    M plugins/CMakeLists.txt
    A plugins/delaunay/CMakeLists.txt
    A plugins/delaunay/filters/DelaunayFilter.cpp
    A plugins/delaunay/filters/DelaunayFilter.hpp
    A plugins/delaunay/filters/Delaunay_psm.cpp
    A plugins/delaunay/filters/Delaunay_psm.h
    M plugins/pcl/CMakeLists.txt
    R plugins/pcl/io/PcdCommon.cpp
    M plugins/pcl/io/PcdCommon.hpp
    M plugins/python/io/CMakeLists.txt
    A plugins/rdb/CMakeLists.txt
    A plugins/rdb/io/RdbPointcloud.cpp
    A plugins/rdb/io/RdbPointcloud.hpp
    A plugins/rdb/io/RdbReader.cpp
    A plugins/rdb/io/RdbReader.hpp
    A plugins/rdb/test/Config.hpp.in
    A plugins/rdb/test/RdbReaderTest.cpp
    A plugins/rdb/test/data/autzen-thin-srs.rdbx
    A plugins/rdb/test/data/autzen-thin-srs.txt
    M plugins/rxp/CMakeLists.txt
    M scripts/docker/Dockerfile
    M test/unit/PluginManagerTest.cpp
    M test/unit/apps/pcpipelineTestJSON.cpp
  Log Message:
  Commit: fff3b84a67a90bd7ceba3086f62a4e2a02c86093
      https://github.com/PDAL/PDAL/commit/fff3b84a67a90bd7ceba3086f62a4e2a02c86093
  Date:   2018-04-23 (Mon, 23 Apr 2018)
  Changed paths:
    M doc/stages/filters.delaunay.rst
    M io/LasWriter.hpp
    M pdal/XMLSchema.cpp
    M plugins/matlab/filters/Script.cpp
    M test/unit/filters/FerryFilterTest.cpp
    M test/unit/filters/ReprojectionFilterTest.cpp
    M tools/lasdump/Vlr.hpp
  Log Message:
  Commit: b0b12fb07faddba67e7d5d2b31e4f21808a6c56a
      https://github.com/PDAL/PDAL/commit/b0b12fb07faddba67e7d5d2b31e4f21808a6c56a
  Changed paths:
  Log Message:
  Remove header that can bring in duplicate macros.
Compare: https://github.com/PDAL/PDAL/compare/9ea259c2b04e...b0b12fb07fad
More information about the pdal-commits mailing list
