[pdal-commits] [PDAL/PDAL] d76922: Config (#1796)
GitHub noreply at github.com
Mon Jan 29 09:27:08 PST 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: d76922bd893e99f1426d5d6adab2f50b3f088d14
      https://github.com/PDAL/PDAL/commit/d76922bd893e99f1426d5d6adab2f50b3f088d14
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-01-29 (Mon, 29 Jan 2018)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M cmake/win32_compiler_options.cmake
    M filters/private/pnp/GridPnp.hpp
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/Ilvis2Reader.cpp
    M io/Ilvis2Reader.hpp
    M io/LasHeader.cpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/PlyReader.cpp
    M io/QfitReader.cpp
    M kernels/HausdorffKernel.cpp
    M kernels/InfoKernel.cpp
    M pdal/DbWriter.cpp
    M pdal/GDALUtils.cpp
    M pdal/GEOSUtils.cpp
    M pdal/Mesh.hpp
    M pdal/PDALUtils.cpp
    M pdal/PDALUtils.hpp
    M pdal/PipelineManager.cpp
    M pdal/PluginManager.cpp
    M pdal/PointView.hpp
    M pdal/PyArray.hpp
    M pdal/SpatialReference.cpp
    M pdal/Writer.cpp
    M pdal/XMLSchema.hpp
    M pdal/compression/Compression.hpp
    A pdal/compression/DeflateCompression.cpp
    M pdal/compression/DeflateCompression.hpp
    A pdal/compression/LazPerfCompression.cpp
    M pdal/compression/LazPerfCompression.hpp
    A pdal/compression/LazPerfVlrCompression.cpp
    A pdal/compression/LazPerfVlrCompression.hpp
    A pdal/compression/LzmaCompression.cpp
    M pdal/compression/LzmaCompression.hpp
    A pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M pdal/pdal_config.cpp
    M pdal/pdal_config.hpp
    M pdal/pdal_export.hpp
    M pdal/pdal_internal.hpp
    M pdal/util/Utils.cpp
    M pdal/util/Uuid.hpp
    R pdal_defines.h.in
    A pdal_features.hpp.in
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundWriter.cpp
    M plugins/greyhound/io/point.hpp
    M plugins/mrsid/test/MrsidTest.cpp
    M plugins/nitf/io/MetadataReader.cpp
    M plugins/nitf/io/MetadataReader.hpp
    M plugins/nitf/io/NitfFileReader.hpp
    M plugins/nitf/io/NitfFileWriter.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/oci/io/OciWrapper.cpp
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/plang/Redirector.cpp
    M plugins/python/plang/Redirector.hpp
    M plugins/python/plang/Script.cpp
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M test/unit/CMakeLists.txt
    R test/unit/CompressionTest.cpp
    M test/unit/ConfigTest.cpp
    A test/unit/DeflateTest.cpp
    A test/unit/LazPerfTest.cpp
    A test/unit/LzmaTest.cpp
    M test/unit/PluginManagerTest.cpp
    M test/unit/SegmentationTest.cpp
    M test/unit/UtilsTest.cpp
    A test/unit/ZstdTest.cpp
    M test/unit/apps/pc2pcTest.cpp
  Log Message:
  Config (#1796)
Eliminate some conditional compilation and make build more build-system agnostic.
More information about the pdal-commits mailing list
