[pdal-commits] [PDAL/PDAL] a0b8c2: Updates for Streamable.
GitHub
noreply at github.com
Wed Feb 14 09:23:45 PST 2018
Branch: refs/heads/streamable
Home: https://github.com/PDAL/PDAL
Commit: a0b8c2ccd10f661777b2b2e26c753554c84e87aa
https://github.com/PDAL/PDAL/commit/a0b8c2ccd10f661777b2b2e26c753554c84e87aa
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-01-19 (Fri, 19 Jan 2018)
Changed paths:
M pdal/Filter.hpp
M pdal/Reader.hpp
M pdal/Stage.hpp
A pdal/Streamable.cpp
A pdal/Streamable.hpp
M pdal/Writer.hpp
Log Message:
Commit: 8ff2f1ef6e3af2834125c413f916b3131e21861f
https://github.com/PDAL/PDAL/commit/8ff2f1ef6e3af2834125c413f916b3131e21861f
Date: 2018-02-13 (Tue, 13 Feb 2018)
Changed paths:
M .gitignore
M .travis.yml
M CMakeLists.txt
M apps/pdal.cpp
M cmake/examples/hobu-config.sh
M cmake/win32_compiler_options.cmake
R doc/development/alpine.rst
A doc/project/alpine.rst
M doc/project/contributors.rst
M doc/project/docker.rst
A doc/project/index.rst
M doc/stages/filters.cluster.rst
A doc/stages/filters.mortonorder.img1.png
M doc/stages/filters.mortonorder.rst
M doc/stages/filters.python.rst
M doc/stages/readers.greyhound.rst
M doc/stages/readers.text.rst
A doc/stages/writers.greyhound.rst
M doc/tutorial/index.rst
M doc/tutorial/pcl_spec.rst
M examples/CMakeLists.txt
M examples/writing-kernel/MyKernel.hpp
M filters/FerryFilter.cpp
M filters/MortonOrderFilter.cpp
M filters/MortonOrderFilter.hpp
M filters/private/pnp/GridPnp.hpp
M io/GDALGrid.cpp
M io/GDALGrid.hpp
M io/Ilvis2Reader.cpp
M io/Ilvis2Reader.hpp
M io/LasHeader.cpp
M io/LasReader.cpp
M io/LasReader.hpp
M io/LasWriter.cpp
M io/LasWriter.hpp
M io/OGRWriterV1.cpp
M io/PlyReader.cpp
M io/QfitReader.cpp
M io/TIndexReader.cpp
M io/TIndexReader.hpp
M io/TextReader.cpp
M io/TextReader.hpp
M kernels/DeltaKernel.hpp
M kernels/GroundKernel.hpp
M kernels/HausdorffKernel.cpp
M kernels/InfoKernel.cpp
M kernels/InfoKernel.hpp
M kernels/PipelineKernel.hpp
M kernels/RandomKernel.hpp
M kernels/SortKernel.hpp
M kernels/TIndexKernel.cpp
M kernels/TIndexKernel.hpp
M kernels/TranslateKernel.hpp
M pdal/DbWriter.cpp
M pdal/DimUtil.hpp
M pdal/Dimension.json
M pdal/GDALUtils.cpp
M pdal/GEOSUtils.cpp
M pdal/Mesh.hpp
M pdal/PDALUtils.cpp
M pdal/PDALUtils.hpp
M pdal/PipelineManager.cpp
M pdal/PipelineReaderJSON.cpp
M pdal/PluginManager.cpp
M pdal/PluginManager.hpp
M pdal/PointView.hpp
R pdal/PyArray.hpp
M pdal/SpatialReference.cpp
M pdal/StageFactory.cpp
M pdal/Writer.cpp
M pdal/XMLSchema.hpp
M pdal/compression/Compression.hpp
A pdal/compression/DeflateCompression.cpp
M pdal/compression/DeflateCompression.hpp
A pdal/compression/LazPerfCompression.cpp
M pdal/compression/LazPerfCompression.hpp
A pdal/compression/LazPerfVlrCompression.cpp
A pdal/compression/LazPerfVlrCompression.hpp
A pdal/compression/LzmaCompression.cpp
M pdal/compression/LzmaCompression.hpp
A pdal/compression/ZstdCompression.cpp
M pdal/compression/ZstdCompression.hpp
M pdal/pdal_config.cpp
M pdal/pdal_config.hpp
M pdal/pdal_export.hpp
M pdal/pdal_internal.hpp
M pdal/pdal_macros.hpp
M pdal/plugin.hpp
M pdal/util/Utils.cpp
M pdal/util/Uuid.hpp
R pdal_defines.h.in
A pdal_features.hpp.in
M plugins/greyhound/CMakeLists.txt
A plugins/greyhound/io/GreyhoundCommon.cpp
A plugins/greyhound/io/GreyhoundCommon.hpp
M plugins/greyhound/io/GreyhoundReader.cpp
M plugins/greyhound/io/GreyhoundReader.hpp
A plugins/greyhound/io/GreyhoundWriter.cpp
A plugins/greyhound/io/GreyhoundWriter.hpp
M plugins/greyhound/io/bounds.cpp
M plugins/greyhound/io/bounds.hpp
M plugins/greyhound/io/point.hpp
M plugins/greyhound/test/GreyhoundReaderTest.cpp
M plugins/hexbin/kernel/DensityKernel.cpp
M plugins/hexbin/test/HexbinFilterTest.cpp
M plugins/mrsid/test/MrsidTest.cpp
M plugins/nitf/io/MetadataReader.cpp
M plugins/nitf/io/MetadataReader.hpp
M plugins/nitf/io/NitfFileReader.hpp
M plugins/nitf/io/NitfFileWriter.hpp
M plugins/nitf/io/NitfWriter.cpp
M plugins/nitf/io/tre_plugins.cpp
M plugins/nitf/test/NitfReaderTest.cpp
M plugins/oci/io/OciReader.cpp
M plugins/oci/io/OciWrapper.cpp
M plugins/oci/io/OciWriter.cpp
M plugins/pcl/kernel/PCLKernel.hpp
M plugins/pcl/kernel/SmoothKernel.cpp
M plugins/pcl/kernel/SmoothKernel.hpp
M plugins/python/plang/Environment.cpp
M plugins/python/plang/Invocation.cpp
M plugins/python/plang/Redirector.cpp
M plugins/python/plang/Redirector.hpp
M plugins/python/plang/Script.cpp
M plugins/python/test/PythonFilterTest.cpp
M plugins/sqlite/io/SQLiteReader.cpp
M plugins/sqlite/io/SQLiteWriter.cpp
M plugins/sqlite/test/SQLiteTest.cpp
A python/PKG-INFO
M python/VERSION.txt
A python/pdal/PyArray.hpp
M python/pdal/PyPipeline.cpp
M python/pdal/PyPipeline.hpp
M python/pdal/libpdalpython.pyx
A python/setup.cfg
M python/setup.py
M scripts/ci/script.sh
M scripts/docker/1.4-maintenance/alpine/Dockerfile
M scripts/docker/1.5-maintenance/alpine/Dockerfile
M scripts/docker/1.6-maintenance/alpine/Dockerfile
M scripts/docker/Dockerfile
M scripts/docker/master/alpine/Dockerfile
A test/data/text/missingheader.txt
M test/unit/CMakeLists.txt
R test/unit/CompressionTest.cpp
M test/unit/ConfigTest.cpp
A test/unit/DeflateTest.cpp
A test/unit/LazPerfTest.cpp
A test/unit/LzmaTest.cpp
M test/unit/PluginManagerTest.cpp
M test/unit/SegmentationTest.cpp
M test/unit/StageFactoryTest.cpp
M test/unit/UtilsTest.cpp
A test/unit/ZstdTest.cpp
M test/unit/apps/TIndexTest.cpp
M test/unit/apps/pc2pcTest.cpp
A test/unit/filters/MortonOrderTest.cpp
M test/unit/io/LasReaderTest.cpp
M test/unit/io/LasWriterTest.cpp
M test/unit/io/TextReaderTest.cpp
Log Message:
Merge branch 'plugin' into streamable
Commit: e022bc1d34501c4e7548231e27838ce3c3cc4f9a
https://github.com/PDAL/PDAL/commit/e022bc1d34501c4e7548231e27838ce3c3cc4f9a
Date: 2018-02-14 (Wed, 14 Feb 2018)
Log Message:
Merge branch 'master' into streamable
Compare: https://github.com/PDAL/PDAL/compare/a0b8c2ccd10f^...e022bc1d3450
More information about the pdal-commits
