[pdal-commits] [PDAL/PDAL] a3135d: Use correct order to traversing stages when stream...
GitHub
noreply at github.com
Mon Jul 2 08:12:40 PDT 2018
Branch: refs/heads/issue-2001
Home: https://github.com/PDAL/PDAL
Commit: a3135db87664265ad6ded32c3b285875929ad375
https://github.com/PDAL/PDAL/commit/a3135db87664265ad6ded32c3b285875929ad375
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-06-27 (Wed, 27 Jun 2018)
Changed paths:
M pdal/StageExtensions.cpp
M pdal/StageExtensions.hpp
M pdal/Streamable.cpp
M test/unit/StreamingTest.cpp
Log Message:
Use correct order to traversing stages when streaming (#2067)
* Process points from left to right when streaming.
Close #2023
* PDAL_DLL StageExtensions::set
* Make sure output string is assigned.
Commit: c5abf081f3cf68b628de0cdedf07084b98cbe4c9
https://github.com/PDAL/PDAL/commit/c5abf081f3cf68b628de0cdedf07084b98cbe4c9
Date: 2018-07-02 (Mon, 02 Jul 2018)
Changed paths:
Log Message:
Merge remote-tracking branch 'origin/master' into issue-2001
Compare: https://github.com/PDAL/PDAL/compare/d0dbf134b606...c5abf081f3cf
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
