[pdal-commits] [PDAL/PDAL] 417261: Make sure pre 1.4 data is populated for 1.4 point ...
GitHub
noreply at github.com
Wed Dec 19 06:35:54 PST 2018
Branch: refs/heads/1.8-maintenance
Home: https://github.com/PDAL/PDAL
Commit: 41726174275a1476e0fe9a682d72398668e08a64
https://github.com/PDAL/PDAL/commit/41726174275a1476e0fe9a682d72398668e08a64
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-12-19 (Wed, 19 Dec 2018)
Changed paths:
M io/LasWriter.cpp
A test/data/las/wontcompress3.las
M test/unit/io/LasWriterTest.cpp
Log Message:
Make sure pre 1.4 data is populated for 1.4 point types (#2321)
Commit: 8747d76ae860fdd8862b75e2e975db81c78817e6
https://github.com/PDAL/PDAL/commit/8747d76ae860fdd8862b75e2e975db81c78817e6
Changed paths:
M plugins/pcl/filters/IcpFilter.cpp
Log Message:
Use proper call for setting the input point cloud (#2319)
Compare: https://github.com/PDAL/PDAL/compare/5aa7d1745fb0...8747d76ae860
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
