[pdal-commits] [PDAL/PDAL] 9ab689: Don't print multiple SRS message if we've overridd...
GitHub noreply at github.com
Mon Aug 13 14:13:14 PDT 2018
  Branch: refs/heads/issue-2114
  Home:   https://github.com/PDAL/PDAL
  Commit: 9ab68928540473bf5719389ba93d75a4e3e2beca
      https://github.com/PDAL/PDAL/commit/9ab68928540473bf5719389ba93d75a4e3e2beca
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-07-25 (Wed, 25 Jul 2018)
  Changed paths:
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/FlexWriter.hpp
  Log Message:
  Don't print multiple SRS message if we've overridden the SRS. (#2108)
Close #2107
  Commit: 40bcc1021f3bc248b8ee261c66e87e0ab2bf8136
      https://github.com/PDAL/PDAL/commit/40bcc1021f3bc248b8ee261c66e87e0ab2bf8136
  Author: Howard Butler <howard at hobu.co>
  Date:   2018-07-31 (Tue, 31 Jul 2018)
  Changed paths:
    M scripts/docker/Dockerfile
  Log Message:
  get alpine docker building again #2110
  Commit: 37646d181fc3f3a5e2beca33964f46e590f0ef3c
      https://github.com/PDAL/PDAL/commit/37646d181fc3f3a5e2beca33964f46e590f0ef3c
  Date:   2018-08-01 (Wed, 01 Aug 2018)
  Changed paths:
    M pdal/util/FileUtils.cpp
    M test/unit/FileUtilsTest.cpp
  Log Message:
  throw an error if we try to open a file with ~ in the file name because we do not do shell expansion. Throw an error for globs with ~ in the file name on windows #2024 (#2117)
  Commit: 4088bea139b1ed4e8b7958f804d233fba739d100
      https://github.com/PDAL/PDAL/commit/4088bea139b1ed4e8b7958f804d233fba739d100
  Changed paths:
    M doc/stages/readers.numpy.rst
    M plugins/python/io/NumpyReader.cpp
    M plugins/python/io/NumpyReader.hpp
    M plugins/python/test/NumpyReaderTest.cpp
    A test/data/plang/threedim.npy
    A test/data/plang/twodim.npy
  Log Message:
  Numpy edits (#2118)
* Changes for a cleaner numpy reader.
* Many changes to generalize numpy reading.
* Add a test.
* Add tests.
Fix iteration order.
Change options.
* Initialize m_storeXYZ
Initialize m_order based on natural array order.
Doc updates
* Add test file.
  Commit: 3f6acaf24b3f84c3b5c381d15078e0d19da8f9da
      https://github.com/PDAL/PDAL/commit/3f6acaf24b3f84c3b5c381d15078e0d19da8f9da
  Changed paths:
    M README.md
  Log Message:
  trigger dockerhub with a silly commit
  Commit: 788c28e697fecb828fe1e26487a05bc2974ebbf4
      https://github.com/PDAL/PDAL/commit/788c28e697fecb828fe1e26487a05bc2974ebbf4
  Date:   2018-08-08 (Wed, 08 Aug 2018)
  Changed paths:
    M doc/stages/readers.text.rst
    M io/TextReader.cpp
  Log Message:
  Add SRS support for readers.text. (#2122)
  Commit: 99835f8d433c26f2848a6a4b518762284e08cb23
      https://github.com/PDAL/PDAL/commit/99835f8d433c26f2848a6a4b518762284e08cb23
  Date:   2018-08-10 (Fri, 10 Aug 2018)
  Changed paths:
    M cmake/options.cmake
    M pdal/StageExtensions.cpp
    M plugins/CMakeLists.txt
    A plugins/fbx/CMakeLists.txt
    A plugins/fbx/io/FbxWriter.cpp
    A plugins/fbx/io/FbxWriter.hpp
    A plugins/fbx/test/FbxWriterTest.cpp
  Log Message:
  Add bare FBX writer (#2127)
* Temp check-in.
* Temp check-in.
* FBX writer creates a real file.
* Working FBX writer.
* Add test for FBX writer.
* Suppress cast warning.
* Remove some warning suppression.
  Commit: 4e83901033f6f13e7dc324dbd9263c98e6b19b69
      https://github.com/PDAL/PDAL/commit/4e83901033f6f13e7dc324dbd9263c98e6b19b69
  Changed paths:
    M filters/ReturnsFilter.cpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/ReturnsFilterTest.cpp
  Log Message:
  Initialize outputTypes (#2116)
* Initialize m_outputTypes.
Close #2115
* Add filters.returns test.
* Add blank line for clarity.
  Commit: caeab2a042c701e37b4e48ac231b2755f1fe6427
      https://github.com/PDAL/PDAL/commit/caeab2a042c701e37b4e48ac231b2755f1fe6427
  Changed paths:
    M filters/ClusterFilter.cpp
    M filters/PMFFilter.cpp
    M filters/SMRFilter.cpp
    A filters/private/Segmentation.cpp
    A filters/private/Segmentation.hpp
    R pdal/Segmentation.cpp
    R pdal/Segmentation.hpp
    M test/unit/SegmentationTest.cpp
  Log Message:
  Move Segmentation.Xpp to filters/private (#2112)
* Move Segmentation.Xpp to filters/private.
Close #2109
* Reference local files.
  Commit: a3ceeccc2144e0fe8aa249a6a9aa7d9c7ca27338
      https://github.com/PDAL/PDAL/commit/a3ceeccc2144e0fe8aa249a6a9aa7d9c7ca27338
  Changed paths:
    M pdal/PointView.hpp
    A test/unit/filters/VoxelTest.cpp
  Log Message:
  Add test for voxelcenternearestneighbor.
  Commit: fe0df2a3f017686eb1ef5439b95b0c71220982a5
      https://github.com/PDAL/PDAL/commit/fe0df2a3f017686eb1ef5439b95b0c71220982a5
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: 939de4fb90e4e414f8c7d2175d272bdf19ffc745
      https://github.com/PDAL/PDAL/commit/939de4fb90e4e414f8c7d2175d272bdf19ffc745
  Date:   2018-08-13 (Mon, 13 Aug 2018)
  Changed paths:
    M io/FauxReader.cpp
  Log Message:
  Error if the point count isn't set. (#2129)
  Commit: a3499cd22d9c7609dfc162a8d7f32e17dedab102
      https://github.com/PDAL/PDAL/commit/a3499cd22d9c7609dfc162a8d7f32e17dedab102
  Changed paths:
    A doc/apps/tile.rst
    M filters/SplitterFilter.cpp
    M filters/SplitterFilter.hpp
    M io/TextWriter.cpp
    A kernels/TileKernel.cpp
    A kernels/TileKernel.hpp
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageWrapper.hpp
    M pdal/Streamable.cpp
    M pdal/Streamable.hpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    A test/data/las/tile/file1.las
    A test/data/las/tile/file2.las
    A test/data/las/tile/file3.las
    A test/data/text/file1.txt
    A test/data/text/file2.txt
    A test/data/text/file3.txt
    A test/unit/apps/TileTest.cpp
  Log Message:
  Add tile command (#2125)
* Add public entry points to allow filters.splitter use outside of pipelines.
* Initial check-in for kernels.tile.
* Rearrangement prior to streaming support.
* Add streaming support for text writer.
* Working tiler.
* Add skip support.
Add SRS support.
Fill point table when possible.
Improve logic.
* Improve argument text.
* Add SRS support for readers.text.
* First test for tile kernel.
* Add tile test.
Close #2065
* Notify reprojection filter about SRS changes.
* Add a test that includes a reprojection.
Close #2065
* Documentation.
* Debug.
* Ignore files that start with '.'
* Remove debug. Add comment.
* There were tabs instead of spaces. Huh.
  Commit: 21ea9ef5add49ef8ab5c893145766cc27d85fea3
      https://github.com/PDAL/PDAL/commit/21ea9ef5add49ef8ab5c893145766cc27d85fea3
  Changed paths:
    M README.md
    A doc/apps/tile.rst
    M io/FauxReader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/TextReader.cpp
    M io/TextWriter.cpp
    M pdal/Options.cpp
    M pdal/Options.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2114
Compare: https://github.com/PDAL/PDAL/compare/554366e3feb9...21ea9ef5add4
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
