[pdal-commits] [PDAL/PDAL] d84a6d: Add dump.
GitHub
noreply at github.com
Tue Dec 18 11:51:25 PST 2018
Branch: refs/heads/issue-2320
Home: https://github.com/PDAL/PDAL
Commit: d84a6d6125d95849e2b9adaf74a64276691520bd
https://github.com/PDAL/PDAL/commit/d84a6d6125d95849e2b9adaf74a64276691520bd
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-10-30 (Tue, 30 Oct 2018)
Changed paths:
M io/LasWriter.cpp
Log Message:
Add dump.
Commit: 1e4104308f0706207877656c767d96b20991074f
https://github.com/PDAL/PDAL/commit/1e4104308f0706207877656c767d96b20991074f
Date: 2018-12-17 (Mon, 17 Dec 2018)
Changed paths:
M .travis.yml
M CMakeLists.txt
R ChangeLog
M HOWTORELEASE.txt
M RELEASENOTES.txt
M appveyor.yml
M cmake/config.cmake
M cmake/cpack.cmake
R cmake/examples/hobu-conda-win64.bat
M cmake/hdf5.cmake
M cmake/macros.cmake
M cmake/modules/FindGEOS.cmake
M cmake/modules/FindNitro.cmake
M cmake/modules/FindOracle.cmake
M cmake/options.cmake
M doc/apps/ground.rst
A doc/development/release-notes/1.8.0.md
M doc/download.rst
M doc/references.rst
M doc/stages/filters.assign.rst
M doc/stages/filters.dem.rst
M doc/stages/filters.hexbin.rst
A doc/stages/filters.info.rst
M doc/stages/filters.kdistance.rst
A doc/stages/filters.mongoexpression.rst
M doc/stages/filters.pmf.rst
M doc/stages/filters.rst
M doc/stages/filters.stats.rst
A doc/stages/reader_opts.rst
M doc/stages/readers.bpf.rst
M doc/stages/readers.buffer.rst
M doc/stages/readers.ept.rst
M doc/stages/readers.faux.rst
M doc/stages/readers.gdal.rst
M doc/stages/readers.geowave.rst
M doc/stages/readers.greyhound.rst
M doc/stages/readers.i3s.rst
M doc/stages/readers.ilvis2.rst
M doc/stages/readers.las.rst
M doc/stages/readers.matlab.rst
M doc/stages/readers.mbio.rst
M doc/stages/readers.mrsid.rst
M doc/stages/readers.nitf.rst
M doc/stages/readers.numpy.rst
M doc/stages/readers.oci.rst
M doc/stages/readers.optech.rst
M doc/stages/readers.pcd.rst
M doc/stages/readers.pgpointcloud.rst
M doc/stages/readers.ply.rst
M doc/stages/readers.pts.rst
M doc/stages/readers.qfit.rst
M doc/stages/readers.rdb.rst
M doc/stages/readers.rst
M doc/stages/readers.rxp.rst
M doc/stages/readers.sbet.rst
M doc/stages/readers.slpk.rst
M doc/stages/readers.sqlite.rst
M doc/stages/readers.terrasolid.rst
M doc/stages/readers.text.rst
M doc/stages/readers.tindex.rst
A filters/MongoExpressionFilter.cpp
A filters/MongoExpressionFilter.hpp
M filters/PMFFilter.cpp
M filters/SMRFilter.cpp
M filters/private/hexer/HexGrid.cpp
M filters/private/hexer/Hexagon.cpp
A filters/private/mongoexpression/Comparison.cpp
A filters/private/mongoexpression/Comparison.hpp
A filters/private/mongoexpression/Expression.cpp
A filters/private/mongoexpression/Expression.hpp
A filters/private/mongoexpression/LogicGate.cpp
A filters/private/mongoexpression/LogicGate.hpp
A filters/private/mongoexpression/Support.hpp
M io/BpfWriter.cpp
M io/BpfWriter.hpp
M io/GDALReader.cpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/TIndexReader.cpp
M kernels/DensityKernel.cpp
M kernels/TIndexKernel.cpp
M package.sh
M pdal/DbWriter.cpp
M pdal/EigenUtils.cpp
M pdal/FlexWriter.hpp
M pdal/PointTable.hpp
M pdal/PointView.cpp
M pdal/PointView.hpp
M pdal/Reader.cpp
M pdal/Reader.hpp
M pdal/Scaling.cpp
M pdal/Scaling.hpp
M pdal/Stage.cpp
M pdal/Stage.hpp
M pdal/util/FileUtils.cpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/bounds.cpp
M plugins/greyhound/io/bounds.hpp
M plugins/nitf/CMakeLists.txt
M plugins/pcl/CMakeLists.txt
M plugins/python/plang/Environment.cpp
M plugins/rdb/io/RdbReader.cpp
M plugins/rxp/io/RxpPointcloud.hpp
M scripts/appveyor/build.cmd
M scripts/appveyor/config.cmd
M scripts/appveyor/install.cmd
M scripts/appveyor/test.cmd
M scripts/ci/add_deploy_key.sh
A scripts/ci/after_success.sh
R scripts/ci/before_install.sh
M scripts/ci/build_docs.sh
R scripts/ci/common.sh
R scripts/ci/docker.sh
M scripts/ci/script.sh
A scripts/conda/osx.sh
A scripts/conda/win64.sh
M scripts/docker/Dockerfile
A scripts/docker/alpine/Dockerfile
A scripts/docker/alpine/Dockerfile.dependencies
M scripts/docker/master/ubuntu/Dockerfile
M scripts/docker/ubuntu/Dockerfile
M test/unit/CMakeLists.txt
M test/unit/FileUtilsTest.cpp
M test/unit/MetadataTest.cpp
M test/unit/PointViewTest.cpp
M test/unit/StreamingTest.cpp
A test/unit/filters/MongoExpressionFilterTest.cpp
M test/unit/filters/SMRFilterTest.cpp
M test/unit/io/LasWriterTest.cpp
M vendor/arbiter/arbiter.cpp
R vendor/eigen/Eigen/src/OrderingMethods/Amd.h
R vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
R vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
Log Message:
Merge remote-tracking branch 'origin/master' into laszip_issue
Commit: 6d00608f2fb3a4c4f775116c0d4ce327c87b8c69
https://github.com/PDAL/PDAL/commit/6d00608f2fb3a4c4f775116c0d4ce327c87b8c69
Changed paths:
M io/LasWriter.cpp
Log Message:
Set the pre 1.4 fields when we're writing 1.4.
Commit: 5519b17386e3ef16462620fe3ccd725bda2ada07
https://github.com/PDAL/PDAL/commit/5519b17386e3ef16462620fe3ccd725bda2ada07
Date: 2018-12-18 (Tue, 18 Dec 2018)
Changed paths:
A test/data/las/wontcompress3.las
Log Message:
Test for fix of LASzip API issue.
Close #2320
Compare: https://github.com/PDAL/PDAL/compare/d84a6d6125d9^...5519b17386e3
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
