[pdal-commits] [PDAL/PDAL] 66936c: Add avg option to NNdistance filter. (#2076)
GitHub
noreply at github.com
Mon Jul 16 08:46:42 PDT 2018
Branch: refs/heads/docfixes
Home: https://github.com/PDAL/PDAL
Commit: 66936c950b3149926daf7886c69948a4a451b26b
https://github.com/PDAL/PDAL/commit/66936c950b3149926daf7886c69948a4a451b26b
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Date: 2018-07-10 (Tue, 10 Jul 2018)
Changed paths:
A filters/NNDistanceFilter.cpp
A filters/NNDistanceFilter.hpp
M pdal/Dimension.json
M test/unit/CMakeLists.txt
A test/unit/filters/NNDistanceTest.cpp
Log Message:
* Add nn distance dimension.
* Add general nearest neighbor distance filter.
* Migrate KDistanceFilter to more generic NNDistanceFilter.
Close #2071
* Full test.
* Add some test comments.
* Use distances, not square distances when computing averages.
* Remove unnecessary braces.
Commit: 004a8480adff030cdadb67664d196da4132492b9
https://github.com/PDAL/PDAL/commit/004a8480adff030cdadb67664d196da4132492b9
Date: 2018-07-11 (Wed, 11 Jul 2018)
Changed paths:
M io/GDALWriter.cpp
M test/unit/io/GDALWriterTest.cpp
Log Message:
Reset GDAL grid when we start a file. (#2079)
Close #2074
Commit: 2dd6dfbeecd4366f30cb006005f9768813e747ee
https://github.com/PDAL/PDAL/commit/2dd6dfbeecd4366f30cb006005f9768813e747ee
Changed paths:
M CMakeLists.txt
M cmake/modules/FindZSTD.cmake
Log Message:
Fix FindZST.cmake (#2085)
* Fix FindZST.cmake.
Use proper variable for ZSTD library.
Close #2036
* Remove repetitive function.
Commit: 95723489ab616b2d1d994d814359fa7646cb2e32
https://github.com/PDAL/PDAL/commit/95723489ab616b2d1d994d814359fa7646cb2e32
Date: 2018-07-16 (Mon, 16 Jul 2018)
Changed paths:
M CMakeLists.txt
M io/GDALWriter.cpp
Log Message:
Merge remote-tracking branch 'origin/master' into docfixes
Commit: 6b381bff8ca42c6ecd237916dc84d44932a79e54
https://github.com/PDAL/PDAL/commit/6b381bff8ca42c6ecd237916dc84d44932a79e54
Changed paths:
M doc/stages/references.bib
Log Message:
Add dummy line in an attempt to resolve warnings.
Didn't work :(
Requested here: https://github.com/mcmtroffaes/sphinxcontrib-bibtex/issues/141
Compare: https://github.com/PDAL/PDAL/compare/b35b7697b339...6b381bff8ca4
**NOTE:** This service been marked for deprecation: https://developer.github.com/changes/2018-04-25-github-services-deprecation/
Functionality will be removed from GitHub.com on January 31st, 2019.
More information about the pdal-commits
