[pdal-commits] [PDAL/PDAL] 0f9a28: Fix filter.crop outside logic being flipped twice ...
GitHub
noreply at github.com
Thu Dec 27 15:10:41 PST 2018
Branch: refs/heads/build
Home: https://github.com/PDAL/PDAL
Commit: 0f9a28f3cf640b80211852a27c9efa620cba64bd
https://github.com/PDAL/PDAL/commit/0f9a28f3cf640b80211852a27c9efa620cba64bd
Author: Daniel Brookes <26078684+dbrookes96 at users.noreply.github.com>
Date: 2018-12-12 (Wed, 12 Dec 2018)
Changed paths:
M filters/CropFilter.cpp
M test/unit/filters/CropFilterTest.cpp
Log Message:
Fix filter.crop outside logic being flipped twice when not in stream mode. (#2306)
Commit: 27102b1736c505822e122334ef106faecb838133
https://github.com/PDAL/PDAL/commit/27102b1736c505822e122334ef106faecb838133
Author: Howard Butler <howard at hobu.co>
Date: 2018-12-13 (Thu, 13 Dec 2018)
Changed paths:
M doc/references.rst
Log Message:
add citation info
Commit: b97f8dcd2de53cf8a7ae3e72e280d799e9866c50
https://github.com/PDAL/PDAL/commit/b97f8dcd2de53cf8a7ae3e72e280d799e9866c50
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
Log Message:
Fix type comparison for crop filter test.
Commit: 0f9e054cac0f13541ea833618e337adff1de5ed3
https://github.com/PDAL/PDAL/commit/0f9e054cac0f13541ea833618e337adff1de5ed3
Date: 2018-12-17 (Mon, 17 Dec 2018)
Changed paths:
R io/GDALGrid.cpp
R io/GDALGrid.hpp
M io/GDALWriter.cpp
M io/GDALWriter.hpp
A io/private/GDALGrid.cpp
A io/private/GDALGrid.hpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Fix computation of shift/size when streaming points. (#2310)
* Cleaner shift implementation.
Close #2292
Commit: feebfaddeb8cec02d0857231941a0c5086b6cb36
https://github.com/PDAL/PDAL/commit/feebfaddeb8cec02d0857231941a0c5086b6cb36
Changed paths:
M doc/pipeline.rst
M doc/stages/readers.tindex.rst
Log Message:
Fix some errors in the pipeline doc. (#2314)
* Fix some errors in the pipeline doc.
* Update based on feedback.
Commit: 30010535a58837f89cecdc67e0b85228765355f6
https://github.com/PDAL/PDAL/commit/30010535a58837f89cecdc67e0b85228765355f6
Date: 2018-12-18 (Tue, 18 Dec 2018)
Changed paths:
M CMakeLists.txt
M vendor/arbiter/CMakeLists.txt
Log Message:
Make sure arbiter depends on curl. (#2301)
Close #1822
Commit: 77313ad36f16b1ba3ad68a4917cc835cd89855b7
https://github.com/PDAL/PDAL/commit/77313ad36f16b1ba3ad68a4917cc835cd89855b7
Date: 2018-12-19 (Wed, 19 Dec 2018)
Changed paths:
M HOWTORELEASE.txt
Log Message:
Replace with proper file.
Commit: 8788dc0c25c5245047352cdb94e94b1a4d5ab8f0
https://github.com/PDAL/PDAL/commit/8788dc0c25c5245047352cdb94e94b1a4d5ab8f0
Changed paths:
M CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/master'
Commit: 5d788bd1b207373c06179601eb40809c783517f2
https://github.com/PDAL/PDAL/commit/5d788bd1b207373c06179601eb40809c783517f2
Changed paths:
M io/PtsReader.cpp
A test/data/pts/bunny_8.pts
M test/unit/io/PtsReaderTest.cpp
Log Message:
Improvements to reader.pts (#2317)
Peek the first line of the input file to determine what dimensions to add. Allows for reading PTS files which don't have Intensity, R, G or B such as the bunnyData.pts point cloud from http://www.libe57.org/data.html.
Also, limit the number of points read by the expected point count on the first line of the PTS file.
Added a unit test and bunny_8.pts test data to check the above two things. Note that bunny_8.pts actually contains 9 points but has 8 as the expected point count.
Commit: 40822bdfbfa819f939f27d0526e8d6e4e57ad7b5
https://github.com/PDAL/PDAL/commit/40822bdfbfa819f939f27d0526e8d6e4e57ad7b5
Changed paths:
M io/LasWriter.cpp
A test/data/las/wontcompress3.las
M test/unit/io/LasWriterTest.cpp
Log Message:
Make sure pre 1.4 data is populated for 1.4 point types (#2321)
* Add dump.
* Set the pre 1.4 fields when we're writing 1.4.
* Test for fix of LASzip API issue.
Close #2320
* Guard min for Windows.
Commit: ce20924c80b8eb8828eaeb61b25bca2ffe867f22
https://github.com/PDAL/PDAL/commit/ce20924c80b8eb8828eaeb61b25bca2ffe867f22
Changed paths:
M plugins/pcl/filters/IcpFilter.cpp
Log Message:
Use proper call for setting the input point cloud (#2319)
* ICP debug.
* Use the correct call to set the base point cloud.
Commit: 92652964db1c1aa1d173a6418074a6c3656cdc4d
https://github.com/PDAL/PDAL/commit/92652964db1c1aa1d173a6418074a6c3656cdc4d
Changed paths:
M io/TIndexReader.cpp
Log Message:
Make sure we set an SRS for geometry. (#2325)
Close #2316
Commit: f0a5303fe595f4acafd6797bead7831279613bf4
https://github.com/PDAL/PDAL/commit/f0a5303fe595f4acafd6797bead7831279613bf4
Date: 2018-12-20 (Thu, 20 Dec 2018)
Changed paths:
M io/PtsReader.cpp
A test/data/pts/site_56_8.pts
Log Message:
Improvements to reader.pts again. (#2326)
Allow for X Y Z Intensity formatted .pts files.
Check if the expected point count at the top of the file was read correctly.
Emit a warning when points read was less than the expected.
Commit: 89d9743ccca2898bc62ed70b86e6dfdcb5e610dc
https://github.com/PDAL/PDAL/commit/89d9743ccca2898bc62ed70b86e6dfdcb5e610dc
Date: 2018-12-27 (Thu, 27 Dec 2018)
Changed paths:
M CMakeLists.txt
M cmake/macros.cmake
M pdal/util/CMakeLists.txt
Log Message:
Merge remote-tracking branch 'origin/build' into build
Commit: 3bc65c42af9952243a59d6e0d619de120cf34d87
https://github.com/PDAL/PDAL/commit/3bc65c42af9952243a59d6e0d619de120cf34d87
Changed paths:
M CMakeLists.txt
M PDALConfig.cmake.in
Log Message:
Change linking for downstream packages.
Compare: https://github.com/PDAL/PDAL/compare/39e0b88325ee...3bc65c42af99
**NOTE:** This service has been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
