[pdal-commits] [PDAL/PDAL] b0ab8d: Change defines to features.
GitHub noreply at github.com
Mon Jan 29 12:26:00 PST 2018
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b0ab8d2a35f3e621c63c23892d2771f36348b8fa
      https://github.com/PDAL/PDAL/commit/b0ab8d2a35f3e621c63c23892d2771f36348b8fa
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-01-24 (Wed, 24 Jan 2018)
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M io/Ilvis2Reader.cpp
    M io/Ilvis2Reader.hpp
    M io/LasHeader.cpp
    M kernels/HausdorffKernel.cpp
    M kernels/InfoKernel.cpp
    M pdal/Mesh.hpp
    M pdal/PDALUtils.hpp
    M pdal/PipelineManager.cpp
    M pdal/PluginManager.cpp
    M pdal/XMLSchema.hpp
    M pdal/pdal_config.cpp
    M pdal/pdal_config.hpp
    M pdal/pdal_export.hpp
    M pdal/pdal_internal.hpp
    R pdal_defines.h.in
    A pdal_features.h.in
    M plugins/greyhound/CMakeLists.txt
    M plugins/greyhound/io/GreyhoundReader.cpp
    M plugins/greyhound/io/GreyhoundWriter.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M test/unit/ConfigTest.cpp
    M test/unit/PluginManagerTest.cpp
    M test/unit/SegmentationTest.cpp
    M test/unit/UtilsTest.cpp
  Log Message:
In progress.
  Commit: 802abfb46b4684c5462506d5855e5ea7b04300e3
      https://github.com/PDAL/PDAL/commit/802abfb46b4684c5462506d5855e5ea7b04300e3
  Changed paths:
  Log Message:
  Remove extra def.
  Commit: 2e55a50e5b7f9bfc2bfcc4231ee575a65ac09d5b
      https://github.com/PDAL/PDAL/commit/2e55a50e5b7f9bfc2bfcc4231ee575a65ac09d5b
  Changed paths:
    M pdal/PDALUtils.cpp
  Log Message:
  Noexcept ugh.
  Commit: dc685cc8bc1ef18cf62c6ded7ed1f2048c7d1e49
      https://github.com/PDAL/PDAL/commit/dc685cc8bc1ef18cf62c6ded7ed1f2048c7d1e49
  Changed paths:
  Log Message:
  Fix typo.
  Commit: 05c3636048c34f3937b93f6316e284b519dde00d
      https://github.com/PDAL/PDAL/commit/05c3636048c34f3937b93f6316e284b519dde00d
  Changed paths:
    M pdal/PyArray.hpp
    M plugins/python/plang/Redirector.hpp
  Log Message:
  Fix some python stuff.
  Commit: 12dc01fe45cce7b6a246d4f946797583f4dcfc7f
      https://github.com/PDAL/PDAL/commit/12dc01fe45cce7b6a246d4f946797583f4dcfc7f
  Changed paths:
    M plugins/sqlite/io/SQLiteReader.cpp
    M plugins/sqlite/io/SQLiteWriter.cpp
  Log Message:
  Add headers for sqlite.
  Commit: 6dd4bb251d3852383ccbc400ae3107e908490009
      https://github.com/PDAL/PDAL/commit/6dd4bb251d3852383ccbc400ae3107e908490009
  Date:   2018-01-25 (Thu, 25 Jan 2018)
  Changed paths:
    M CMakeLists.txt
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    A pdal/compression/DeflateCompression.cpp
    M pdal/compression/DeflateCompression.hpp
    A pdal/compression/LazPerfCompression.cpp
    M pdal/compression/LazPerfCompression.hpp
    A pdal/compression/LazPerfVlrCompression.cpp
    A pdal/compression/LazPerfVlrCompression.hpp
    A pdal/compression/LzmaCompression.cpp
    M pdal/compression/LzmaCompression.hpp
    A pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M test/unit/CMakeLists.txt
    M test/unit/CompressionTest.cpp
    A test/unit/DeflateTest.cpp
    A test/unit/LazPerfTest.cpp
    A test/unit/LzmaTest.cpp
    A test/unit/ZstdTest.cpp
  Log Message:
  Remove PDAL_HAVE dependencies from compression code.
  Commit: 2e9af63024acb9abb67682eb1ba5a1258a09b726
      https://github.com/PDAL/PDAL/commit/2e9af63024acb9abb67682eb1ba5a1258a09b726
  Changed paths:
    M pdal/compression/LazPerfVlrCompression.hpp
    R test/unit/CompressionTest.cpp
  Log Message:
  Remove dead test. Add header.
  Commit: c941c999a946fd638fdd4c64b8c935885f79e4c3
      https://github.com/PDAL/PDAL/commit/c941c999a946fd638fdd4c64b8c935885f79e4c3
  Changed paths:
    M pdal/compression/LazPerfCompression.cpp
    M pdal/compression/LazPerfVlrCompression.cpp
  Log Message:
  Fix lots of typos.
  Commit: fc33dae7c5a954dc50a748e8c7062e6f06b4db27
      https://github.com/PDAL/PDAL/commit/fc33dae7c5a954dc50a748e8c7062e6f06b4db27
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M cmake/win32_compiler_options.cmake
    M io/QfitReader.cpp
    M pdal/GDALUtils.cpp
    M pdal/GEOSUtils.cpp
    M pdal/PointView.hpp
    M pdal/SpatialReference.cpp
    M pdal/Writer.cpp
    M pdal/util/Utils.cpp
    M pdal/util/Uuid.hpp
    R pdal_features.h.in
    A pdal_features.hpp.in
    M plugins/mrsid/test/MrsidTest.cpp
    M plugins/nitf/io/MetadataReader.cpp
    M plugins/nitf/io/MetadataReader.hpp
    M plugins/nitf/io/NitfFileReader.hpp
    M plugins/nitf/io/NitfFileWriter.hpp
    M plugins/nitf/io/NitfWriter.cpp
    M plugins/nitf/io/tre_plugins.cpp
    M plugins/nitf/test/NitfReaderTest.cpp
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/plang/Redirector.cpp
    M plugins/python/plang/Script.cpp
    M test/unit/apps/pc2pcTest.cpp
  Log Message:
  Reduce dependencies on build system for correct compilation.
  Commit: 507428c20e46e48c1a35ce3ba0a7739caf5edfc2
      https://github.com/PDAL/PDAL/commit/507428c20e46e48c1a35ce3ba0a7739caf5edfc2
  Changed paths:
  Log Message:
  Remove warning catch for dead option.
  Commit: f5fbc9afacc067c69503be5bc5a389a09a4de424
      https://github.com/PDAL/PDAL/commit/f5fbc9afacc067c69503be5bc5a389a09a4de424
  Changed paths:
  Log Message:
  More.
  Commit: 71953e7b9402a20c3f004966a64915118563f37b
      https://github.com/PDAL/PDAL/commit/71953e7b9402a20c3f004966a64915118563f37b
  Changed paths:
    M pdal/compression/Compression.hpp
  Log Message:
  PDAL_DLL fun
  Commit: e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
      https://github.com/PDAL/PDAL/commit/e1fdd64523a18c6c8b6611a8542c6aaddaf901ff
  Changed paths:
    A doc/stages/filters.mortonorder.img1.png
    M doc/stages/filters.mortonorder.rst
    M doc/stages/filters.python.rst
    M doc/tutorial/pcl_spec.rst
    M filters/MortonOrderFilter.cpp
    M filters/MortonOrderFilter.hpp
    M pdal/DimUtil.hpp
    M scripts/ci/script.sh
    M scripts/docker/Dockerfile
    A test/unit/filters/MortonOrderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into config
  Commit: f223102ade3879d885fb54e0e193943b7ae7c413
      https://github.com/PDAL/PDAL/commit/f223102ade3879d885fb54e0e193943b7ae7c413
  Date:   2018-01-26 (Fri, 26 Jan 2018)
  Changed paths:
  Log Message:
  Remove arbiter lib.
  Commit: 904e7462d29ec36bcdf287f755fa27584a19f759
      https://github.com/PDAL/PDAL/commit/904e7462d29ec36bcdf287f755fa27584a19f759
  Changed paths:
    M filters/private/pnp/GridPnp.hpp
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/PlyReader.cpp
    M pdal/DbWriter.cpp
    M pdal_features.hpp.in
    M plugins/greyhound/io/point.hpp
    M plugins/oci/io/OciWrapper.cpp
  Log Message:
  Changes to eliminate warnings on MSVC.
  Commit: dae0102127107d54aeabcd292ff93d12b0087b4e
      https://github.com/PDAL/PDAL/commit/dae0102127107d54aeabcd292ff93d12b0087b4e
  Changed paths:
  Log Message:
  Remove extra PDAL_DLL.
  Commit: a4c89e44e8d8d7664e039c09d7cb1f4bf6043919
      https://github.com/PDAL/PDAL/commit/a4c89e44e8d8d7664e039c09d7cb1f4bf6043919
  Changed paths:
  Log Message:
  More missed PDAL_DLL on decompressor.
  Commit: 3c1a3542c57858814b4ee2e1e533c9e809918a61
      https://github.com/PDAL/PDAL/commit/3c1a3542c57858814b4ee2e1e533c9e809918a61
  Date:   2018-01-29 (Mon, 29 Jan 2018)
  Changed paths:
    M pdal/Mesh.hpp
  Log Message:
  Minor fixes.
  Commit: 7c0297a483f89fc137e367caa66c9a5c599e3dca
      https://github.com/PDAL/PDAL/commit/7c0297a483f89fc137e367caa66c9a5c599e3dca
  Changed paths:
  Log Message:
  Add missed LASZIP LAZPERF defines.
  Commit: 6c0b4775c1f8a3866ac3fc24d8882f6a747f8a84
      https://github.com/PDAL/PDAL/commit/6c0b4775c1f8a3866ac3fc24d8882f6a747f8a84
  Changed paths:
    M CMakeLists.txt
    M apps/pdal.cpp
    M io/GDALGrid.cpp
    M io/GDALGrid.hpp
    M io/LasHeader.cpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/PlyReader.cpp
    M io/QfitReader.cpp
    M pdal/DbWriter.cpp
    M pdal/Mesh.hpp
    M pdal/PyArray.hpp
    M pdal/Writer.cpp
    R pdal_defines.h.in
  Log Message:
  Merge branch 'config'
  Commit: cd43b47475caaf7e34eaaffcd46912c5866ff4ff
      https://github.com/PDAL/PDAL/commit/cd43b47475caaf7e34eaaffcd46912c5866ff4ff
  Changed paths:
  Log Message:
  Commit: 238f38f1af6701bc3d5897a8fa5c25d7bc1a9259
      https://github.com/PDAL/PDAL/commit/238f38f1af6701bc3d5897a8fa5c25d7bc1a9259
  Changed paths:
  Log Message:
  Add back LASZIP and LAZPERF defines.
Compare: https://github.com/PDAL/PDAL/compare/d76922bd893e...238f38f1af67
More information about the pdal-commits mailing list
