[pdal-commits] [PDAL/PDAL] 4f63d2: Throw error if we can't open PLY file.
GitHub
noreply at github.com
Thu Feb 1 06:41:06 PST 2018
Branch: refs/heads/plugin
Home: https://github.com/PDAL/PDAL
Commit: 4f63d2b3138d9addc4f55401155fa2668583a4fe
https://github.com/PDAL/PDAL/commit/4f63d2b3138d9addc4f55401155fa2668583a4fe
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-01-17 (Wed, 17 Jan 2018)
Changed paths:
M io/PlyReader.cpp
Log Message:
Commit: 50ace60ea647fdfeee08d939cbb9f3f11fcd25b3
https://github.com/PDAL/PDAL/commit/50ace60ea647fdfeee08d939cbb9f3f11fcd25b3
Author: Connor Manning <connor at hobu.co>
Date: 2018-01-19 (Fri, 19 Jan 2018)
Changed paths:
M filters/FerryFilter.cpp
Log Message:
Register the FerryFilter's destination dimension with the same type as the source, rather than always a double.
Commit: 4fd2ae8e1f468c00c598f8ec7f169f87665ba872
https://github.com/PDAL/PDAL/commit/4fd2ae8e1f468c00c598f8ec7f169f87665ba872
Changed paths:
M doc/stages/readers.greyhound.rst
A doc/stages/writers.greyhound.rst
M pdal/Dimension.json
M pdal/StageFactory.cpp
M plugins/greyhound/CMakeLists.txt
A plugins/greyhound/io/GreyhoundCommon.cpp
A plugins/greyhound/io/GreyhoundCommon.hpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/GreyhoundReader.hpp
A plugins/greyhound/io/GreyhoundWriter.cpp
A plugins/greyhound/io/GreyhoundWriter.hpp
M plugins/greyhound/io/bounds.cpp
M plugins/greyhound/io/bounds.hpp
M plugins/greyhound/io/point.hpp
M plugins/greyhound/test/GreyhoundReaderTest.cpp
Log Message:
Add Greyhound writer (#1782)
Commit: cb641be793c4cf9e6d311b2051037e86d915aec9
https://github.com/PDAL/PDAL/commit/cb641be793c4cf9e6d311b2051037e86d915aec9
Changed paths:
Log Message:
Merge pull request #1783 from PDAL/ferry-filter-type
Commit: d0e9b56a406d2bad816a2048869ed93edafd3d5e
https://github.com/PDAL/PDAL/commit/d0e9b56a406d2bad816a2048869ed93edafd3d5e
Author: Howard Butler <howard at hobu.co>
Changed paths:
M scripts/docker/Dockerfile
Log Message:
more alpine tweaks
Commit: 179e3682518229ab10883aa44387a328b0d888d6
https://github.com/PDAL/PDAL/commit/179e3682518229ab10883aa44387a328b0d888d6
Changed paths:
Log Message:
Don't remove proj4-dev in the Docker setup.
Commit: 81d94d3e72cd74255d2ad9d49f2f85bb8ef7b856
https://github.com/PDAL/PDAL/commit/81d94d3e72cd74255d2ad9d49f2f85bb8ef7b856
Date: 2018-01-23 (Tue, 23 Jan 2018)
Changed paths:
M plugins/greyhound/io/GreyhoundWriter.cpp
Log Message:
Update GreyhoundWriter for new Greyhound addon API.
Commit: 060f7832abc0f738601823f6bd2cd20b1f1e5c9d
https://github.com/PDAL/PDAL/commit/060f7832abc0f738601823f6bd2cd20b1f1e5c9d
Changed paths:
M pdal/DimUtil.hpp
Log Message:
Allow dimension names to contain slashes for the assign/range filters.
Commit: d63b1210e27a26d2eb1b66368b20bee35f948d48
https://github.com/PDAL/PDAL/commit/d63b1210e27a26d2eb1b66368b20bee35f948d48
Changed paths:
M doc/stages/filters.python.rst
Log Message:
Fix doc error.
Commit: 64caa1d4b35d168214ce405273a50fd3abb8a803
https://github.com/PDAL/PDAL/commit/64caa1d4b35d168214ce405273a50fd3abb8a803
Changed paths:
Log Message:
Fix typos on other side of ifdef. Ifdef's are awful.
Commit: 37edaa3f0676754a35df45067fd15564d9c5c30b
https://github.com/PDAL/PDAL/commit/37edaa3f0676754a35df45067fd15564d9c5c30b
Changed paths:
M pdal/DimUtil.hpp
Log Message:
Merge pull request #1784 from PDAL/dimensions-with-slashes
Commit: f71e19607e9fc010cf387e81699aeb9185d7b360
https://github.com/PDAL/PDAL/commit/f71e19607e9fc010cf387e81699aeb9185d7b360
Date: 2018-01-24 (Wed, 24 Jan 2018)
Changed paths:
M scripts/ci/script.sh
Log Message:
Re-enable Python Extension building on AppVeyor (#1787)
* turn Python extension testing back on
* need pip
* need cython
Commit: 5e7c3985e8f6ccd1ed1c84d8cfb1b9517ead34a1
https://github.com/PDAL/PDAL/commit/5e7c3985e8f6ccd1ed1c84d8cfb1b9517ead34a1
Author: Blottiere Paul <blottiere.paul at gmail.com>
Date: 2018-01-25 (Thu, 25 Jan 2018)
Changed paths:
A doc/stages/filters.mortonorder.img1.png
M doc/stages/filters.mortonorder.rst
M filters/MortonOrderFilter.cpp
M filters/MortonOrderFilter.hpp
M test/unit/CMakeLists.txt
A test/unit/filters/MortonOrderTest.cpp
Log Message:
[filter] Reverse Morton (#1786)
* Add revert Morton algorithm
* Add test
* Rename option from revert to reverse
* Update documentation
* Some minor changes
Commit: 59feb3997a413dab105c66dabf0684558f262fc6
https://github.com/PDAL/PDAL/commit/59feb3997a413dab105c66dabf0684558f262fc6
Changed paths:
M doc/tutorial/pcl_spec.rst
Log Message:
fix up filters.ground references that are now out of date
Commit: 4d9dfe8f48ee860c59d159e190a4f441cc26d78f
https://github.com/PDAL/PDAL/commit/4d9dfe8f48ee860c59d159e190a4f441cc26d78f
Changed paths:
Log Message:
Use master branch for Dockerfile.
Commit: 5a79f514b98fd79433eba33f461f0d5063a9f602
https://github.com/PDAL/PDAL/commit/5a79f514b98fd79433eba33f461f0d5063a9f602
Date: 2018-01-29 (Mon, 29 Jan 2018)
Changed paths:
M doc/stages/readers.text.rst
M io/TextReader.cpp
M io/TextReader.hpp
A test/data/text/missingheader.txt
M test/unit/io/TextReaderTest.cpp
Log Message:
Add support for overriding header line in readers.text. (#1795)
* Add support for overriding header line in readers.text.
Close #1788
* Update doc.
Commit: d4a8f7c658a90db77ba70edf87430f7efff97c54
https://github.com/PDAL/PDAL/commit/d4a8f7c658a90db77ba70edf87430f7efff97c54
Author: chambbj <brad.chambers at gmail.com>
Changed paths:
M scripts/docker/1.4-maintenance/alpine/Dockerfile
M scripts/docker/1.5-maintenance/alpine/Dockerfile
M scripts/docker/1.6-maintenance/alpine/Dockerfile
M scripts/docker/master/alpine/Dockerfile
Log Message:
Persist the proj4-dev package (#1797)
proj4-dev contains the libproj.so symbolic link that GDAL expects. We need it
at runtime and cannot delete it as build-only dependency.
Commit: d76922bd893e99f1426d5d6adab2f50b3f088d14
https://github.com/PDAL/PDAL/commit/d76922bd893e99f1426d5d6adab2f50b3f088d14
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M cmake/win32_compiler_options.cmake
M filters/private/pnp/GridPnp.hpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/Ilvis2Reader.cpp
M io/Ilvis2Reader.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/PlyReader.cpp
M io/QfitReader.cpp
M kernels/HausdorffKernel.cpp
M kernels/InfoKernel.cpp
M pdal/DbWriter.cpp
M pdal/GDALUtils.cpp
M pdal/GEOSUtils.cpp
M pdal/Mesh.hpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PipelineManager.cpp
M pdal/PluginManager.cpp
M pdal/PointView.hpp
M pdal/PyArray.hpp
M pdal/SpatialReference.cpp
M pdal/Writer.cpp
M pdal/XMLSchema.hpp
M pdal/compression/Compression.hpp
A pdal/compression/DeflateCompression.cpp
M pdal/compression/DeflateCompression.hpp
A pdal/compression/LazPerfCompression.cpp
M pdal/compression/LazPerfCompression.hpp
A pdal/compression/LazPerfVlrCompression.cpp
A pdal/compression/LazPerfVlrCompression.hpp
A pdal/compression/LzmaCompression.cpp
M pdal/compression/LzmaCompression.hpp
A pdal/compression/ZstdCompression.cpp
M pdal/compression/ZstdCompression.hpp
M pdal/pdal_config.cpp
M pdal/pdal_config.hpp
M pdal/pdal_export.hpp
M pdal/pdal_internal.hpp
M pdal/util/Utils.cpp
M pdal/util/Uuid.hpp
R pdal_defines.h.in
A pdal_features.hpp.in
M plugins/mrsid/test/MrsidTest.cpp
M plugins/nitf/io/MetadataReader.cpp
M plugins/nitf/io/MetadataReader.hpp
M plugins/nitf/io/NitfFileReader.hpp
M plugins/nitf/io/NitfFileWriter.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/oci/io/OciWrapper.cpp
M plugins/python/plang/Environment.cpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Redirector.cpp
M plugins/python/plang/Redirector.hpp
M plugins/python/plang/Script.cpp
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M plugins/sqlite/test/SQLiteTest.cpp
R test/unit/CompressionTest.cpp
M test/unit/ConfigTest.cpp
A test/unit/DeflateTest.cpp
A test/unit/LazPerfTest.cpp
A test/unit/LzmaTest.cpp
M test/unit/PluginManagerTest.cpp
M test/unit/SegmentationTest.cpp
M test/unit/UtilsTest.cpp
A test/unit/ZstdTest.cpp
M test/unit/apps/pc2pcTest.cpp
Log Message:
Config (#1796)
Eliminate some conditional compilation and make build more build-system agnostic.
Commit: 29f7c8ca0b6db10f6c9bd9c3dfed32833a6874c8
https://github.com/PDAL/PDAL/commit/29f7c8ca0b6db10f6c9bd9c3dfed32833a6874c8
Date: 2018-02-01 (Thu, 01 Feb 2018)
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M examples/CMakeLists.txt
M examples/writing-kernel/MyKernel.hpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/PlyReader.cpp
M io/QfitReader.cpp
M io/TextReader.cpp
M io/TextReader.hpp
M pdal/DbWriter.cpp
M pdal/DimUtil.hpp
M pdal/Mesh.hpp
M pdal/PyArray.hpp
M pdal/Writer.cpp
R pdal_defines.h.in
Log Message:
Merge remote-tracking branch 'origin/master' into plugin
Add CMakeLists.txt for test build of examples.
Compare: https://github.com/PDAL/PDAL/compare/f97100db417b...29f7c8ca0b6d
More information about the pdal-commits
