[pdal-commits] [PDAL/PDAL] 40822b: Make sure pre 1.4 data is populated for 1.4 point ...
GitHub noreply at github.com
Wed Dec 19 06:21:50 PST 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 40822bdfbfa819f939f27d0526e8d6e4e57ad7b5
      https://github.com/PDAL/PDAL/commit/40822bdfbfa819f939f27d0526e8d6e4e57ad7b5
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-12-19 (Wed, 19 Dec 2018)
  Changed paths:
    M io/LasWriter.cpp
    A test/data/las/wontcompress3.las
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Make sure pre 1.4 data is populated for 1.4 point types (#2321)
* Add dump.
* Set the pre 1.4 fields when we're writing 1.4.
* Test for fix of LASzip API issue.
Close #2320
* Guard min for Windows.
      **NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
      Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits mailing list
