[pdal-commits] [PDAL/PDAL] b0ab8d: Change defines to features.
GitHub
noreply at github.com
Thu Feb 1 08:36:37 PST 2018
Branch: refs/heads/plugin
Home: https://github.com/PDAL/PDAL
Commit: b0ab8d2a35f3e621c63c23892d2771f36348b8fa
https://github.com/PDAL/PDAL/commit/b0ab8d2a35f3e621c63c23892d2771f36348b8fa
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-01-24 (Wed, 24 Jan 2018)
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M io/Ilvis2Reader.cpp
M io/Ilvis2Reader.hpp
M io/LasHeader.cpp
M kernels/HausdorffKernel.cpp
M kernels/InfoKernel.cpp
M pdal/Mesh.hpp
M pdal/PDALUtils.hpp
M pdal/PipelineManager.cpp
M pdal/PluginManager.cpp
M pdal/XMLSchema.hpp
M pdal/pdal_config.cpp
M pdal/pdal_config.hpp
M pdal/pdal_export.hpp
M pdal/pdal_internal.hpp
R pdal_defines.h.in
A pdal_features.h.in
M plugins/greyhound/CMakeLists.txt
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/GreyhoundWriter.cpp
M plugins/sqlite/test/SQLiteTest.cpp
M test/unit/ConfigTest.cpp
M test/unit/PluginManagerTest.cpp
M test/unit/SegmentationTest.cpp
M test/unit/UtilsTest.cpp
Log Message:
In progress.
Commit: 802abfb46b4684c5462506d5855e5ea7b04300e3
https://github.com/PDAL/PDAL/commit/802abfb46b4684c5462506d5855e5ea7b04300e3
Changed paths:
Log Message:
Remove extra def.
Commit: 2e55a50e5b7f9bfc2bfcc4231ee575a65ac09d5b
https://github.com/PDAL/PDAL/commit/2e55a50e5b7f9bfc2bfcc4231ee575a65ac09d5b
Changed paths:
M pdal/PDALUtils.cpp
Log Message:
Noexcept ugh.
Commit: dc685cc8bc1ef18cf62c6ded7ed1f2048c7d1e49
https://github.com/PDAL/PDAL/commit/dc685cc8bc1ef18cf62c6ded7ed1f2048c7d1e49
Changed paths:
Log Message:
Fix typo.
Commit: 05c3636048c34f3937b93f6316e284b519dde00d
https://github.com/PDAL/PDAL/commit/05c3636048c34f3937b93f6316e284b519dde00d
Changed paths:
M pdal/PyArray.hpp
M plugins/python/plang/Redirector.hpp
Log Message:
Fix some python stuff.
Commit: 12dc01fe45cce7b6a246d4f946797583f4dcfc7f
https://github.com/PDAL/PDAL/commit/12dc01fe45cce7b6a246d4f946797583f4dcfc7f
Changed paths:
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
Log Message:
Add headers for sqlite.
Commit: 6dd4bb251d3852383ccbc400ae3107e908490009
https://github.com/PDAL/PDAL/commit/6dd4bb251d3852383ccbc400ae3107e908490009
Date: 2018-01-25 (Thu, 25 Jan 2018)
Changed paths:
M CMakeLists.txt
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
A pdal/compression/DeflateCompression.cpp
M pdal/compression/DeflateCompression.hpp
A pdal/compression/LazPerfCompression.cpp
M pdal/compression/LazPerfCompression.hpp
A pdal/compression/LazPerfVlrCompression.cpp
A pdal/compression/LazPerfVlrCompression.hpp
A pdal/compression/LzmaCompression.cpp
M pdal/compression/LzmaCompression.hpp
A pdal/compression/ZstdCompression.cpp
M pdal/compression/ZstdCompression.hpp
M test/unit/CMakeLists.txt
M test/unit/CompressionTest.cpp
A test/unit/DeflateTest.cpp
A test/unit/LazPerfTest.cpp
A test/unit/LzmaTest.cpp
A test/unit/ZstdTest.cpp
Log Message:
Remove PDAL_HAVE dependencies from compression code.
Commit: 2e9af63024acb9abb67682eb1ba5a1258a09b726
https://github.com/PDAL/PDAL/commit/2e9af63024acb9abb67682eb1ba5a1258a09b726
Changed paths:
M pdal/compression/LazPerfVlrCompression.hpp
R test/unit/CompressionTest.cpp
Log Message:
Remove dead test. Add header.
Commit: c941c999a946fd638fdd4c64b8c935885f79e4c3
https://github.com/PDAL/PDAL/commit/c941c999a946fd638fdd4c64b8c935885f79e4c3
Changed paths:
M pdal/compression/LazPerfCompression.cpp
M pdal/compression/LazPerfVlrCompression.cpp
Log Message:
Fix lots of typos.
Commit: fc33dae7c5a954dc50a748e8c7062e6f06b4db27
https://github.com/PDAL/PDAL/commit/fc33dae7c5a954dc50a748e8c7062e6f06b4db27
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M cmake/win32_compiler_options.cmake
M io/QfitReader.cpp
M pdal/GDALUtils.cpp
M pdal/GEOSUtils.cpp
M pdal/PointView.hpp
M pdal/SpatialReference.cpp
M pdal/Writer.cpp
M pdal/util/Utils.cpp
M pdal/util/Uuid.hpp
R pdal_features.h.in
A pdal_features.hpp.in
M plugins/mrsid/test/MrsidTest.cpp
M plugins/nitf/io/MetadataReader.cpp
M plugins/nitf/io/MetadataReader.hpp
M plugins/nitf/io/NitfFileReader.hpp
M plugins/nitf/io/NitfFileWriter.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/python/plang/Environment.cpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Redirector.cpp
M plugins/python/plang/Script.cpp
M test/unit/apps/pc2pcTest.cpp
Log Message:
Reduce dependencies on build system for correct compilation.
Commit: 507428c20e46e48c1a35ce3ba0a7739caf5edfc2
https://github.com/PDAL/PDAL/commit/507428c20e46e48c1a35ce3ba0a7739caf5edfc2
Changed paths:
Log Message:
Remove warning catch for dead option.
Commit: f5fbc9afacc067c69503be5bc5a389a09a4de424
https://github.com/PDAL/PDAL/commit/f5fbc9afacc067c69503be5bc5a389a09a4de424
Changed paths:
Log Message:
More.
Commit: 71953e7b9402a20c3f004966a64915118563f37b
https://github.com/PDAL/PDAL/commit/71953e7b9402a20c3f004966a64915118563f37b
Changed paths:
M pdal/compression/Compression.hpp
Log Message:
PDAL_DLL fun
Commit: e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
https://github.com/PDAL/PDAL/commit/e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
Changed paths:
A doc/stages/filters.mortonorder.img1.png
M doc/stages/filters.mortonorder.rst
M doc/stages/filters.python.rst
M doc/tutorial/pcl_spec.rst
M filters/MortonOrderFilter.cpp
M filters/MortonOrderFilter.hpp
M pdal/DimUtil.hpp
M scripts/ci/script.sh
M scripts/docker/Dockerfile
A test/unit/filters/MortonOrderTest.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into config
Commit: f223102ade3879d885fb54e0e193943b7ae7c413
https://github.com/PDAL/PDAL/commit/f223102ade3879d885fb54e0e193943b7ae7c413
Date: 2018-01-26 (Fri, 26 Jan 2018)
Changed paths:
Log Message:
Remove arbiter lib.
Commit: 904e7462d29ec36bcdf287f755fa27584a19f759
https://github.com/PDAL/PDAL/commit/904e7462d29ec36bcdf287f755fa27584a19f759
Changed paths:
M filters/private/pnp/GridPnp.hpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/PlyReader.cpp
M pdal/DbWriter.cpp
M pdal_features.hpp.in
M plugins/greyhound/io/point.hpp
M plugins/oci/io/OciWrapper.cpp
Log Message:
Changes to eliminate warnings on MSVC.
Commit: dae0102127107d54aeabcd292ff93d12b0087b4e
https://github.com/PDAL/PDAL/commit/dae0102127107d54aeabcd292ff93d12b0087b4e
Changed paths:
Log Message:
Remove extra PDAL_DLL.
Commit: a4c89e44e8d8d7664e039c09d7cb1f4bf6043919
https://github.com/PDAL/PDAL/commit/a4c89e44e8d8d7664e039c09d7cb1f4bf6043919
Changed paths:
Log Message:
More missed PDAL_DLL on decompressor.
Commit: 3c1a3542c57858814b4ee2e1e533c9e809918a61
https://github.com/PDAL/PDAL/commit/3c1a3542c57858814b4ee2e1e533c9e809918a61
Date: 2018-01-29 (Mon, 29 Jan 2018)
Changed paths:
M pdal/Mesh.hpp
Log Message:
Minor fixes.
Commit: 7c0297a483f89fc137e367caa66c9a5c599e3dca
https://github.com/PDAL/PDAL/commit/7c0297a483f89fc137e367caa66c9a5c599e3dca
Changed paths:
Log Message:
Add missed LASZIP LAZPERF defines.
Commit: 6c0b4775c1f8a3866ac3fc24d8882f6a747f8a84
https://github.com/PDAL/PDAL/commit/6c0b4775c1f8a3866ac3fc24d8882f6a747f8a84
Changed paths:
M CMakeLists.txt
M apps/pdal.cpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/PlyReader.cpp
M io/QfitReader.cpp
M pdal/DbWriter.cpp
M pdal/Mesh.hpp
M pdal/PyArray.hpp
M pdal/Writer.cpp
R pdal_defines.h.in
Log Message:
Merge branch 'config'
Commit: cd43b47475caaf7e34eaaffcd46912c5866ff4ff
https://github.com/PDAL/PDAL/commit/cd43b47475caaf7e34eaaffcd46912c5866ff4ff
Changed paths:
Log Message:
Commit: 238f38f1af6701bc3d5897a8fa5c25d7bc1a9259
https://github.com/PDAL/PDAL/commit/238f38f1af6701bc3d5897a8fa5c25d7bc1a9259
Changed paths:
Log Message:
Add back LASZIP and LAZPERF defines.
Commit: 073445ea3cca50d414490c4b076c025b5323e0f8
https://github.com/PDAL/PDAL/commit/073445ea3cca50d414490c4b076c025b5323e0f8
Date: 2018-01-30 (Tue, 30 Jan 2018)
Changed paths:
M CMakeLists.txt
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M plugins/greyhound/io/GreyhoundCommon.cpp
M plugins/oci/io/OciReader.cpp
M plugins/oci/io/OciWriter.cpp
M test/unit/io/LasReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
Log Message:
Make sure files include pdal_features.
Commit: 2cb5e840ba1e310d0a513672879fecc925d7feb7
https://github.com/PDAL/PDAL/commit/2cb5e840ba1e310d0a513672879fecc925d7feb7
Changed paths:
M kernels/TIndexKernel.cpp
M test/unit/apps/TIndexTest.cpp
Log Message:
Make --stdin work on kernels.tindex.
Commit: d8bdced9c86283c4a786a5d9835f72bad6e79943
https://github.com/PDAL/PDAL/commit/d8bdced9c86283c4a786a5d9835f72bad6e79943
Author: Howard Butler <howard at hobu.co>
Date: 2018-01-31 (Wed, 31 Jan 2018)
Changed paths:
R doc/development/alpine.rst
A doc/project/alpine.rst
M doc/project/contributors.rst
M doc/project/docker.rst
M doc/tutorial/index.rst
Log Message:
doc warnings fixes
Commit: fa745a4b07806ac57d72f29d49b6fda4b59db9ac
https://github.com/PDAL/PDAL/commit/fa745a4b07806ac57d72f29d49b6fda4b59db9ac
Author: Mateusz Loskot <mateusz at loskot.net>
Date: 2018-02-01 (Thu, 01 Feb 2018)
Changed paths:
M io/OGRWriterV1.cpp
Log Message:
Remove superfluous semi-colon following CREATE_STATIC_PLUGIN (#1798)
Fixes GCC 5.6.0 error: extra ‘;’ [-Werror=pedantic]
Commit: d6dbf82764cb04d607c0784b0ac327ff9e4e92c8
https://github.com/PDAL/PDAL/commit/d6dbf82764cb04d607c0784b0ac327ff9e4e92c8
Changed paths:
A doc/project/index.rst
Log Message:
add missing file
Commit: da85f20dd0dc2773d8d5ae006cb28388204eb7a9
https://github.com/PDAL/PDAL/commit/da85f20dd0dc2773d8d5ae006cb28388204eb7a9
Changed paths:
Log Message:
Merge branch 'master' of github.com:PDAL/PDAL
Commit: 5d3341b9d33e7be19d34d31d37db1a8eab6fcfad
https://github.com/PDAL/PDAL/commit/5d3341b9d33e7be19d34d31d37db1a8eab6fcfad
Changed paths:
M CMakeLists.txt
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
Log Message:
Merge remote-tracking branch 'origin/master' into plugin
Commit: 01d12db00bf5380d66ba08ed71d85ef958ddcfcd
https://github.com/PDAL/PDAL/commit/01d12db00bf5380d66ba08ed71d85ef958ddcfcd
Changed paths:
M python/test/test_pipeline.py
Log Message:
Debug.
Compare: https://github.com/PDAL/PDAL/compare/29f7c8ca0b6d...01d12db00bf5
More information about the pdal-commits
