[pdal-commits] [PDAL/PDAL] 7570b0: Improve filters.stats (#2034)
GitHub
noreply at github.com
Wed Aug 15 08:21:08 PDT 2018
Branch: refs/heads/issue-1852
Home: https://github.com/PDAL/PDAL
Commit: 7570b0a4f2d133ced720dc6fc5fc23bd8ddf558e
https://github.com/PDAL/PDAL/commit/7570b0a4f2d133ced720dc6fc5fc23bd8ddf558e
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-05-24 (Thu, 24 May 2018)
Changed paths:
M filters/ColorinterpFilter.cpp
M filters/StatsFilter.cpp
M filters/StatsFilter.hpp
M test/unit/filters/StatsFilterTest.cpp
Log Message:
* Fix comment.
* Enhance stats filter test to check higher-order statistics.
* Only compute average once.
Simplify a little math.
Add comments.
* Only run skewness/kurtosis in advanced mode.
Commit: ef27755cf6a8126c2d228aaa19390878d2403f81
https://github.com/PDAL/PDAL/commit/ef27755cf6a8126c2d228aaa19390878d2403f81
Author: Howard Butler <howard at hobu.co>
Date: 2018-05-29 (Tue, 29 May 2018)
Changed paths:
R scripts/docker/1.4-maintenance/alpine/10-backtrace-guards.patch
R scripts/docker/1.4-maintenance/alpine/Dockerfile
R scripts/docker/1.4-maintenance/ubuntu/Dockerfile
R scripts/docker/1.5-maintenance/alpine/10-backtrace-guards.patch
R scripts/docker/1.5-maintenance/alpine/Dockerfile
R scripts/docker/1.5-maintenance/ubuntu/Dockerfile
R scripts/docker/1.6-maintenance/alpine/Dockerfile
R scripts/docker/1.6-maintenance/ubuntu/Dockerfile
R scripts/docker/dependencies/Dockerfile
A scripts/docker/ubuntu/Dockerfile
A scripts/docker/ubuntu/dependencies/Dockerfile
Log Message:
ubuntu-based docker build
Commit: 3c5a0698a797df6e346081e91bf7d9b381936f5c
https://github.com/PDAL/PDAL/commit/3c5a0698a797df6e346081e91bf7d9b381936f5c
Author: Carl Anderson <carl.anderson at vadose.org>
Date: 2018-05-31 (Thu, 31 May 2018)
Changed paths:
M io/LasReader.cpp
M pdal/util/ProgramArgs.hpp
Log Message:
fix argument error message for true/false (#2039)
Commit: 9ef03d61a17509a26bd06b07694a8379fa2b55dd
https://github.com/PDAL/PDAL/commit/9ef03d61a17509a26bd06b07694a8379fa2b55dd
Author: chambbj <brad.chambers at gmail.com>
Date: 2018-06-01 (Fri, 01 Jun 2018)
Changed paths:
M .travis.yml
M scripts/ci/script.sh
A scripts/docker/Dockerfile.alpinedeps
Log Message:
Add Dockerfile to create pdal/dependencies:alpine and update build scripts to use it on Travis (#2040)
Commit: 5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
https://github.com/PDAL/PDAL/commit/5722e156ffcd3a1e2fda7d0f0f1cba254377ca96
Date: 2018-06-03 (Sun, 03 Jun 2018)
Changed paths:
M vendor/arbiter/CMakeLists.txt
M vendor/arbiter/arbiter.cpp
M vendor/arbiter/arbiter.hpp
Log Message:
update arbiter to support windows globbing (#2043)
* update arbiter to support windows globbing
* need SHLWAPI for arbiter now for windows
Commit: d0cb25f18b81c802588d5a938b3bf8485b87aeb1
https://github.com/PDAL/PDAL/commit/d0cb25f18b81c802588d5a938b3bf8485b87aeb1
Date: 2018-06-05 (Tue, 05 Jun 2018)
Changed paths:
M plugins/rdb/CMakeLists.txt
Log Message:
link RDB with JSONCPP (#2046)
Commit: 54e35ebd3fe1255031eb983c04cb634ae7c72527
https://github.com/PDAL/PDAL/commit/54e35ebd3fe1255031eb983c04cb634ae7c72527
Date: 2018-06-06 (Wed, 06 Jun 2018)
Changed paths:
M filters/PMFFilter.cpp
M filters/SMRFilter.cpp
M pdal/Segmentation.cpp
Log Message:
Fix segmentation of last returns (#2045)
segmentLastReturns now defines last returns as those points whose ReturnNumber
equals the NumberOfReturns when the NumberOfReturns is greater than 1.
This segmentation is used in both the SMRF and PMF ground segmentation filters,
so ground segmentation results may differ from what was previously returned.
Commit: 75cded9bb61f23b7ec54ebf9c1111f1cfd718129
https://github.com/PDAL/PDAL/commit/75cded9bb61f23b7ec54ebf9c1111f1cfd718129
Changed paths:
Log Message:
update RDB linking as suggested in #2046 (#2048)
Commit: 9ad065975db7a4220c94d20c09310705e0bc4df9
https://github.com/PDAL/PDAL/commit/9ad065975db7a4220c94d20c09310705e0bc4df9
Date: 2018-06-07 (Thu, 07 Jun 2018)
Changed paths:
M vendor/kazhdan/PoissonRecon.h
M vendor/kazhdan/point_source/AsciiPointSource.inl
M vendor/kazhdan/point_source/MemoryPointSource.h
M vendor/kazhdan/point_source/PlyPointSource.inl
M vendor/kazhdan/point_source/PointSource.h
M vendor/kazhdan/point_source/TransformedPointSource.h
Log Message:
Compiler updates for poisson filter (#2031)
* Updates from Mark Loyman.
* Set thread count to 1.
Commit: de8ca415e43eb8401040a51adcedc5ea90e734af
https://github.com/PDAL/PDAL/commit/de8ca415e43eb8401040a51adcedc5ea90e734af
Date: 2018-06-11 (Mon, 11 Jun 2018)
Changed paths:
M doc/python.rst
Log Message:
Add some Conda docs to python pages (#2052)
Fixes #2047 (assuming the Python compilation page is just stale output)
Commit: 80f876b1d7df7ef6f51b2f3f856912faeeeb8039
https://github.com/PDAL/PDAL/commit/80f876b1d7df7ef6f51b2f3f856912faeeeb8039
Changed paths:
M apps/pdal.cpp
M cmake/execinfo.cmake
A cmake/modules/FindLibexecinfo.cmake
A cmake/modules/FindLibunwind.cmake
A cmake/unwind.cmake
M dimbuilder/CMakeLists.txt
A pdal/util/Backtrace.cpp
A pdal/util/Backtrace.hpp
M pdal/util/CMakeLists.txt
M pdal/util/Utils.cpp
M pdal/util/Utils.hpp
A pdal/util/private/BacktraceExecinfo.cpp
A pdal/util/private/BacktraceImpl.hpp
A pdal/util/private/BacktraceNone.cpp
A pdal/util/private/BacktraceUnwind.cpp
Log Message:
Implement Backtrace for Libunwind (#2037)
* Add backtrace support for libunwind.
* Use proper execinfo backtrace function.
* Remove cruft.
* Make backtrace work on a system w/o libunwind.
* Small fixes.
Commit: 0796de17e2c0505ea17d4ff7b8604db7674e5747
https://github.com/PDAL/PDAL/commit/0796de17e2c0505ea17d4ff7b8604db7674e5747
Author: Éric Lemoine <eric.lemoine at gmail.com>
Date: 2018-06-13 (Wed, 13 Jun 2018)
Changed paths:
M doc/stages/writers.pgpointcloud.rst
M plugins/pgpointcloud/io/PgCommon.hpp
M plugins/pgpointcloud/io/PgWriter.cpp
Log Message:
Add pgpointcloud lazperf support (#2051)
Commit: cc254abfff1bb2a2d5ad845182973c52d92762fc
https://github.com/PDAL/PDAL/commit/cc254abfff1bb2a2d5ad845182973c52d92762fc
Changed paths:
M kernels/GroundKernel.cpp
M kernels/GroundKernel.hpp
Log Message:
Add prefiltering options to ground kernel (#2054)
- Add a switch to optionally reset classifications prior to segmenting ground returns
- Add a switch to optionally denoise prior to segmenting ground returns
Fixes #1579
Commit: 6e2d2a7363b2969b6e895d21b7e8381978cad7cf
https://github.com/PDAL/PDAL/commit/6e2d2a7363b2969b6e895d21b7e8381978cad7cf
Changed paths:
M doc/quickstart.rst
Log Message:
Rewrite quickstart docs with Conda focus, dropping Docker (#2056)
* Initial cut at rewriting Quickstart, short of replacing images
* Provide some sample outputs and update the autzen.laz download link
Careful readers will note the warning about datum.csv, etc. not being found.
This is a real thing. They exist and are installed, but are not being located
for some reason.
Commit: 944122ce72f185dd4b821d0e5150c910f17fc1c2
https://github.com/PDAL/PDAL/commit/944122ce72f185dd4b821d0e5150c910f17fc1c2
Date: 2018-06-22 (Fri, 22 Jun 2018)
Changed paths:
M tools/nitfwrap/CMakeLists.txt
Log Message:
Fix build.
Commit: 08fb529e63db71491e530f3f1b737bf2b2ffe612
https://github.com/PDAL/PDAL/commit/08fb529e63db71491e530f3f1b737bf2b2ffe612
Changed paths:
A CITATION
Log Message:
add CITATION file (#2063)
Commit: 9eafd35297c24fc852fc71d23d01bbc045302038
https://github.com/PDAL/PDAL/commit/9eafd35297c24fc852fc71d23d01bbc045302038
Date: 2018-06-26 (Tue, 26 Jun 2018)
Changed paths:
M pdal/Segmentation.hpp
M test/unit/CMakeLists.txt
M test/unit/OldPCLBlockTest.cpp
A test/unit/filters/PMFFilterTest.cpp
A test/unit/filters/SMRFilterTest.cpp
Log Message:
Allow more flexible processing of return groups in ground filters (#2055)
* Allow more flexible processing of return groups in ground filters
Continue to default to processing last and only returns, but allow users to
specify any combination of "last", "first", "intermediate", and "only".
* Update the tests to handle returns as a StringList in filters.pmf
* Remove debug and unused variable
* Simplified logic
* Some error checking on returns
* Add simple tests for returns option
* Add tests for SMRF too
Commit: 76bdabdb6a47e3395397b7d9a56f239ff5e44fd0
https://github.com/PDAL/PDAL/commit/76bdabdb6a47e3395397b7d9a56f239ff5e44fd0
Changed paths:
M filters/OverlayFilter.cpp
M pdal/Streamable.cpp
M test/unit/StreamingTest.cpp
M test/unit/apps/pcpipelineTestJSON.cpp
Log Message:
Always emit a spatialReferenceChanged when processing starts (#2060)
* Make sure we emit a single spatialReferenceChanged() when processing
points with no SRS.
* Fix overlay filter to deal with SRS change to empty SRS.
Add more info to failed pipeline test message.
Commit: a3135db87664265ad6ded32c3b285875929ad375
https://github.com/PDAL/PDAL/commit/a3135db87664265ad6ded32c3b285875929ad375
Date: 2018-06-27 (Wed, 27 Jun 2018)
Changed paths:
M pdal/StageExtensions.cpp
M pdal/StageExtensions.hpp
Log Message:
Use correct order to traversing stages when streaming (#2067)
* Process points from left to right when streaming.
Close #2023
* PDAL_DLL StageExtensions::set
* Make sure output string is assigned.
Commit: 76b69c82b7b961d3be162ba2b5b31f0f3131e326
https://github.com/PDAL/PDAL/commit/76b69c82b7b961d3be162ba2b5b31f0f3131e326
Date: 2018-07-02 (Mon, 02 Jul 2018)
Changed paths:
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/mbio/io/MbError.cpp
M plugins/pcl/CMakeLists.txt
Log Message:
Warning updates and such for OSX High Sierra compiler. (#2058)
Commit: d7c2352cf0a6d17e648236673fbae68d0bfd3708
https://github.com/PDAL/PDAL/commit/d7c2352cf0a6d17e648236673fbae68d0bfd3708
Changed paths:
M io/TextWriter.cpp
M io/TextWriter.hpp
M test/unit/io/TextWriterTest.cpp
Log Message:
Support streaming in writers.text (#2066)
* Rearrangement prior to streaming support.
* Add streaming support for text writer.
* Fix messed-up separator in GeoJSON code.
Commit: 1d159082b2115a014a2d720d6fbc78307be51335
https://github.com/PDAL/PDAL/commit/1d159082b2115a014a2d720d6fbc78307be51335
Date: 2018-07-04 (Wed, 04 Jul 2018)
Changed paths:
M CMakeLists.txt
M cmake/examples/hobu-config.sh
R cmake/modules/FindHexer.cmake
A filters/HexBinFilter.cpp
A filters/HexBinFilter.hpp
A filters/private/hexer/HexGrid.cpp
A filters/private/hexer/HexGrid.hpp
A filters/private/hexer/HexInfo.hpp
A filters/private/hexer/HexIter.hpp
A filters/private/hexer/Hexagon.cpp
A filters/private/hexer/Hexagon.hpp
A filters/private/hexer/Mathpair.hpp
A filters/private/hexer/Path.cpp
A filters/private/hexer/Path.hpp
A filters/private/hexer/Processor.cpp
A filters/private/hexer/Processor.hpp
A filters/private/hexer/Segment.cpp
A filters/private/hexer/Segment.hpp
A filters/private/hexer/exception.hpp
A kernels/DensityKernel.cpp
A kernels/DensityKernel.hpp
A kernels/private/density/OGR.cpp
A kernels/private/density/OGR.hpp
M plugins/CMakeLists.txt
A plugins/faux/CMakeLists.txt
A plugins/faux/kernel/FauxPluginKernel.cpp
A plugins/faux/kernel/FauxPluginKernel.hpp
R plugins/hexbin/CMakeLists.txt
R plugins/hexbin/filters/HexBin.cpp
R plugins/hexbin/filters/HexBin.hpp
R plugins/hexbin/kernel/DensityKernel.cpp
R plugins/hexbin/kernel/DensityKernel.hpp
R plugins/hexbin/kernel/OGR.cpp
R plugins/hexbin/kernel/OGR.hpp
R plugins/hexbin/test/HexbinFilterTest.cpp
M test/unit/apps/AppPluginTest.cpp
A test/unit/filters/HexbinFilterTest.cpp
Log Message:
Integrate hexer code into PDAL (#2073)
* include hexer source tree in PDAL (now relicensed as BSD) #2001
* Remove hexbin plugin.
Add hexbin test.
* Fix app test.
* Add faux plugin to make plugin kernel test work.
* Remove stuff from hexer that was necessary when it was its own package.
* Revert version info
Close #2001
Commit: 05964b72ae664d7ed0f0514ba90a5a6ddb211455
https://github.com/PDAL/PDAL/commit/05964b72ae664d7ed0f0514ba90a5a6ddb211455
Date: 2018-07-05 (Thu, 05 Jul 2018)
Changed paths:
Log Message:
Fix SRS assignment in streaming. (#2070)
Close #2069
Commit: 4d8cdf0951413e14ccf7d81a8acf3a4227f5f405
https://github.com/PDAL/PDAL/commit/4d8cdf0951413e14ccf7d81a8acf3a4227f5f405
Changed paths:
M io/LasHeader.cpp
Log Message:
Make more accurate error message for point type/WKT flag mismatch. (#2075)
Close #2059
Commit: ab44c6fb09e73ac36be9e3d27031f89f16818dfe
https://github.com/PDAL/PDAL/commit/ab44c6fb09e73ac36be9e3d27031f89f16818dfe
Author: Jaime Soto <jsoto at simverge.com>
Date: 2018-07-06 (Fri, 06 Jul 2018)
Changed paths:
M pdal/pdal_config.hpp
Log Message:
Remove pdal::Config::lazPerfEnabled() declaration (#2080)
This function has been replaced by pdal::Config::hasFeature() with the
pdal::Config::LAZPERF argument. See comment in #2078.
Commit: 643b03442d6c1a9fa8dc04c776ca56f8689475a4
https://github.com/PDAL/PDAL/commit/643b03442d6c1a9fa8dc04c776ca56f8689475a4
Date: 2018-07-09 (Mon, 09 Jul 2018)
Changed paths:
M CMakeLists.txt
Log Message:
Add exclusion for header files of unbuilt compression schemes.
Commit: d77f671eb3e2820f18e6bc8e2c58197033085dce
https://github.com/PDAL/PDAL/commit/d77f671eb3e2820f18e6bc8e2c58197033085dce
Date: 2018-07-10 (Tue, 10 Jul 2018)
Changed paths:
M pdal/ArtifactManager.hpp
Log Message:
Delete copy assignment/ctor from ArtifactManager. (#2084)
Close #2082
Commit: d06134de3b22b650a770614fee401cd609cc453f
https://github.com/PDAL/PDAL/commit/d06134de3b22b650a770614fee401cd609cc453f
Changed paths:
M filters/ReprojectionFilter.cpp
M filters/ReprojectionFilter.hpp
M test/unit/filters/ReprojectionFilterTest.cpp
Log Message:
Handle changes in SRS with spatialReferenceChanged(). (#2081)
Commit: 66936c950b3149926daf7886c69948a4a451b26b
https://github.com/PDAL/PDAL/commit/66936c950b3149926daf7886c69948a4a451b26b
Changed paths:
A filters/NNDistanceFilter.cpp
A filters/NNDistanceFilter.hpp
M pdal/Dimension.json
A test/unit/filters/NNDistanceTest.cpp
Log Message:
Add avg option to NNdistance filter. (#2076)
* Add nn distance dimension.
* Add general nearest neighbor distance filter.
* Migrate KDistanceFilter to more generic NNDistanceFilter.
Close #2071
* Full test.
* Add some test comments.
* Use distances, not square distances when computing averages.
* Remove unnecessary braces.
Commit: 004a8480adff030cdadb67664d196da4132492b9
https://github.com/PDAL/PDAL/commit/004a8480adff030cdadb67664d196da4132492b9
Date: 2018-07-11 (Wed, 11 Jul 2018)
Changed paths:
M io/GDALWriter.cpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Reset GDAL grid when we start a file. (#2079)
Close #2074
Commit: 2dd6dfbeecd4366f30cb006005f9768813e747ee
https://github.com/PDAL/PDAL/commit/2dd6dfbeecd4366f30cb006005f9768813e747ee
Changed paths:
M CMakeLists.txt
M cmake/modules/FindZSTD.cmake
Log Message:
Fix FindZST.cmake (#2085)
* Fix FindZST.cmake.
Use proper variable for ZSTD library.
Close #2036
* Remove repetitive function.
Commit: 6469b51d60ffae0149589f78c2bf762546d434ca
https://github.com/PDAL/PDAL/commit/6469b51d60ffae0149589f78c2bf762546d434ca
Date: 2018-07-16 (Mon, 16 Jul 2018)
Changed paths:
M pdal/PipelineReaderJSON.hpp
Log Message:
Make parsePipeline private.
Commit: 973ceafb1589037ce9d073ac296fdc86bfe13ca5
https://github.com/PDAL/PDAL/commit/973ceafb1589037ce9d073ac296fdc86bfe13ca5
Changed paths:
M pdal/Reader.hpp
Log Message:
Handle count option on readers when streaming. (#2088)
* Handle count option on readers when streaming.
* Parenthesize max for Windows.
* And min...
Commit: 562980934836a83a24f3e3b43cc43f4a27d8b2fb
https://github.com/PDAL/PDAL/commit/562980934836a83a24f3e3b43cc43f4a27d8b2fb
Author: Eli L Adam <elil at users.noreply.github.com>
Date: 2018-07-17 (Tue, 17 Jul 2018)
Changed paths:
M doc/stages/filters.poisson.rst
Log Message:
Correct trailing comma typos (#2089)
I think that I'm in the correct location now.
Are these commas typos?
Commit: 380e186e0d62811bea416ec2119c7209bc193841
https://github.com/PDAL/PDAL/commit/380e186e0d62811bea416ec2119c7209bc193841
Changed paths:
A doc/stages/filters.dem.rst
M doc/stages/filters.rst
A filters/DEMFilter.cpp
A filters/DEMFilter.hpp
Log Message:
add filters.dem for filtering data given a GDAL-readable data source (#2090)
Commit: 768077a1f3f541ca1563a0284d5e1cc7c3529ea4
https://github.com/PDAL/PDAL/commit/768077a1f3f541ca1563a0284d5e1cc7c3529ea4
Author: Brandon Barker <contact at brandonbarker.me>
Changed paths:
M scripts/docker/ubuntu/Dockerfile
Log Message:
Purging Numpy breaks numpy support (#2091)
numyp should not be purged, when it is removed the 'npy' file extension no longer works for pdal.
Commit: ca898758fc494561f2815a889c793ff51976beab
https://github.com/PDAL/PDAL/commit/ca898758fc494561f2815a889c793ff51976beab
Date: 2018-07-18 (Wed, 18 Jul 2018)
Changed paths:
A cmake/examples/hobu-conda-win64.bat
R cmake/modules/BuildOSGeo4W.cmake
M cmake/modules/FindGDAL.cmake
M cmake/modules/FindGEOS.cmake
M cmake/modules/FindGeoTIFF.cmake
M cmake/modules/FindLASzip.cmake
R cmake/modules/FindP2G.cmake
M cmake/modules/FindSQLite3.cmake
M cmake/win32_compiler_options.cmake
Log Message:
De-OSGeo4W'ify CMake configuration (#2092)
* start de-OSGEO4W'ing the cmake config
* add hobu-conda example
Commit: e4ede0b2b5865893d42ece955f776f5e7680471a
https://github.com/PDAL/PDAL/commit/e4ede0b2b5865893d42ece955f776f5e7680471a
Changed paths:
M doc/about.rst
M doc/conf.py
M doc/development/compilation/index.rst
M doc/development/compilation/unix.rst
M doc/development/compilation/windows.rst
R doc/development/contributors.rst
M doc/development/index.rst
M doc/development/writing-reader.rst
M doc/development/writing.rst
M doc/download.rst
M doc/faq.rst
M doc/pipeline.rst
M doc/project/contributors.rst
M doc/project/docs.rst
M doc/project/testing.rst
M doc/python.rst
M doc/stages/filters.delaunay.rst
M doc/stages/filters.hexbin.rst
M doc/stages/filters.neighborclassifier.rst
A doc/stages/filters.nndistance.rst
M doc/stages/filters.python.rst
A doc/stages/filters.streamcallback.rst
R doc/stages/index.rst
M doc/stages/readers.nitf.rst
M doc/stages/readers.rst
A doc/stages/readers.terrasolid.rst
M doc/stages/references.bib
M doc/tutorial/clipping/index.rst
M doc/tutorial/ground-filters.rst
M doc/tutorial/pcl_spec.rst
R doc/tutorial/python-filtering.rst
A doc/tutorial/python-filtering.rst.save
M doc/tutorial/reading.rst
R doc/tutorial/sampling/index.rst
A doc/tutorial/sampling/index.rst.save
R doc/workshop/docker.rst
A doc/workshop/docker.rst.save
M doc/workshop/exercises/analysis/boundary/boundary.rst
M doc/workshop/exercises/analysis/dtm/dtm.rst
M doc/workshop/exercises/analysis/ground/ground.rst
M doc/workshop/exercises/analysis/rasterize/rasterize.rst
M doc/workshop/exercises/analysis/thinning/thinning.rst
R doc/workshop/exercises/batch_processing/batch-processing.rst
A doc/workshop/exercises/batch_processing/batch-processing.rst.save
M doc/workshop/exercises/info/metadata.rst
M doc/workshop/notes.rst
M doc/workshop/osgeo4w.rst
M doc/workshop/software.rst
Log Message:
Docfixes for Sphinx (#2093)
* Fix doc warnings.
* Eliminate warnings in doc build.
* Add dummy line in an attempt to resolve warnings.
Didn't work :(
Requested here: https://github.com/mcmtroffaes/sphinxcontrib-bibtex/issues/141
Commit: 091baaa05bd4b93b4187fe081e014ac40c3016b0
https://github.com/PDAL/PDAL/commit/091baaa05bd4b93b4187fe081e014ac40c3016b0
Date: 2018-07-20 (Fri, 20 Jul 2018)
Changed paths:
M pdal/PointView.hpp
M pdal/util/Uuid.hpp
Log Message:
Eliminate pragmas. (#2094)
Commit: 6f257118f625e23a7771ba913f38296b7ad8bdea
https://github.com/PDAL/PDAL/commit/6f257118f625e23a7771ba913f38296b7ad8bdea
Changed paths:
M filters/DEMFilter.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M test/unit/io/GDALReaderTest.cpp
Log Message:
make readers.gdal streamable (#2096)
* make readers.gdal streamable
* add tiff/tif/jpeg/jpg to readers.gdal identification
* modifications as requested by review
Commit: 016e970ece57d4f1b1aae814acffee5ea210bbfa
https://github.com/PDAL/PDAL/commit/016e970ece57d4f1b1aae814acffee5ea210bbfa
Date: 2018-07-23 (Mon, 23 Jul 2018)
Changed paths:
M io/GDALGrid.hpp
Log Message:
Use correct math to compute vertical index in GDALGrid. (#2097)
* Fix calculation of verticalIndex().
* Export GDAL Grid for testing.
Commit: 97f02ca0bd540ead70140b14aebd977101fad3e6
https://github.com/PDAL/PDAL/commit/97f02ca0bd540ead70140b14aebd977101fad3e6
Date: 2018-07-24 (Tue, 24 Jul 2018)
Changed paths:
M plugins/python/plang/Environment.cpp
Log Message:
Constify python strings. (#2102)
Close #2099
Commit: adcd36022577d1661d91e71d9df1c9d397df2bd1
https://github.com/PDAL/PDAL/commit/adcd36022577d1661d91e71d9df1c9d397df2bd1
Author: Dylan Leidig <dzleidig at gmail.com>
Changed paths:
Log Message:
Update doc to indicate that python filter's add_dimension accepts array. (#2103)
* Update doc to indicate that python filter's add_dimension accepts array.
* Update python filter's doc to indicate add_dimension also accepts single arg.
Commit: 884865f97a86ce8b27a855ef29d371d2b4be297c
https://github.com/PDAL/PDAL/commit/884865f97a86ce8b27a855ef29d371d2b4be297c
Date: 2018-07-25 (Wed, 25 Jul 2018)
Changed paths:
M doc/stages/filters.smrf.rst
Log Message:
Add missed options for filters.smrf doc.
Commit: 969373235fea97ff9ff2a61249ad9ea1ed67b43b
https://github.com/PDAL/PDAL/commit/969373235fea97ff9ff2a61249ad9ea1ed67b43b
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 9ab68928540473bf5719389ba93d75a4e3e2beca
https://github.com/PDAL/PDAL/commit/9ab68928540473bf5719389ba93d75a4e3e2beca
Changed paths:
M io/LasWriter.cpp
M io/LasWriter.hpp
M pdal/FlexWriter.hpp
Log Message:
Don't print multiple SRS message if we've overridden the SRS. (#2108)
Close #2107
Commit: 40bcc1021f3bc248b8ee261c66e87e0ab2bf8136
https://github.com/PDAL/PDAL/commit/40bcc1021f3bc248b8ee261c66e87e0ab2bf8136
Date: 2018-07-31 (Tue, 31 Jul 2018)
Changed paths:
M scripts/docker/Dockerfile
Log Message:
get alpine docker building again #2110
Commit: 37646d181fc3f3a5e2beca33964f46e590f0ef3c
https://github.com/PDAL/PDAL/commit/37646d181fc3f3a5e2beca33964f46e590f0ef3c
Date: 2018-08-01 (Wed, 01 Aug 2018)
Changed paths:
M pdal/util/FileUtils.cpp
M test/unit/FileUtilsTest.cpp
Log Message:
throw an error if we try to open a file with ~ in the file name because we do not do shell expansion. Throw an error for globs with ~ in the file name on windows #2024 (#2117)
Commit: 4088bea139b1ed4e8b7958f804d233fba739d100
https://github.com/PDAL/PDAL/commit/4088bea139b1ed4e8b7958f804d233fba739d100
Changed paths:
M doc/stages/readers.numpy.rst
M plugins/python/io/NumpyReader.cpp
M plugins/python/io/NumpyReader.hpp
M plugins/python/test/NumpyReaderTest.cpp
A test/data/plang/threedim.npy
A test/data/plang/twodim.npy
Log Message:
Numpy edits (#2118)
* Changes for a cleaner numpy reader.
* Many changes to generalize numpy reading.
* Add a test.
* Add tests.
Fix iteration order.
Change options.
* Initialize m_storeXYZ
Initialize m_order based on natural array order.
Doc updates
* Add test file.
Commit: 3f6acaf24b3f84c3b5c381d15078e0d19da8f9da
https://github.com/PDAL/PDAL/commit/3f6acaf24b3f84c3b5c381d15078e0d19da8f9da
Changed paths:
M README.md
Log Message:
trigger dockerhub with a silly commit
Commit: 788c28e697fecb828fe1e26487a05bc2974ebbf4
https://github.com/PDAL/PDAL/commit/788c28e697fecb828fe1e26487a05bc2974ebbf4
Date: 2018-08-08 (Wed, 08 Aug 2018)
Changed paths:
M doc/stages/readers.text.rst
M io/TextReader.cpp
Log Message:
Add SRS support for readers.text. (#2122)
Commit: 99835f8d433c26f2848a6a4b518762284e08cb23
https://github.com/PDAL/PDAL/commit/99835f8d433c26f2848a6a4b518762284e08cb23
Date: 2018-08-10 (Fri, 10 Aug 2018)
Changed paths:
M cmake/options.cmake
A plugins/fbx/CMakeLists.txt
A plugins/fbx/io/FbxWriter.cpp
A plugins/fbx/io/FbxWriter.hpp
A plugins/fbx/test/FbxWriterTest.cpp
Log Message:
Add bare FBX writer (#2127)
* Temp check-in.
* Temp check-in.
* FBX writer creates a real file.
* Working FBX writer.
* Add test for FBX writer.
* Suppress cast warning.
* Remove some warning suppression.
Commit: 4e83901033f6f13e7dc324dbd9263c98e6b19b69
https://github.com/PDAL/PDAL/commit/4e83901033f6f13e7dc324dbd9263c98e6b19b69
Changed paths:
M filters/ReturnsFilter.cpp
A test/unit/filters/ReturnsFilterTest.cpp
Log Message:
Initialize outputTypes (#2116)
* Initialize m_outputTypes.
Close #2115
* Add filters.returns test.
* Add blank line for clarity.
Commit: caeab2a042c701e37b4e48ac231b2755f1fe6427
https://github.com/PDAL/PDAL/commit/caeab2a042c701e37b4e48ac231b2755f1fe6427
Changed paths:
M filters/ClusterFilter.cpp
A filters/private/Segmentation.cpp
A filters/private/Segmentation.hpp
R pdal/Segmentation.cpp
R pdal/Segmentation.hpp
M test/unit/SegmentationTest.cpp
Log Message:
Move Segmentation.Xpp to filters/private (#2112)
* Move Segmentation.Xpp to filters/private.
Close #2109
* Reference local files.
Commit: a3ceeccc2144e0fe8aa249a6a9aa7d9c7ca27338
https://github.com/PDAL/PDAL/commit/a3ceeccc2144e0fe8aa249a6a9aa7d9c7ca27338
Changed paths:
A test/unit/filters/VoxelTest.cpp
Log Message:
Add test for voxelcenternearestneighbor.
Commit: fe0df2a3f017686eb1ef5439b95b0c71220982a5
https://github.com/PDAL/PDAL/commit/fe0df2a3f017686eb1ef5439b95b0c71220982a5
Changed paths:
Log Message:
Commit: 939de4fb90e4e414f8c7d2175d272bdf19ffc745
https://github.com/PDAL/PDAL/commit/939de4fb90e4e414f8c7d2175d272bdf19ffc745
Date: 2018-08-13 (Mon, 13 Aug 2018)
Changed paths:
M io/FauxReader.cpp
Log Message:
Error if the point count isn't set. (#2129)
Commit: a3499cd22d9c7609dfc162a8d7f32e17dedab102
https://github.com/PDAL/PDAL/commit/a3499cd22d9c7609dfc162a8d7f32e17dedab102
Changed paths:
A doc/apps/tile.rst
M filters/SplitterFilter.cpp
M filters/SplitterFilter.hpp
M io/TextWriter.cpp
A kernels/TileKernel.cpp
A kernels/TileKernel.hpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/StageWrapper.hpp
M pdal/Streamable.hpp
M pdal/Writer.cpp
M pdal/Writer.hpp
A test/data/las/tile/file1.las
A test/data/las/tile/file2.las
A test/data/las/tile/file3.las
A test/data/text/file1.txt
A test/data/text/file2.txt
A test/data/text/file3.txt
A test/unit/apps/TileTest.cpp
Log Message:
Add tile command (#2125)
* Add public entry points to allow filters.splitter use outside of pipelines.
* Initial check-in for kernels.tile.
* Working tiler.
* Add skip support.
Add SRS support.
Fill point table when possible.
Improve logic.
* Improve argument text.
* Add SRS support for readers.text.
* First test for tile kernel.
* Add tile test.
Close #2065
* Notify reprojection filter about SRS changes.
* Add a test that includes a reprojection.
Close #2065
* Documentation.
* Debug.
* Ignore files that start with '.'
* Remove debug. Add comment.
* There were tabs instead of spaces. Huh.
Commit: 415b634b5fc2430ba884dc7a513801f5b2c2ec5f
https://github.com/PDAL/PDAL/commit/415b634b5fc2430ba884dc7a513801f5b2c2ec5f
Date: 2018-08-14 (Tue, 14 Aug 2018)
Changed paths:
M doc/stages/readers.faux.rst
Log Message:
Update readers.faux doc.
Commit: b8e6c7e6ac2095f6015cab3da586434e203a0698
https://github.com/PDAL/PDAL/commit/b8e6c7e6ac2095f6015cab3da586434e203a0698
Changed paths:
A doc/apps/tile.rst
M io/FauxReader.cpp
M io/TextWriter.cpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/Writer.cpp
M pdal/Writer.hpp
Log Message:
Commit: f1b695b874a8c3dc43e1a061ecb96089d282acef
https://github.com/PDAL/PDAL/commit/f1b695b874a8c3dc43e1a061ecb96089d282acef
Changed paths:
M plugins/python/filters/PythonFilter.cpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Invocation.hpp
M plugins/python/test/PythonFilterTest.cpp
Log Message:
support adding and deleting points to filters.numpy 'out' dictionary #1965 (#2120)
* support adding points to filters.numpy 'out' dictionary #1965
* update as mentioned in review for iteration
* test deleting too
* iterate Mask for its size, not the view's
Commit: 21b5676b86b310c5d0a4d97de20da0a322ec6e39
https://github.com/PDAL/PDAL/commit/21b5676b86b310c5d0a4d97de20da0a322ec6e39
Author: Mateusz Loskot <mateusz at loskot.net>
Changed paths:
M vendor/gtest/cmake/internal_utils.cmake
Log Message:
Add _SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING to gtest flags (#2134)
gtest uses std::tr1 which has been deprecated in VS 2017
https://github.com/google/googletest/issues/1111
Without _SILENCE_TR1_NAMESPACE_DEPRECATION_WARNING define, MSVC
generates warnings and, since warnings are treated as errors,
compilation fails.
Commit: 333a51bafa1260fca5b45e866cabc3523c923f7f
https://github.com/PDAL/PDAL/commit/333a51bafa1260fca5b45e866cabc3523c923f7f
Changed paths:
M cmake/unix_compiler_options.cmake
Log Message:
Handle cmake pre-3.1 for cxx standard version.
Commit: aa56ffa62e308b26ac330d43403b2873ed834417
https://github.com/PDAL/PDAL/commit/aa56ffa62e308b26ac330d43403b2873ed834417
Changed paths:
Log Message:
Commit: ca41f117639fa120c5f33843502361ef44cfa0c8
https://github.com/PDAL/PDAL/commit/ca41f117639fa120c5f33843502361ef44cfa0c8
Changed paths:
M .gitignore
Log Message:
Ignore CMakeSettings.json for CMake integration with VS2017 [ci skip] (#2136)
CMakeSettings.json is an auxiliary file used to customize CMake
configuration while building from within VS2017.
Commit: 5e1bd63dd08c0d2719a5a7d743563fa24068437e
https://github.com/PDAL/PDAL/commit/5e1bd63dd08c0d2719a5a7d743563fa24068437e
Changed paths:
M .gitignore
Log Message:
Commit: 725f9477d0bab3945cbd6a429b3eead00893e7c1
https://github.com/PDAL/PDAL/commit/725f9477d0bab3945cbd6a429b3eead00893e7c1
Date: 2018-08-15 (Wed, 15 Aug 2018)
Changed paths:
M .gitignore
M .travis.yml
A CITATION
M CMakeLists.txt
M README.md
M apps/pdal.cpp
M doc/about.rst
A doc/apps/tile.rst
M doc/conf.py
M doc/download.rst
M doc/faq.rst
M doc/pipeline.rst
M doc/python.rst
M io/FauxReader.cpp
M io/GDALGrid.hpp
M io/GDALReader.cpp
M io/GDALReader.hpp
M io/GDALWriter.cpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/TextReader.cpp
M io/TextWriter.cpp
M io/TextWriter.hpp
M pdal/Options.cpp
M pdal/Options.hpp
M pdal/Reader.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/Writer.cpp
M pdal/Writer.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into issue-1852
Compare: https://github.com/PDAL/PDAL/compare/8472c070d789...725f9477d0ba
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
